![]() | #376 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2005 Location: Sliven, Bulgaria
Member: 198847 Status: Offline Thanks Meter: 109 ![]() | Version: V_05.92_07-09-06_RM-78_(c)_Nokia unlocked sucsesfuly ; 6288-Type: RM-78 Version: V_06.10_21-12-06_RM-78_(c)_Nokia-unlocked sucsesfuly ; 6085- RM-198 Version: V_03.71_30-11-06-unlocked sucsesfuly |
![]() | #384 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2004 Location: PHILIPPINES
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 ![]() | Again......... 6288 - 5.92 UNLOCKED BB5Box ROCKS.............. Quote:
![]() ![]() ![]() br RNC_EBM | |
![]() | #385 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 ![]() | 5200 unllocked without problem Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_05.00_27-04-07_RM-174_(c)_Nokia. IMEI: 35xxxxxxxxxxxxxxx SP LOCK status: Config Key: 2082000000000000 Block 1: CLOSED Type 5 Data: 20820F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-174_35xxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_05.0 0_27-04-07_RM-174_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-174_35xxxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_05.00_2 7-04-07_RM-174_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2082000000000000 Block 1: CLOSED Type 5 Data: 20820F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2082000000000000 Block 1: OPEN Type 5 Data: 20820F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
![]() | #386 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005 Location: ROMANIA
Member: 188484 Status: Offline Thanks Meter: 117 | nokia 6234 sec....atb chip unlock ok vers 5.10 , 6280 vers 3.65,3.81,5.92,6.43 unlock ok , 6300 vers 4.70 unlock ok 5 sec unlock per phone ![]() |
![]() | #387 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2005 Location: repair shop Age: 44
Member: 181825 Status: Offline Thanks Meter: 199 | N 95 UNLOCKED SUCCESSFULLY ------ Operation: UNLOCK Date: 12-10-2007 Time: 13:19:31 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-159 Version: V_06wk41v23.4_17-04-07_RM-159_(c)_Nokia IMEI: 356996014930761 SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Block 2: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-159_356996014930761_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v23.4_17-04-07_RM-159_(c)_Nokia.bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-159_356996014930761_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v23.4_17-04-07_RM-159_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Block 2: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2343000000000000 Block 1: OPEN Type 5 Data: 23430F Block 2: OPEN Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
![]() | #388 (permalink) | ||
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 ![]() | 6133 T-Mobile Quote:
![]() ![]() br RNC_EBM | ||
![]() | #389 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | unlocked with bb5box v25 6288 spansion inside: Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.10_21-12-06_RM-78_(c)_Nokia IMEI: 355547014423884 SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_355547014423884_Locked_Keycnt_0_Fbuscnt_0__V_06 .10_21-12-06_RM-78_(c)_Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-78_355547014423884_Locked_Keycnt_0_Fbuscnt_0__V_06 .10_21-12-06_RM-78_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2342000000000000 Block 1: OPEN Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
★★★★★★ post here all phone unlocked with bb5 trk unlocker ★★★★★★ | ProfesionalGSM | BB5 Box by D.K. | 98 | 06-11-2010 21:29 |
Post Here all phones repair with this latest updat! | Faheem Anjum | Universalbox | 1 | 11-19-2009 08:50 |
POST HERE === BB5 Phones TESTED with 3/3 10/10 Cnt Rst === | sudeeshveekey | BB5BOX | 11 | 04-26-2008 23:01 |
post here all phones unlocked with V32 | RaMCES | BB5BOX | 4 | 01-13-2008 10:27 |
