Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 09-24-2007, 01:58   #136 (permalink)
CyberKareca's Avatar
Member: 3769
Thanks Meter: 53
Originally Posted by Raskal View Post
ATD works 100% check plz where u connect GND there are some issues with ATB but really ATD 100% tested
B.R.,
Raskal
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-146
Version: V_05.00_27-04-07_RM-146_(c)_Nokia.
IMEI: XXXXXXXXXXXXXXX
SP LOCK status:
Block 1: CLOSED Type 5 Data: 26801F
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Cable wrong codes counter: 0 wrong tries from max. 10 tries
Checking if model/version is supported for unlock ...
Skip autobackup of PM 308
Autobackup file:
RM-146_356408012606005_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-146_(c)_Nokia..bin
already exist
Set Full Factory Defaults ...
Full Factory Defaults set OK
Please connect testpoints
Testpoints connected OK ...
Unlocking phone ...
Try number: 1
Sending SP code: #pw+012345678901234+7#
Response byte: 08
Try number: 2
Response byte: 08
Try number: 3
Response byte: 08
Try number: 4
Response byte: 08
Try number: 5
Response byte: 08
Try number: 6
Response byte: 08
Try number: 7
Response byte: 08
Try number: 8
Response byte: 08
Try number: 9
Response byte: 08
Try number: 10
Response byte: 08
Unlock fail. Please try again.
NOTE: tested in more than 10 units, always same error.
BTW: I see there's a new version on the support site (v0.0.1.19) what are the new models ?
Old 09-24-2007, 03:04   #137 (permalink)
ryaz1993.'s Avatar
Member: 222481
Thanks Meter: 30
Type: RM-146
SP LOCK status:
Autobackup file:
already exist
Unlocking phone ...
Try number: 1
Response byte: 08
Try number: 2
Response byte: 08
Try number: 3
Response byte: 08
Try number: 4
Response byte: 08
Try number: 5
Response byte: 08
Try number: 6
Response byte: 08
Try number: 7
Response byte: 08
Try number: 8
Response byte: 08
Try number: 9
Response byte: 08
Try number: 10
Response byte: 08
BRO TRY THIS , KEEP IGNITION BUTTON PRESSED AND PRESS UNLOCK THEN CONNECT TPS TO CLK THEN DATA
SEE UR PHONE MUST BE UNLOCKED
remember u keep pressing your button of ignition till u see unlock success
see attachment
br
ryaz
Old 09-24-2007, 03:16   #138 (permalink)
tuffee11's Avatar
Member: 407680
Originally Posted by *MaTeOoSh* View Post
bb5box.org posted some hints - use 160 C hotair and after that glue should be removed easier.
sir your right i also done that to remove glue many time... but that method is not safe and we know many of work this method can make the unit dead so i just share my new discovery using this knife of the doctor... thank you...
br, Tuffee the TESTPOINT GUNNER...
Old 09-24-2007, 03:53   #139 (permalink)
Member: 3769
Thanks Meter: 53
see attachment
br
ryaz
Still not working....
Old 09-24-2007, 04:05   #140 (permalink)
Member: 588059
Thanks Meter: 47
What exactly is written on your phone flash chip? SEC xxxxxx-ATB, SEC-xxxxxx-ATD, Spnsion xxxxxxx ???
Old 09-24-2007, 04:05   #141 (permalink)
Ryuken's Avatar
Member: 16768
Sonork: 1583568
Thanks Meter: 37
Tested also on N91 & 5200,got 1 6300 with samsung flash on hand unlocking failed also...
Type: RM-217
Version: V_04.70_24-01-07_RM-217_(c)_Nokia.
IMEI: 356960019181705
SP LOCK status:
Block 1: CLOSED Type 5 Data: 51502F
Block 2: CLOSED Type 5 Data: 51502F
Autobackup file:
RM-217_3xxxxxxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_0 4.70_24-01-07_RM-217_(c)_Nokia..bin
already exist
Unlocking phone ...
Try number: 1
Response byte: 08
Try number: 2
Response byte: 08
Try number: 3
Response byte: 08
Try number: 4
Response byte: 08
Try number: 5
Response byte: 08
Try number: 6
Response byte: 08
Try number: 7
Response byte: 08
Try number: 8
Response byte: 08
Try number: 9
Response byte: 08
Try number: 10
Response byte: 08
Old 09-24-2007, 04:23   #142 (permalink)
nlogomaster's Avatar
Member: 16816
Sonork: 100.42691
Thanks Meter: 105
please post the flash chip of the phone while posting the logs.
br
nlogomaster
www.gsm-traders.com
Old 09-24-2007, 04:48   #143 (permalink)
Member: 3769
Thanks Meter: 53
SEC XXXXXX K5G5629ATD
Old 09-24-2007, 05:07   #144 (permalink)
Registered User
Member: 274461
Thanks Meter: 17
this box seems to be working good.. have anyone tried for the american models 5300b 5200b 6300b ? they are the same for the 5300 5200 and 6300?
Old 09-24-2007, 05:26   #145 (permalink)
Member: 80244
Thanks Meter: 49
br
nlogomaster
www.gsm-traders.com
so it means that these flash chips causing the error? or it only support some of this chips?
Old 09-24-2007, 08:44   #146 (permalink)
ryaz1993.'s Avatar
Member: 222481
Thanks Meter: 30
6131 unlocked successfull
br
ryaz
Old 09-24-2007, 08:50   #147 (permalink)
Member: 16816
Sonork: 100.42691
Thanks Meter: 105
much better to do this to have a more wider scope in analyzing problems if occured.
br
nlogomaster
www.gsm-traders.com
Old 09-24-2007, 08:56   #148 (permalink)
clearcom's Avatar
Member: 120669
Thanks Meter: 15
Thumbs up Successfully Unlock N6288 Via Bb5box
JUST WANT TO SHARE MAY UNLOCKING EXPERIENCE WITH BB5 BOX...
AROUND 8SECS MY PHONE IS FREE FROM OPERATOR..!
GREAT... GREAT.... GREAT...
MORE POWER!!!
THANKS TO RASKAL. MANOLE AND JAKE....
Old 09-24-2007, 11:02   #149 (permalink)
Member: 25392
Thanks Meter: 10
tested on 6280 3.40 and 6288 6.10
no need upgrade or downgrade covers a lot of version -this box works exactly like dejan box ..tp are identical the time needed for entering codes..for the moment my mt is geting rusty
Old 09-24-2007, 12:09   #150 (permalink)
bauzito's Avatar
Member: 120120
Sonork: 100.1592092
Thanks Meter: 234
My first Nokia with BB5 Box: Nokia 5200!!!!
Very fast no problems. Phone is working good with full signal.
Thank you BABY FIVE Team!!!!
★★★★★★ post here all phone unlocked with bb5 trk unlocker ★★★★★★ ProfesionalGSM BB5 Box by D.K. 98 06-11-2010 21:29
Post Here all phones repair with this latest updat! Faheem Anjum Universalbox 1 11-19-2009 08:50
POST HERE === BB5 Phones TESTED with 3/3 10/10 Cnt Rst === sudeeshveekey BB5BOX 11 04-26-2008 23:01
post here all phones unlocked with V32 RaMCES BB5BOX 4 01-13-2008 10:27
Page generated in 0.23584 seconds with 10 queries
