![]() | #871 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005 Location: algeria Age: 54
Member: 189532 Status: Offline Thanks Meter: 28 | again E61i with our great box Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-227 Version: V_1.0615.31_12-02-07_RM-227_(c)_Nokia. IMEI: 35187901127***x SP LOCK status: Config Key: ***************x Block 1: CLOSED Type 5 Data: 21401F Block 2: CLOSED Type 5 Data: 21401F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-227_35187901127***x_Locked_Keycnt_0_Fbuscnt_0__V_1 .0615.31_12-02-07_RM-227_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: ***************x Block 1: OPEN Type 5 Data: 21401F Block 2: OPEN Type 5 Data: 21401F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull ![]() |
![]() | #872 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2007 Location: Phnom Penh(CAMBODIA)
Member: 447590 Status: Offline Thanks Meter: 378 | 6280 ETA can't unlock.But after choosing spansion sectin well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_05.92_07-09-06_RM-78_(c)_Nokia IMEI: 357926000131867 SP LOCK status: Config Key: 5050600042465540 Block 1: CLOSED Type 5 Data: 50506F Block 2: CLOSED Type 5 Data: 50599F Block 3: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_357926000131867_Locked_Keycnt_0_Fbuscnt_0__V_05 .92_07-09-06_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5050600042465540 Block 1: OPEN Type 5 Data: 50506F Block 2: OPEN Type 5 Data: 50599F Block 3: OPEN Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
![]() | #873 (permalink) |
Member: 447590 Status: Offline Thanks Meter: 378 | 6234 spansion well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-123 Version: V_05.10_21-12-06_RM-123_(c)_Nokia IMEI: 351869010928680 SP LOCK status: Config Key: 5050300014981890 Block 1: CLOSED Type 5 Data: 50503F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-123_351869010928680_Locked_Keycnt_0_Fbuscnt_0__V_0 5.10_21-12-06_RM-123_(c)_Nokia.bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5050300014981890 Block 1: OPEN Type 5 Data: 50503F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
![]() | #874 (permalink) |
Member: 447590 Status: Offline Thanks Meter: 378 | 6133 well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-126 Version: V_05.61_14-12-06_RM-126_(c)_Nokia. IMEI: 355536015057312 SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310170 Block 3: CLOSED Type 5 Data: 310200 Block 4: CLOSED Type 5 Data: 310210 Block 5: CLOSED Type 5 Data: 310220 Block 6: CLOSED Type 5 Data: 310230 Block 7: CLOSED Type 5 Data: 310240 Block 8: CLOSED Type 5 Data: 310250 Block 9: CLOSED Type 5 Data: 310260 Block 10: CLOSED Type 5 Data: 310270 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Block 19: CLOSED Type 5 Data: 310160 Block 20: CLOSED Type 5 Data: 310170 Block 21: CLOSED Type 5 Data: 310200 Block 22: CLOSED Type 5 Data: 310210 Block 23: CLOSED Type 5 Data: 310220 Block 24: CLOSED Type 5 Data: 310230 Block 25: CLOSED Type 5 Data: 310240 Block 26: CLOSED Type 5 Data: 310250 Block 27: CLOSED Type 5 Data: 310260 Block 28: CLOSED Type 5 Data: 310270 Block 29: CLOSED Type 5 Data: 310310 Block 30: CLOSED Type 5 Data: 310490 Block 31: CLOSED Type 5 Data: 310530 Block 32: CLOSED Type 5 Data: 310580 Block 33: CLOSED Type 5 Data: 310590 Block 34: CLOSED Type 5 Data: 310640 Block 35: CLOSED Type 5 Data: 310660 Block 36: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-126_355536015057312_Locked_Keycnt_0_Fbuscnt_0__V_0 5.61_14-12-06_RM-126_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5555555555555555 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Phone unlocked succesfull |
![]() | #875 (permalink) |
Member: 447590 Status: Offline Thanks Meter: 378 | N75 well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-128 Version: V_06wk15v37_08-03-07_RM-128_(c)_Nokia. IMEI: 354815010620451 SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310150 Block 3: CLOSED Type 5 Data: 310170 Block 4: CLOSED Type 5 Data: 310170 Block 5: CLOSED Type 5 Data: 310410 Block 6: CLOSED Type 5 Data: 310410 Block 7: CLOSED Type 5 Data: 311180 Block 8: CLOSED Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-128_354815010620451_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk15v37_08-03-07_RM-128_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3101700000000000 Block 1: OPEN Type 5 Data: 310150 Block 2: OPEN Type 5 Data: 310150 Block 3: OPEN Type 5 Data: 310170 Block 4: OPEN Type 5 Data: 310170 Block 5: OPEN Type 5 Data: 310410 Block 6: OPEN Type 5 Data: 310410 Block 7: OPEN Type 5 Data: 311180 Block 8: OPEN Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
![]() | #876 (permalink) |
Member: 447590 Status: Offline Thanks Meter: 378 | N75 ell done on first shot Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-128 Version: V_06wk15v37_08-03-07_RM-128_(c)_Nokia. IMEI: 354815012964030 SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310150 Block 3: CLOSED Type 5 Data: 310170 Block 4: CLOSED Type 5 Data: 310170 Block 5: CLOSED Type 5 Data: 310410 Block 6: CLOSED Type 5 Data: 310410 Block 7: CLOSED Type 5 Data: 311180 Block 8: CLOSED Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-128_354815012964030_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk15v37_08-03-07_RM-128_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3101700000000000 Block 1: OPEN Type 5 Data: 310150 Block 2: OPEN Type 5 Data: 310150 Block 3: OPEN Type 5 Data: 310170 Block 4: OPEN Type 5 Data: 310170 Block 5: OPEN Type 5 Data: 310410 Block 6: OPEN Type 5 Data: 310410 Block 7: OPEN Type 5 Data: 311180 Block 8: OPEN Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
![]() | #877 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | i have big problem regarding 6288 unlock its the second time i am having this problem when i attatch Test points the phone loses the communication with the fone any suggestions plz Br |
![]() | #878 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | 6280 eta Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.43_30-03-07_RM-78_(c)_Nokia IMEI: 357926000018296 SP LOCK status: Config Key: 5050600042465540 Block 1: CLOSED Type 5 Data: 50506F Block 2: CLOSED Type 5 Data: 50599F Block 3: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 4096 bytes Saving autobackup to file: RM-78_357926000018296_Locked_Keycnt_0_Fbuscnt_0__V_06 .43_30-03-07_RM-78_(c)_Nokia.bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5050600042465540 Block 1: OPEN Type 5 Data: 50506F Block 2: OPEN Type 5 Data: 50599F Block 3: OPEN Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
![]() | #880 (permalink) |
Major Poster ![]() ![]() Join Date: Apr 2006
Member: 264802 Status: Offline Thanks Meter: 6 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.50_14-08-07_RM-217_(c)_Nokia. IMEI: 359810011361531 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-217_359810011361531_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-217_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2343300000000000 Block 1: OPEN Type 5 Data: 23433F Block 2: OPEN Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
![]() | #881 (permalink) |
Member: 447590 Status: Offline Thanks Meter: 378 | 6280 spansin well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.10_21-12-06_RM-78_(c)_Nokia IMEI: 357926006735307 SP LOCK status: Config Key: 5050600042465540 Block 1: CLOSED Type 5 Data: 50506F Block 2: CLOSED Type 5 Data: 50599F Block 3: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 4096 bytes Saving autobackup to file: RM-78_357926006735307_Locked_Keycnt_0_Fbuscnt_0__V_06 .10_21-12-06_RM-78_(c)_Nokia.bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5050600042465540 Block 1: OPEN Type 5 Data: 50506F Block 2: OPEN Type 5 Data: 50599F Block 3: OPEN Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
![]() | #883 (permalink) |
Member: 447590 Status: Offline Thanks Meter: 378 | 6280 spansion well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.43_30-03-07_RM-78_(c)_Nokia IMEI: 352264019735584 SP LOCK status: Config Key: 2680100000000000 Block 1: CLOSED Type 5 Data: 26801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 4096 bytes Saving autobackup to file: RM-78_352264019735584_Locked_Keycnt_0_Fbuscnt_0__V_06 .43_30-03-07_RM-78_(c)_Nokia.bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2680100000000000 Block 1: OPEN Type 5 Data: 26801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
![]() | #884 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2006 Location: Bangladesh
Member: 247758 Status: Offline Sonork: 100.1574842 Thanks Meter: 259 | 6300 unlock successful ------ Operation: READ PM 308 Date: 19-02-2008 Time: 12:42:30 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.71_28-02-07_RM-217_(c)_Nokia. IMEI: 359544012013888 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reading PM Field 308 Subfield 1 with length 8192 bytes Saving to file: RM-217_3595440_Locked_Keycnt_0_Fbuscnt_0__V_04.71_28-02-07_RM-217_(c)_Nokia.__19_02_2008__12_42_44.bin Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.71_28-02-07_RM-217_(c)_Nokia. IMEI: 3595440 SP LOCK status: Config Key: 5050300014981890 Block 1: CLOSED Type 5 Data: 50503F Block 2: CLOSED Type 5 Data: 50503F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-217_3595_Locked_Keycnt_0_Fbuscnt_0__V_04.71_28-02-07_RM-217_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-21_Locked_Keycnt_0_Fbuscnt_0__V_04.71_28-02-07_RM-217_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 5050300014981890 Block 1: CLOSED Type 5 Data: 50503F Block 2: CLOSED Type 5 Data: 50503F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5050300014981890 Block 1: OPEN Type 5 Data: 50503F Block 2: OPEN Type 5 Data: 50503F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
★★★★★★ post here all phone unlocked with bb5 trk unlocker ★★★★★★ | ProfesionalGSM | BB5 Box by D.K. | 98 | 06-11-2010 21:29 |
Post Here all phones repair with this latest updat! | Faheem Anjum | Universalbox | 1 | 11-19-2009 08:50 |
POST HERE === BB5 Phones TESTED with 3/3 10/10 Cnt Rst === | sudeeshveekey | BB5BOX | 11 | 04-26-2008 23:01 |
post here all phones unlocked with V32 | RaMCES | BB5BOX | 4 | 01-13-2008 10:27 |
