12-15-2007, 12:16 | #1 (permalink) |
Crazy Poster Join Date: Feb 2007
Member: 451774 Status: Offline Thanks Meter: 4 | problem reading phone JAF version 1.98.42 Detected PKEY: 9XXXXXX7 Card life counter: 99.72% P-key nokia module version 01.00 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... Failed! Aborting! IMEI when i connect the lcd, i see "test mode" in display any soluce ? |
12-19-2007, 00:57 | #7 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Brazil Age: 43
Member: 81894 Status: Offline Thanks Meter: 29 | I am in the same situation, I believe that is defective in cable dku, insisting info can do, because the cable of 5200 this normal, the precise schematic of the cable dku jaf team or some solution. thanks |
12-19-2007, 01:17 | #8 (permalink) |
Banned Join Date: Nov 2007
Member: 632155 Status: Offline Thanks Meter: 0 | My v-spec came with two cables one with DK-2 header and the other with a mini Usb header. Ok you have two cable if one is working just to test you can add the pop port header to the working cable. e.g., if you DK-2 is working wire-up the mini usb to the working cable, connect tx,rx, grd and vpp four wires. How you have a two header cable. and like they two heads are better then one. enjoy...E.C. |
problem reading phone code in coral 300 [ANSWERED] | ray_granville | PolarBox 3 | 7 | 10-29-2009 21:05 |
Jaf & Jaf+ Problem Reading Phones | picks | J.A.F. Plus | 2 | 01-26-2008 19:16 |
M6100 problem... reading phone info slooooooowly and then Failed | Burnt Cobba | ThunderStorm Box | 2 | 03-26-2007 13:58 |
unlocking LG G4020 - - problems reading phone | Zoeb | Phone Unlocking Codes & Maps | 2 | 11-25-2004 14:28 |
