01-14-2018, 08:46 | #19771 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Read Codes via Server Selected model: SM-J320ZN Selected port: COM783 SAMSUNG Mobile USB Serial Port Software version: 30.5 Checking Login and Password... OK Ballance: 95 crd. You have 95 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J320ZN Android version: 5.1.1 Product code: SM-J320ZZKNTLP Phone version: J320ZNDOU1AQH1 PDA version: J320ZNDOU1AQH1 CSC version: J320ZNTLP1AQH1 CSC country code: Australia CSC sales code: TLP HW version: MP 0.200 Phone SN: R58H854AJ4H Chip name: MSM8916 Modem board: MSM8916 Security patch: 2017-08-01 RF cal date: 2016.08.30 IMEI: Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM9 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 64263038 NET lock: 53904259 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.5 |
01-14-2018, 08:47 | #19772 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Read Codes via Server Selected model: SM-J320ZN Selected port: COM783 SAMSUNG Mobile USB Serial Port Software version: 30.5 Checking Login and Password... OK Ballance: 95 crd. You have 95 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J320ZN Android version: 5.1.1 Product code: SM-J320ZZKNTLP Phone version: J320ZNDOU1AQH1 PDA version: J320ZNDOU1AQH1 CSC version: J320ZNTLP1AQH1 CSC country code: Australia CSC sales code: TLP HW version: MP 0.200 Phone SN: R58H854AJ4H Chip name: MSM8916 Modem board: MSM8916 Security patch: 2017-08-01 RF cal date: 2016.08.30 IMEI: Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM9 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 64263038 NET lock: 53904259 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.5 |
01-14-2018, 14:17 | #19774 (permalink) |
No Life Poster Join Date: May 2014 Location: D.I.Khan [KPK] Age: 35
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | Sm-j530f/ds frp 7.0 SM-J530F/DS FRP Removed Successfully using ADB method of z3x Code: Waiting ADB device... OK Reading phone info... Model: SM-J530F Android version: 7.0 Product code: SM-J530FZDDPAK Phone version: J530FXXU1AQED PDA version: J530FXWU1AQF1 CSC version: J530FOJV1AQF3 CSC country code: PAKISTAN CSC sales code: PAK HW version: REV0.5B Phone SN: R28J642DHMR Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-06-01 RF cal date: 20170630 IMEI: 3564xxxxxxxxxxxx Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.5 |
The Following 3 Users Say Thank You to EjazATF For This Useful Post: |
01-14-2018, 15:29 | #19775 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Cuba Age: 56
Member: 517318 Status: Offline Thanks Meter: 88 | Unlock A520W 100% Operation: Read Codes via Server Selected model: SM-A520W Software version: 30.5 Checking Login and Password... Listo Ballance: 35 crd. You have 35 credit(s) left. This operation takes 5 credits.Continue? Si Searching Samsung modem... detectado COM100 Leyendo información del teléfono ... Listo Modelo: SM-A520W AP version: A520WVLS1AQH1 CSC version: A520WOYA1AQH1 CP version: A520WVLS1AQH1 Código del Producto: SM-A520WZKABMC Phone SN: R58J54RDHFH Número único: CBJ100F6565FA34 Searching Samsung diag port... detectado COM99 Leyendo información del teléfono ... Listo CP version: A520WVLS1AQH1 CP build: Aug 3 2017 19:04:44 Lectura de datos desde el teléfono ... Listo Calculando... Listo Buscando servidor... Listo Waiting for server answer... Listo Congelar código: 64642639 NET lock: 31315136 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 Para comprobar bloquea el estado: *#7465625# Done with Samsung Tool PRO v.30.5 |
01-14-2018, 17:46 | #19776 (permalink) |
No Life Poster Join Date: Sep 2013 Location: KERALA, INDIA
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | Samsung j320f ssuccessfully unlocked ! Operation: Read Codes Selected model: SM-J320F Software version: 30.5 Searching Samsung modem... detected COM991 Reading phone info... OK Model: SM-J320F Version: J320FXXU0AQK2/J320FDBT0AQK1/J320FXXU0AQI1/J320FXXU0AQK2 Product code: SM-J320FZKDDBT Phone SN: RV8J50YDEWR IMEI: 356440087616072 Unique number: CQN00D0614FC434 Reading codes... OK Please wait, calculating codes... OK (time - 00:00:30) Freeze code: 41482504 NET lock: 38538264 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.5 |
01-14-2018, 17:56 | #19777 (permalink) |
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | G935f frp reset done by UFS method !! Operation: Reset FRP UFS Selected model: SM-G935F Selected port: COM4 Z3X BOX Serial Port Software version: 30.5 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM4 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G935F) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done |
01-15-2018, 09:35 | #19778 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | j120a read codes diag mode Operation: Read Codes DIAG Selected model: SM-J120A Software version: 30.4 Checking hash file... OK Searching Samsung modem... detected COM90 Reading phone info... OK Model: SM-J120A AP version: J120AUCU2APJ2 CSC version: J120AATT2APJ2 CP version: J120AUCU2APJ2 Product code: SM2J120AZWCATT Phone SN: R58J14FPCAY Unique number: CFN00A6BEEE9FC3 Searching Samsung diag port... detected COM89 Reading phone info... OK CP version: J120AUCU2APJ2 CP build: Oct 13 2016 18:53:03 Reading data from phone... OK Reading NV data... OK Modem board: SHANNON308 Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:56) Freeze code: 85084636 NET lock: 40483513 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.4 |
01-15-2018, 11:02 | #19779 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Punjabi University India
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | Samsung j1 Ace Unlock done Operation: Read Codes Selected model: SM-J111F Software version: 30.5 Searching Samsung modem... detected COM25 Reading phone info... OK Model: SM-J111F Version: J111FXXU0AQD2/J111FOLB0APL2/J111FXXU0AQC2/J111FXXU0AQD2 Product code: SM-J111FZWDXME Phone SN: RV8J90WLH5T IMEI: 35262109xxxxxxx Unique number: CFN00C1C6D05F64 Reading codes... OK Please wait, calculating codes... OK (time - 00:01:37) Freeze code: 90582418 NET lock: 60374070 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.5 Thanks z3x Team |
01-15-2018, 12:32 | #19780 (permalink) |
No Life Poster Join Date: Mar 2012 Location: punjab
Member: 1732025 Status: Offline Sonork: 100.1615024 Thanks Meter: 329 | Samsung j327p unlock done !!!!! Waiting ADB device... OK Reading phone info... Model: SM-J327P Android version: 6.0.1 Product code: Not Active Phone version: J327PVPU1AQF4 PDA version: J327PVPU1AQF4 CSC version: J327PSPT1AQF4 CSC country code: USA CSC sales code: SPR HW version: J327P.03 Phone SN: 00000000000 Modem board: MSM8917 Security patch: 2017-06-01 RF cal date: 2017.02.18 IMEI: 352510082626443 Writing AT RIL... OK Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.4 |
01-15-2018, 22:26 | #19781 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | G935T unlock done Operation: Unlock Selected model: SM-G935T Software version: 30.5 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G935T Android version: 6.0.1 Product code: SM-G935TZBATMB Phone version: G935TUVS4BQC1 PDA version: G935TUVU4APIA CSC version: G935TTMB4APIA CSC country code: USA CSC sales code: TMB HW version: REV0.7 Phone SN: RF8HB2YHTQY Chip name: MSM8996 Modem board: MSM8996 Security patch: 2016-09-01 RF cal date: 2016.11.23 IMEI: 355018080927257 Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM3 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.5 |
01-16-2018, 05:46 | #19782 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Sri Lanka Age: 35
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Reset FRP/React/EE Selected model: SM-J106H Software version: 30.4 Searching Samsung USB Flash interface... COM13 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.4 |
01-16-2018, 05:47 | #19783 (permalink) |
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Reset FRP Selected model: SM-J111F Software version: 30.4 Waiting ADB device... OK Reading phone info... Model: SM-J111F Android version: 5.1.1 Product code: SM-J111FZKDXSG Phone version: J111FXXU0AQC2 PDA version: J111FXXU0AQD2 CSC version: J111FOJV0AQD3 CSC country code: UAE CSC sales code: XSG HW version: MP 0.200 Phone SN: RV8J40XQDFZ Chip name: SC9830I Modem board: SC9830i Security patch: 2017-04-01 RF cal date: 2017.04.19 IMEI: 2515925302514f0 Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.4 |
01-16-2018, 05:47 | #19784 (permalink) |
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Reset FRP/React/EE Selected model: SM-J200G Software version: 30.4 Searching Samsung USB Flash interface... COM9 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.4 |
01-16-2018, 09:49 | #19785 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 1995502 Status: Offline Thanks Meter: 139 | Operation: Unlock Selected model: GT-S7580 Software version: 20.5 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-S7580 Android version: 4.2.2 Product code: Phone version: S7580XXUBOA1 PDA version: S7580XXUBOB1 CSC version: S7580OXFBNK1 CSC country code: Serbia CSC sales code: TOP HW version: Phone S/N: 00000000000 Modem board: RF cal date: IMEI: 359702055269193 Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.20.5 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
