03-18-2008, 17:32 | #1066 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Tunisia Age: 53
Member: 240499 Status: Offline Thanks Meter: 151 | ------ Operation: UNLOCK V1 Date: 18-03-2008 Time: 11:25:22 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.50_14-08-07_RM-217_(c)_Nokia. IMEI: 352042020086373 SP LOCK status: Config Key: 2620700000000000 Block 1: CLOSED Type 5 Data: 262074 Block 2: CLOSED Type 5 Data: 262075 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-217_352042020086373_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-217_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-217_352042020086373_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-217_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2620700000000000 Block 1: CLOSED Type 5 Data: 262074 Block 2: CLOSED Type 5 Data: 262075 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2620700000000000 Block 1: OPEN Type 5 Data: 262074 Block 2: OPEN Type 5 Data: 262075 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
03-18-2008, 17:38 | #1067 (permalink) |
Member: 240499 Status: Offline Thanks Meter: 151 | ------ Operation: UNLOCK V1 Date: 18-03-2008 Time: 15:48:52 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-115 Version: V_06.10_16-02-07_RM-115_(c)_Nokia. IMEI: 352257016025140 SP LOCK status: Config Key: 2080100000000000 Block 1: CLOSED Type 5 Data: 20801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-115_352257016025140_Locked_Keycnt_0_Fbuscnt_0__V_0 6.10_16-02-07_RM-115_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-115_352257016025140_Locked_Keycnt_0_Fbuscnt_0__V_0 6.10_16-02-07_RM-115_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2080100000000000 Block 1: CLOSED Type 5 Data: 20801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2080100000000000 Block 1: OPEN Type 5 Data: 20801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
03-19-2008, 05:48 | #1068 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Phnom Penh(CAMBODIA)
Member: 447590 Status: Offline Thanks Meter: 378 | 5300 well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_05.02_05-06-07_RM-146_(c)_Nokia. IMEI: 356433012519768 SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-146_356433012519768_Locked_Keycnt_0_Fbuscnt_0__V_0 5.02_05-06-07_RM-146_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3102000000000000 Block 1: OPEN Type 5 Data: 310160 Block 2: OPEN Type 5 Data: 310200 Block 3: OPEN Type 5 Data: 310210 Block 4: OPEN Type 5 Data: 310220 Block 5: OPEN Type 5 Data: 310230 Block 6: OPEN Type 5 Data: 310240 Block 7: OPEN Type 5 Data: 310250 Block 8: OPEN Type 5 Data: 310260 Block 9: OPEN Type 5 Data: 310270 Block 10: OPEN Type 5 Data: 310300 Block 11: OPEN Type 5 Data: 310310 Block 12: OPEN Type 5 Data: 310490 Block 13: OPEN Type 5 Data: 310530 Block 14: OPEN Type 5 Data: 310580 Block 15: OPEN Type 5 Data: 310590 Block 16: OPEN Type 5 Data: 310640 Block 17: OPEN Type 5 Data: 310660 Block 18: OPEN Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
03-19-2008, 08:19 | #1069 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | 6280 spansion ad0 Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.40_20-12-05_RM-78_(c)_Nokia IMEI: 357926006717420 SP LOCK status: Config Key: 5050600042465540 Block 1: CLOSED Type 5 Data: 50506F Block 2: CLOSED Type 5 Data: 50599F Block 3: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-78_357926006717420_Locked_Keycnt_0_Fbuscnt_0__V_03 .40_20-12-05_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5050600042465540 Block 1: OPEN Type 5 Data: 50506F Block 2: OPEN Type 5 Data: 50599F Block 3: OPEN Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
03-19-2008, 08:28 | #1070 (permalink) |
No Life Poster Join Date: May 2007 Location: P A K I S T A N
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | ------ Operation: UNLOCK V2 Date: 19-03-2008 Time: 11:39:11 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.10_21-12-06_RM-78_(c)_Nokia IMEI: 355547019617928 SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_355547019617928_Locked_Keycnt_0_Fbuscnt_0__V_06 .10_21-12-06_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2342000000000000 Block 1: OPEN Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
03-19-2008, 09:06 | #1071 (permalink) |
Registered User Join Date: May 2005 Location: My Office
Member: 143939 Status: Offline Thanks Meter: 264 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.71_28-02-07_RM-217_(c)_Nokia. IMEI: 353932019****** SP LOCK status: Config Key: 5050300014981890 Block 1: CLOSED Type 5 Data: 50503F Block 2: CLOSED Type 5 Data: 50503F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 1 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-217_353932019460689_Locked_Keycnt_3_Fbuscnt_1__V_0 4.71_28-02-07_RM-217_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-217_353932019460689_Locked_Keycnt_3_Fbuscnt_1__V_0 4.71_28-02-07_RM-217_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 5050300014981890 Block 1: CLOSED Type 5 Data: 50503F Block 2: CLOSED Type 5 Data: 50503F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 1 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using cable codes ... Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5050300014981890 Block 1: OPEN Type 5 Data: 50503F Block 2: OPEN Type 5 Data: 50503F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
03-19-2008, 09:13 | #1072 (permalink) |
Member: 447590 Status: Offline Thanks Meter: 378 | E65 well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-208 Version: V_1.0615.25_10-01-07_RM-208_(c)_Nokia. IMEI: 353262015666406 SP LOCK status: Config Key: 2081000000000000 Block 1: CLOSED Type 5 Data: 20810F Block 2: CLOSED Type 5 Data: 20810F Block 3: CLOSED Type 5 Data: 64710F Block 4: CLOSED Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-208_353262015666406_Locked_Keycnt_0_Fbuscnt_0__V_1 .0615.25_10-01-07_RM-208_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2081000000000000 Block 1: OPEN Type 5 Data: 20810F Block 2: OPEN Type 5 Data: 20810F Block 3: OPEN Type 5 Data: 64710F Block 4: OPEN Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
03-19-2008, 21:00 | #1073 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Earth
Member: 426389 Status: Offline Thanks Meter: 2,356 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.43_30-03-07_RM-78_(c)_Nokia IMEI: 357603001810696 SP LOCK status: Config Key: 2229900093172790 Block 1: CLOSED Type 5 Data: 22299F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_357603001810696_Locked_Keycnt_0_Fbuscnt_0__V_06 .43_30-03-07_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2229900093172790 Block 1: OPEN Type 5 Data: 22299F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
03-20-2008, 06:26 | #1074 (permalink) |
Member: 447590 Status: Offline Thanks Meter: 378 | N95 well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-159 Version: V_06wk41v23.4_17-04-07_RM-159_(c)_Nokia IMEI: 356962015806715 SP LOCK status: Config Key: 2341500000000000 Block 1: CLOSED Type 5 Data: 23415F Block 2: CLOSED Type 5 Data: 23415F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-159_356962015806715_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v23.4_17-04-07_RM-159_(c)_Nokia.bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2341500000000000 Block 1: OPEN Type 5 Data: 23415F Block 2: OPEN Type 5 Data: 23415F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
03-20-2008, 06:30 | #1075 (permalink) |
Member: 447590 Status: Offline Thanks Meter: 378 | N75 well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-128 Version: V_06wk15v37_08-03-07_RM-128_(c)_Nokia. IMEI: 354815012658327 SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310150 Block 3: CLOSED Type 5 Data: 310170 Block 4: CLOSED Type 5 Data: 310170 Block 5: CLOSED Type 5 Data: 310410 Block 6: CLOSED Type 5 Data: 310410 Block 7: CLOSED Type 5 Data: 311180 Block 8: CLOSED Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-128_354815012658327_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk15v37_08-03-07_RM-128_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3101700000000000 Block 1: OPEN Type 5 Data: 310150 Block 2: OPEN Type 5 Data: 310150 Block 3: OPEN Type 5 Data: 310170 Block 4: OPEN Type 5 Data: 310170 Block 5: OPEN Type 5 Data: 310410 Block 6: OPEN Type 5 Data: 310410 Block 7: OPEN Type 5 Data: 311180 Block 8: OPEN Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
03-20-2008, 08:09 | #1076 (permalink) |
Member: 447590 Status: Offline Thanks Meter: 378 | 6085 well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-198 Version: V_05.03_09-08-07_RM-198_(c)_Nokia. IMEI: 358061017421744 SP LOCK status: Config Key: 5050100058056920 Block 1: CLOSED Type 5 Data: 50501F Block 2: CLOSED Type 5 Data: 50501F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 3 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-198_358061017421744_Locked_Keycnt_0_Fbuscnt_3__V_0 5.03_09-08-07_RM-198_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5050100058056920 Block 1: OPEN Type 5 Data: 50501F Block 2: OPEN Type 5 Data: 50501F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
03-21-2008, 08:37 | #1077 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Inside Samsung Pocket Age: 40
Member: 489331 Status: Offline Thanks Meter: 1,141 | ----- Operation: UNLOCK V1 Date: 19-03-2008 Time: 17:21:49 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.43_30-03-07_RM-78_(c)_Nokia IMEI: 358669014133177 SP LOCK status: Config Key: 4250200000000000 Block 1: CLOSED Type 5 Data: 42502F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 4096 bytes Saving autobackup to file: RM-78_358669014133177_Locked_Keycnt_0_Fbuscnt_10__V_0 6.43_30-03-07_RM-78_(c)_Nokia.bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 4250200000000000 Block 1: OPEN Type 5 Data: 42502F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull ----- Operation: UNLOCK V1 Date: 20-03-2008 Time: 16:56:41 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.43_30-03-07_RM-78_(c)_Nokia IMEI: 358669015459498 SP LOCK status: Config Key: 4250200000000000 Block 1: CLOSED Type 5 Data: 42502F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_358669015459498_Locked_Keycnt_0_Fbuscnt_0__V_06 .43_30-03-07_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 4250200000000000 Block 1: OPEN Type 5 Data: 42502F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
03-21-2008, 10:02 | #1078 (permalink) |
Member: 489331 Status: Offline Thanks Meter: 1,141 | ------ Operation: UNLOCK V2 Date: 21-03-2008 Time: 00:52:34 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_05.92_07-09-06_RM-78_(c)_Nokia IMEI: 352264012324725 SP LOCK status: Config Key: 4250200000000000 Block 1: CLOSED Type 5 Data: 42502F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 4096 bytes Saving autobackup to file: RM-78_352264012324725_Locked_Keycnt_0_Fbuscnt_10__V_0 5.92_07-09-06_RM-78_(c)_Nokia.bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 4250200000000000 Block 1: OPEN Type 5 Data: 42502F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
03-21-2008, 10:13 | #1079 (permalink) |
No Life Poster Join Date: Jul 2006 Location: I.N.D.I.A(PUNJAB)
Member: 309398 Status: Offline Sonork: 100.1590052 Thanks Meter: 5,455 | n73 Successfuly UNLOCKED! Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v48_26-06-07_RM-133_(c)_Nokia. IMEI: 356406011517124 SP LOCK status: Config Key: 5050600042465540 Block 1: CLOSED Type 5 Data: 50506F Block 2: CLOSED Type 5 Data: 50599F Block 3: CLOSED Type 5 Data: 50506F Block 4: CLOSED Type 5 Data: 50599F Block 5: CLOSED Type 5 Data: 00101F Block 6: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-133_356406011517124_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v48_26-06-07_RM-133_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5050600042465540 Block 1: OPEN Type 5 Data: 50506F Block 2: OPEN Type 5 Data: 50599F Block 3: OPEN Type 5 Data: 50506F Block 4: OPEN Type 5 Data: 50599F Block 5: OPEN Type 5 Data: 00101F Block 6: OPEN Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
03-21-2008, 10:17 | #1080 (permalink) |
Member: 309398 Status: Offline Sonork: 100.1590052 Thanks Meter: 5,455 | Successful unlock whith new TP Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_05.92_07-09-06_RM-78_(c)_Nokia IMEI: 353227014359600 SP LOCK status: Config Key: 2140100000000000 Block 1: CLOSED Type 5 Data: 21401F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 4096 bytes Saving autobackup to file: RM-78_353227014359600_Locked_Keycnt_0_Fbuscnt_0__V_05 .92_07-09-06_RM-78_(c)_Nokia.bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2140100000000000 Block 1: OPEN Type 5 Data: 21401F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull WBR : VINAY |
★★★★★★ post here all phone unlocked with bb5 trk unlocker ★★★★★★ | ProfesionalGSM | BB5 Box by D.K. | 98 | 06-11-2010 21:29 |
Post Here all phones repair with this latest updat! | Faheem Anjum | Universalbox | 1 | 11-19-2009 08:50 |
POST HERE === BB5 Phones TESTED with 3/3 10/10 Cnt Rst === | sudeeshveekey | BB5BOX | 11 | 04-26-2008 23:01 |
post here all phones unlocked with V32 | RaMCES | BB5BOX | 4 | 01-13-2008 10:27 |
