01-07-2018, 13:01 | #19726 (permalink) |
Freak Poster Join Date: Jul 2012 Location: khujand
Member: 1791645 Status: Offline Sonork: 119.01.15.66 Thanks Meter: 44 | S5310 unlock done Selected port: COM37 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-S5310 Android version: 4.1.2 Product code: Unknown Phone version: S5310XXAME1 PDA version: S5310XXAML1 CSC version: S5310OXEAML1 IMEI: 357520056874296 Phone S/N: R21D8AP5SFM Checking Super user right... false Rooting phone, please wait... OK Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.19.1 |
01-07-2018, 13:36 | #19728 (permalink) |
Member: 1791645 Status: Offline Sonork: 119.01.15.66 Thanks Meter: 44 | GT-I9500 IMEI: 004999010640000 repair done Selected model: I9500 Selected port: COM37 Z3X BOX Serial Port Selected port speed: 115200 Waiting ADB device... OK Reading phone info... Model: GT-I9500 Android version: 4.4.2 Product code: Not Active Phone version: I9500XXUGNL1 PDA version: I9500XXUGNJ1 CSC version: I9500SERGNJ1 IMEI: 004999010640000 Phone S/N: Unknown Checking Super user right... true Reseting EFS... OK Rebooting phone... OK Waiting ADB device... OK Reading phone info... Model: GT-I9500 Android version: 4.4.2 Product code: Not Active Phone version: I9500XXUGNL1 PDA version: I9500XXUGNJ1 CSC version: I9500SERGNJ1 IMEI: 004999010640000 Phone S/N: Unknown Checking Super user right... true Disabling Factory mode... OK Reading nv data... OK Reading modem... OK Patching modem... error Checking magic... OK Running zTool, please wait... OK Security damaged or incorrect key, retry... Running zTool, please wait... OK Detected new type of security version 1 Calculating... OK Writing nv data... OK Rebooting phone... OK Repair done Done with Samsung Tool v.19.1 |
01-07-2018, 13:37 | #19729 (permalink) |
Member: 1791645 Status: Offline Sonork: 119.01.15.66 Thanks Meter: 44 | GT-I9500 Write CERT done Selected model: I9500 Selected port: COM37 Z3X BOX Serial Port Selected port speed: 115200 Checking certificate file... OK Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-I9500 Android version: 5.0.1 Product code: GT-I9500XXXSER Phone version: I9500XXUHOA7 PDA version: I9500XXUHOA7 CSC version: I9500SERHOA7 IMEI: Unknown Phone S/N: R21F327HR4L Checking Super user right... true Reading nv data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security v1 Writing nv data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool v.19.1 |
01-07-2018, 14:44 | #19730 (permalink) | |||
No Life Poster Join Date: Oct 2010 Location: .::: Madina :::.
Member: 1427732 Status: Offline Sonork: ˙·٠•● Thanks Meter: 1,061 | SM-N920T FRP Reset By UFS Method Using Uart Cable Quote:
01-07-2018, 15:35 | #19731 (permalink) |
Junior Member Join Date: Mar 2014 Location: algeria blida city
Member: 2142531 Status: Offline Sonork: chawkiphone Thanks Meter: 3 | UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings) Opération:Read Codes via Server Modèle sélectionné:SM-A520F Version du logiciel:30.4 Checking Login and Password... Ok Ballance: 45 crd. You have 45 credit(s) left. This operation takes 5 credits.Continue? Oui RechercheSamsung modem... détécté COM369 Lecture d'information du telephone... Ok Modèle: SM-A520F AP version: A520FXXU2BQK1 CSC version: A520FLUX2BQK1 CP version: A520FXXU2BQK1 Code du produit: LUX Téléphones SN: R58J50NH7NP Numéro unique: CBJ10EF3C423234 RechercheSamsung diag port... détécté COM368 Lecture d'information du telephone... Ok CP version: A520FXXU2BQK1 CP build: Nov 6 2017 11:36:12 Lecture données du Téléphone... Ok Calcul... Ok Serveur Recherche... Ok Waiting for server answer... Ok Freeze code: 83507363 NET verrou: 92061361 SUB verrou: 00000000 SP verrou: 00000000 CP verrou: 00000000 SIM verrou: 00000000 Pour connaître l'état de verrouillage : *#7465625# Fait avecSamsung Tool PRO v.30.4 |
01-07-2018, 18:30 | #19732 (permalink) |
No Life Poster Join Date: May 2014 Location: D.I.Khan [KPK] Age: 35
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | SM-G532F FRP Removed Successfully Code: Operation: Flash Selected model: SM-G532F Software version: 30.4 File analysis... OK Total file size: 0x00919910 (9 Mb) Searching USB Flash interface... COM22 detected Setup connection... OK Reading PIT from phone... OK Sending boot.img... OK Flashing done (time - 00:00:04) Code: Operation: Reset FRP Selected model: SM-G532F Software version: 30.4 Waiting ADB device... OK Reading phone info... Model: SM-G532F Android version: 6.0.1 Product code: SM-G532FZDDAFR Phone version: G532FXXU1AQG5 PDA version: G532FXWU1AQG5 CSC version: G532FOJV1AQG5 CSC country code: Kenya CSC sales code: AFR HW version: MP 0.300 Phone SN: R58HC5270GH Chip name: MT6737T Modem board: MT6737T Security patch: 2017-07-01 RF cal date: 20161224 IMEI: 35562xxxxxxxxxxxx Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.4 |
The Following 2 Users Say Thank You to EjazATF For This Useful Post: |
01-07-2018, 20:00 | #19733 (permalink) |
No Life Poster Join Date: May 2013
Member: 1930570 Status: Offline Thanks Meter: 82 | J327T APP LOCK DONE IN 3 MINUTES Operation: Unlock Selected model: SM-J327T Software version: 30.4 Checking Login and Password... OK Ballance: 40 crd. You have 40 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J327T Android version: 7.0 Product code: SM2J327TZKATMB Phone version: J327TUVU1AQG1 PDA version: J327TUVU1AQG1 CSC version: J327TTMB1AQG1 CSC country code: USA CSC sales code: TMB HW version: REV0.1 Phone SN: RV8Jxxxxxx Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-07-01 RF cal date: 20171019 IMEI: 35200xxxxxx Searching Samsung diag port... detected COM744 Reading phone info... OK CP version: J327TUVU1AQG1 CP build: Jul 13 2017 17:10:11 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.4 |
01-08-2018, 10:30 | #19734 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Punjabi University India
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | Samsung S4 i337m unlock done [ 01/08/2018 14:34:00 ] Operation: Unlock [ 01/08/2018 14:34:00 ] Selected model: SGH-I337M [ 01/08/2018 14:34:00 ] Selected port: COM32 SAMSUNG Mobile USB Serial Port [ 01/08/2018 14:34:00 ] Software version: 29.4 [ 01/08/2018 14:34:00 ] [ 01/08/2018 14:34:00 ] Reading phone info... [ 01/08/2018 14:34:00 ] Reading IMEI... OK [ 01/08/2018 14:34:00 ] IMEI: 35376707xxxxxxx [ 01/08/2018 14:34:00 ] Unlocking... OK [ 01/08/2018 14:34:00 ] Reseting... OK [ 01/08/2018 14:34:00 ] Unlock done Thanks z3x Team |
01-08-2018, 11:35 | #19735 (permalink) |
No Life Poster Join Date: Oct 2013 Location: Cote Ivoire ABJ,tvlle, LBJ.23 Age: 39
Member: 2041210 Status: Offline Thanks Meter: 541 | unlock samsung C6625 take 2H30 to done Code: Selected model: C6625 Selected com port: COM8 Selected speed port: 921600 Power On phone Press on phone keyboard code *#0228# Press Back and press 2 key Select UART-CP and connect phone on cable Phone detected [SOFTWARE]:C6625BUID1 [Unique number]:60000000193466 [IMEI]:359757020241966 [Serial number]:R3WS418466 Start Bruteforce Msl code detected: 180051 Unlock - ok Elapsed time: 2882 second, sw ver: 3.5.0040 |
01-08-2018, 17:20 | #19736 (permalink) |
No Life Poster Join Date: Sep 2013 Location: KERALA, INDIA
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | SM-G615F successfully read codes !! Operation: Read Codes Selected model: SM-G615F Software version: 30.2 Checking hash file... OK Waiting ADB device... OK Reading phone info... Model: SM-G615F Android version: 7.0 Product code: SM-G615FZKDINS Phone version: G615FXXU1AQL1 PDA version: G615FXXU1AQL1 CSC version: G615FODD1AQL1 CSC country code: India CSC sales code: INS HW version: MP 0.200 Phone SN: RZ8J912BY7W Chip name: MT6757 Modem board: MT6757 Security patch: 2017-12-01 RF cal date: 20170911 IMEI: xxxxxxxxxxxxxxxxxxxxx Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM454 detected Reading data from phone... OK Please wait, calculating codes... OK (time - 00:00:10) Freeze code: 48402631 NET lock: 00000000 SUB lock: 00000000 SP lock: 00000000 CP lock: 24259171 SIM lock: -------- For check lock status: *#7465625# |
01-08-2018, 17:23 | #19737 (permalink) |
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | SM-G928T successfully reset FRP done with UFS method !! Operation: Reset FRP UFS Selected model: SM-G928T Selected port: COM4 Z3X BOX Serial Port Software version: 29.6 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM4 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G928T) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done |
01-08-2018, 18:55 | #19738 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Between Heaven and Hell
Member: 563008 Status: Offline Thanks Meter: 108 | Samsung Note 8 unlock by server UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Operation: Read Codes via Server Selected model: SM-N950F Software version: 30.4 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 5 credits.Continue? Yes Searching Samsung modem... detected COM54 Reading phone info... OK Model: SM-N950F AP version: N950FXXU1AQI1 CSC version: N950FOVF1AQI1 CP version: N950FXXU1AQHB Product code: VOD Phone SN: R58JB6GK Unique number: 988A1B445359354 Searching Samsung diag port... detected COM55 Reading phone info... OK CP version: N950FXXU1AQHB CP build: Aug 17 2017 17:41:21 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 73682862 NET lock: 60742463 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.4 |
01-08-2018, 21:47 | #19739 (permalink) |
Junior Member Join Date: Mar 2009
Member: 994015 Status: Offline Sonork: 12345 Thanks Meter: 0 | unlock galaxy g925t via z3x done [ 08/01/2018 21:39:00 ] Operation: Unlock [ 08/01/2018 21:39:00 ] Selected model: SM-G925T [ 08/01/2018 21:39:00 ] Selected port: COM64 SAMSUNG Mobile USB Serial Port [ 08/01/2018 21:39:00 ] Software version: 30.4 [ 08/01/2018 21:39:00 ] [ 08/01/2018 21:39:00 ] Waiting ADB device... Listo [ 08/01/2018 21:39:00 ] Leyendo información del teléfono ... [ 08/01/2018 21:39:00 ] Modelo: SM-G925T [ 08/01/2018 21:39:00 ] Android version: 6.0.1 [ 08/01/2018 21:39:00 ] Código del Producto: SM2G925TZDATMB [ 08/01/2018 21:39:00 ] Versión del telefono: G925TUVU5EQC2 [ 08/01/2018 21:39:00 ] PDA version: G925TUVU5EQC2 [ 08/01/2018 21:39:00 ] CSC version: G925TTMB5EQC2 [ 08/01/2018 21:39:00 ] Código de país CSC: USA [ 08/01/2018 21:39:00 ] Código de Venta CSC: TMB [ 08/01/2018 21:39:00 ] HW version: REV0.2 [ 08/01/2018 21:39:00 ] Phone SN: R58G80RNBGP [ 08/01/2018 21:39:00 ] Chip name: EXYNOS7420 [ 08/01/2018 21:39:00 ] Módem: SHANNON333 [ 08/01/2018 21:39:00 ] Security patch: 2017-03-01 [ 08/01/2018 21:39:00 ] RF cal date: 20150812 [ 08/01/2018 21:39:00 ] IMEI: 359715061931036 [ 08/01/2018 21:39:00 ] Verificando derecho de Super Usuario... verdadero [ 08/01/2018 21:40:00 ] Reading NV data... Listo [ 08/01/2018 21:40:00 ] Checking NV data... Listo [ 08/01/2018 21:40:00 ] Initialization zTool... Listo [ 08/01/2018 21:40:00 ] Running zTool, please wait... Listo [ 08/01/2018 21:40:00 ] HWID: 88 CD 8A 1C 35 04 00 00 00 00 00 00 00 00 00 00 [ 08/01/2018 21:40:00 ] Calculando... Listo [ 08/01/2018 21:40:00 ] Desbloquear... Listo [ 08/01/2018 21:40:00 ] Writing NV data... Listo [ 08/01/2018 21:41:00 ] Reiniciando teléfono ... Listo [ 08/01/2018 21:41:00 ] Desbloqueo Listo [ 08/01/2018 21:41:00 ] |
01-08-2018, 23:01 | #19740 (permalink) |
Freak Poster Join Date: Jul 2014 Location: Haiti
Member: 2216186 Status: Offline Sonork: 100.1668130 Thanks Meter: 120 | Samsung Galaxy S8+ TMO Unlock done by Z3X via Unlock by Server TMO 10 cr (APP Unlock) Operation: Unlock Selected model: SM-G955U Selected port: COM78 SAMSUNG Mobile USB Serial Port Software version: 30.4 Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G955U Android version: 7.0 Product code: SM2G955UZVATMB Phone version: G955USQU1AQGA PDA version: G955USQU1AQGA CSC version: G955UOYN1AQGA CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R28JA0EF5DM Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-07-01 RF cal date: 2017.10.11 IMEI: 357759xxxxxxxx Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM42 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.4 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
