![]() | #302 (permalink) |
Major Poster ![]() ![]() Join Date: Nov 2004
Member: 94038 Status: Offline Thanks Meter: 0 | what could be responsible for this? Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-209 Version: V_04.70_24-01-07_RM-209_(c)_Nokia. IMEI: 356291010500580 SP LOCK status: Block 1: CLOSED Type 5 Data: 27202F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-209_356291010500580_Locked_Keycnt_0_Fbuscnt_0__V_0 4.70_24-01-07_RM-209_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-209 Version: V_04.70_24-01-07_RM-209_(c)_Nokia. IMEI: 356291010500580 SP LOCK status: Block 1: CLOSED Type 5 Data: 27202F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-209_356291010500580_Locked_Keycnt_0_Fbuscnt_0__V_0 4.70_24-01-07_RM-209_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. |
![]() | #304 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2005
Member: 202954 Status: Offline Thanks Meter: 32 | hi, here is my first, 5300 unlocking, Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-147 Version: V_04.51_11-01-07_RM-147_(c)_Nokia. IMEI: 354567010315273 SP LOCK status: Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-147_354567010315273_Locked_Keycnt_0_Fbuscnt_0__V_0 4.51_11-01-07_RM-147_(c)_Nokia..bin Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK alexssl63 (15:05): hi, here is my first, 5300 unlocking, Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-147 Version: V_04.51_11-01-07_RM-147_(c)_Nokia. IMEI: 354567010315273 SP LOCK status: Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-147_354567010315273_Locked_Keycnt_0_Fbuscnt_0__V_0 4.51_11-01-07_RM-147_(c)_Nokia..bin Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Block 1: OPEN Type 5 Data: 310160 Block 2: OPEN Type 5 Data: 310200 Block 3: OPEN Type 5 Data: 310210 Block 4: OPEN Type 5 Data: 310220 Block 5: OPEN Type 5 Data: 310230 Block 6: OPEN Type 5 Data: 310240 Block 7: OPEN Type 5 Data: 310250 Block 8: OPEN Type 5 Data: 310260 Block 9: OPEN Type 5 Data: 310270 Block 10: OPEN Type 5 Data: 310300 Block 11: OPEN Type 5 Data: 310310 Block 12: OPEN Type 5 Data: 310490 Block 13: OPEN Type 5 Data: 310530 Block 14: OPEN Type 5 Data: 310580 Block 15: OPEN Type 5 Data: 310590 Block 16: OPEN Type 5 Data: 310640 Block 17: OPEN Type 5 Data: 310660 Block 18: OPEN Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull THIS BOX WORKS GREAT, THANKS BB5 BOX TEAM. BR |
![]() | #306 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2004 Location: China Age: 46
Member: 68392 Status: Offline Sonork: 100.100701 Thanks Meter: 658 ![]() | Successfully unlock N95 use Acp12 for unlock. Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-92 Version: V_05wk33v33.1_22-06-06_RM-92_(c)_Nokia. IMEI: 358361003156563 SP LOCK status: Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Block 3: CLOSED Type 5 Data: 23433F Block 4: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-92_358361003156563_Locked_Keycnt_0_Fbuscnt_0__V_05 wk33v33.1_22-06-06_RM-92_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Block 1: OPEN Type 5 Data: 23433F Block 2: OPEN Type 5 Data: 23486F Block 3: OPEN Type 5 Data: 23433F Block 4: OPEN Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
![]() | #308 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Jun 2005 Age: 54
Member: 153305 Status: Offline Thanks Meter: 1 | E50 in 10 seconds Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-170 Version: V_3.37.23_11-10-06_RM-170_(c)_Nokia. IMEI: 353672014049422 SP LOCK status: Block 1: CLOSED Type 5 Data: 29340F Block 2: CLOSED Type 5 Data: 29340F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-170_353672014049422_Locked_Keycnt_0_Fbuscnt_0__V_3 .37.23_11-10-06_RM-170_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Block 1: OPEN Type 5 Data: 29340F Block 2: OPEN Type 5 Data: 29340F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
![]() | #309 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2005 Age: 38
Member: 138877 Status: Offline Thanks Meter: 0 | Quote:
![]() How many N80 you unlocked? Good Work! BR Louis Hope you can help the rest of us with your knowledge and experience now. | |
★★★★★★ post here all phone unlocked with bb5 trk unlocker ★★★★★★ | ProfesionalGSM | BB5 Box by D.K. | 98 | 06-11-2010 21:29 |
Post Here all phones repair with this latest updat! | Faheem Anjum | Universalbox | 1 | 11-19-2009 08:50 |
POST HERE === BB5 Phones TESTED with 3/3 10/10 Cnt Rst === | sudeeshveekey | BB5BOX | 11 | 04-26-2008 23:01 |
post here all phones unlocked with V32 | RaMCES | BB5BOX | 4 | 01-13-2008 10:27 |
