11-29-2010, 02:21 | #91 (permalink) |
Registered User Join Date: Feb 2006 Location: tagum,davao philippines
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | first charge the battery 2nd open the software select e2120 3rd uncheck the imei so that after procedure you wont need to repair imei 4th erase firmware 5th select e2120 flashfile 5th update firmware. thats all insert fully charge battery and try ....... |
12-01-2010, 06:05 | #92 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1009679 Status: Offline Thanks Meter: 166 | another repaired E2120 11/30/2010. i re-flashed with different version. Using USTPRO, HWK, and Z3X no solved the problem. still keep on restarting. But repaired 100% this way. Open phone mild reheat flash IC and CPU, and re-flashed again with Z3X and problem solved. you see it can be repaired but risky procedure. |
12-01-2010, 12:43 | #93 (permalink) | |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | Quote:
12-01-2010, 14:21 | #94 (permalink) |
Junior Member Join Date: Mar 2010 Location: FATEHPUR UP INDIA Age: 45
Member: 1248310 Status: Offline Sonork: 100.1641641 Thanks Meter: 7 | great information .......about this seri's phone ... bcoz many models like (e2120i) after flash also same problem i hope this solution help to all .. |
12-01-2010, 15:03 | #95 (permalink) |
No Life Poster Join Date: Jan 2003 Location: ALGERIEN
Member: 19423 Status: Offline Sonork: 69566 Thanks Meter: 246 | 'i spen time to repair this model' lowcost phone no need to buy PCB for this c rap this team need real search and provider another platform to unlock like HTC android and Semc xperia is bitter good team good job all this years |
12-05-2010, 08:04 | #103 (permalink) |
No Life Poster Join Date: Jun 2007
Member: 533476 Status: Offline Thanks Meter: 1,855 | E2120, E2120i, E2120B - 100% restart solution!!! change pcb and phone will work 100%. other solution not exist. If someone have other solution you can post only in this tread!!! Keep z3x section clear and easy for searching if someone need real solutiion and real help. not waste time. if i will see 1more post in z3x section about this problem - tread poster will be blocked from z3x section forever. |
12-05-2010, 08:15 | #104 (permalink) |
Freak Poster Join Date: Apr 2010 Location: france
Member: 1287817 Status: Offline Sonork: france Thanks Meter: 10 | hi it must be the heating system then errase, repaire, custme then full flash and I had saucer of this model and I used this method and works fine 100% |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
Pic Solution | jan | Nokia Hardware & Hardware Repair | 8 | 10-11-2010 10:56 |
100% unlock1 for Nokia 6150 v5.17 ------,......... | cIVIc | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-10-1999 02:00 |
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! | spterminator | Main Sales Section | 2 | 08-13-1999 05:55 |
