02-09-2017, 12:21 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | LG LS775 stuck in download mode in unlocking supported models: 1426 Mode: Normal Model: LS775ZV8 Build version: Dec 23 201611:58:01Nov 18 201604:00:00LS775ZV8 SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1 IMEI: 35630407647022-4 BlueTooth Address: 00:00:00:00:00:00 Phone Code: Elapsed: 1 secs. --> (v9.30) Mode: Normal Model: LS775ZV8 Build version: Dec 23 201611:58:01Nov 18 201604:00:00LS775ZV8 SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1 IMEI: 35630407647022-4 BlueTooth Address: 00:00:00:00:00:00 Phone Code: Elapsed: 1 secs. --> (v9.30) Checking phone at COM624 Detected ID: 00000FFE (MSM8916) SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1 Reading ESN... OK Read SPC... Unlock SPC... error Elapsed: 1 secs. --> (v9.30) Mode: Normal Model: LS775ZV8 Build version: Dec 23 201611:58:01Nov 18 201604:00:00LS775ZV8 SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1 IMEI: 35630407647022-4 BlueTooth Address: 00:00:30:30:30:30 Phone Code: Elapsed: 1 secs. --> (v9.30) Checking phone at COM624 Detected ID: 00000FFE (MSM8916) SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1 Reading ESN... OK Read SPC... Unlock SPC... error Elapsed: 1 secs. --> (v9.30) Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 3 secs. --> (v9.30) Mode: Normal Model: LS775ZV8 Build version: Dec 23 201611:58:01Nov 18 201604:00:00LS775ZV8 SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1 IMEI: 35630407647022-4 BlueTooth Address: 00:00:30:30:30:30 Phone Code: Elapsed: 1 secs. --> (v9.30) Phone mode is NORMAL Switch to DOWNLOAD mode Phone detected! Start unlock Sprint... Model name: LGLS775 Software verion: LS775ZV8 Android verion: 7.0 IMEI: 356304076470224 Backup carrier... done Init EXT4 ... /apps /apps/node.db /apps/node.db-journal Laf flash ext4 error: [ChmodChown] could not find root inode. Error change rights for /cust... Laf flash ext4 error: [ChmodChown] could not find root inode. Error change rights for /omadm... Save EXT4... Laf cmd error: LAF_CMD_WRITE fail[LAF_ERROR_UNKNOWN[80000121]]. Elapsed: 45 secs. --> (v9.30) |
The Following User Says Thank You to maplegsm For This Useful Post: |
02-10-2017, 13:21 | #2 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Middle-Earth
Member: 190274 Status: Offline Thanks Meter: 47 | Me too. Octoplus doesn't mess up the phone like this. Kindly fix this problem asap! LG 2-3G Tool v9.32 supported models: 1440 Mode: Normal Model: LS775ZV8 Build version: Dec 23 201611:58:01Nov 18 201604:00:00LS775ZV8 SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1 IMEI: 356304079xxxxxxx BlueTooth Address: 00:00:00:00:00:00 Phone Code: Elapsed: 1 secs. --> (v9.32) Mode: Normal Model: LS775ZV8 Build version: Dec 23 201611:58:01Nov 18 201604:00:00LS775ZV8 SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1 IMEI: 356304079xxxxxxxx BlueTooth Address: 00:00:00:00:00:00 Phone Code: Elapsed: 1 secs. --> (v9.32) Phone mode is NORMAL Switch to DOWNLOAD mode Phone detected! Start unlock Sprint... Model name: LGLS775 Software verion: LS775ZV8 Android verion: 7.0 IMEI: 356304079xxxxxx Backup carrier... done Init EXT4 ... /apps /apps/node.db /apps/node.db-journal Laf flash ext4 error: [ChmodChown] could not find root inode. Error change rights for /cust... Laf flash ext4 error: [ChmodChown] could not find root inode. Error change rights for /omadm... Save EXT4... Laf cmd error: LAF_CMD_WRITE fail[LAF_ERROR_UNKNOWN[80000121]]. Elapsed: 53 secs. --> (v9.32) |
The Following User Says Thank You to hiroprotagonist For This Useful Post: |
02-10-2017, 13:51 | #3 (permalink) |
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | waiting for support answer i want to restore back in Normal state if we cant unlock i downloaded its tot https://forum.xda-developers.com/and...-0-lg-t3552990 but z3x unable to flash always same error battery 50% charged 2/9/2017 8:44:59 PM: LG 2-3G Tool v9.32 2/9/2017 8:44:59 PM: supported models: 1440 2/9/2017 8:44:59 PM: 2/9/2017 8:48:02 PM: Reading timeout, check cable 2/9/2017 8:48:02 PM: Error Code: ReadInfo,1,1 2/9/2017 8:48:02 PM: Elapsed: 2 secs. --> (v9.32) 2/9/2017 8:48:02 PM: 2/9/2017 8:49:48 PM: Reading timeout, check cable 2/9/2017 8:49:48 PM: Error Code: ReadInfo,1,1 2/9/2017 8:49:48 PM: Elapsed: 2 secs. --> (v9.32) |
02-10-2017, 14:59 | #4 (permalink) |
Member: 190274 Status: Offline Thanks Meter: 47 | Flashing mine with same file. Its currently at 40%. You should charge battery at external source before flashing. It will work. |
02-10-2017, 15:00 | #5 (permalink) |
Member: 190274 Status: Offline Thanks Meter: 47 | It looks like the unlock process messes with a partition, which makes it get stuck in download mode. Repartition during flash process should change that. |
02-10-2017, 15:04 | #6 (permalink) |
Member: 190274 Status: Offline Thanks Meter: 47 | Process is done sucessfully. Phone is back to working state. LG 2-3G Tool v9.32 supported models: 1440 Mode: Emergency Model: LS775 Read info... Model name: LGLS775 Software verion: LS775ZV8 Android verion: 7.0 IMEI: 356304079xxxxxxxx Elapsed: 2 secs. --> (v9.32) Phone mode is DOWNLOAD Start flashing. Open TOT File : M:\Work\LG\LS775\LS775ZV8_07.tot Model : LGLS775 SwVersion : LS775ZV8 BuildTime : Total Files : 22 Model name: LGLS775 Software verion: LS775ZV8 Android verion: 7.0 IMEI: 356304079xxxxxxx Laf flash error: incompatible partition table [start] 01D56000:01D5BFDD, grow Start direct download mode Write "PrimaryGPT" partition #1 of 22 Write "sbl1" partition #2 of 22 Write "tz" partition #3 of 22 Write "hyp" partition #4 of 22 Write "rpm" partition #5 of 22 Write "aboot" partition #6 of 22 Write "sbl1bak" partition #7 of 22 Write "tzbak" partition #8 of 22 Write "hypbak" partition #9 of 22 Write "rpmbak" partition #10 of 22 Write "abootbak" partition #11 of 22 Write "persist" partition #12 of 22 Write "metadata" partition #13 of 22 Write "laf" partition #14 of 22 Write "boot" partition #15 of 22 Write "recovery" partition #16 of 22 Write "recoverybak" partition #17 of 22 Write "sec" partition #18 of 22 Write "factory" partition #19 of 22 Write "modem" partition #20 of 22 Write "carrier" partition #21 of 22 Write "system" partition #22 of 22 Erase "rct" partition Done. Elapsed: 286 secs. --> (v9.32) Make sure to boot to recovery mode and do hard reset to prevent force close of settings app after flashing |
The Following 5 Users Say Thank You to hiroprotagonist For This Useful Post: |
02-10-2017, 19:47 | #8 (permalink) | |
Freak Poster Join Date: Nov 2006 Location: COLOMBIA
Member: 383903 Status: Offline Thanks Meter: 3 | Quote:
please share the flash file, link not working.... thaks | |
The Following User Says Thank You to john r For This Useful Post: |
02-10-2017, 19:48 | #9 (permalink) | |
thanks | |
02-13-2017, 09:08 | #11 (permalink) |
Member: 190274 Status: Offline Thanks Meter: 47 | Here it is: Download LS775ZV8 zip |
The Following 6 Users Say Thank You to hiroprotagonist For This Useful Post: |
02-27-2017, 10:17 | #13 (permalink) |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | You can't more unlock Sprint phone with Android 7 because LG add firmware sign. You can't write in phone only signed firmware. For repair phone: Put phone in Download mode Reflash with last firmwares -- |
The Following User Says Thank You to andrew_tm For This Useful Post: |
03-15-2017, 14:51 | #14 (permalink) | |
Freak Poster Join Date: Sep 2007
Member: 593061 Status: Offline Thanks Meter: 19 | downgrade is possible Quote:
The Following 3 Users Say Thank You to juan_junior99 For This Useful Post: |
