07-14-2017, 21:23 | #18706 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Selected com port: COM16 Selected speed port: 115200 Phone must be ON Search modem ... OK Search modem on:COM98 Model: GT-S5230 CountryCode: VOP Factory SW: S5230ACIF3_IG1 UniqueNumber: 55270000324051 MemoryPhone: K522H1HACA(S5230) Phone IMEI: 35795203095127 /2 Phone S/N: RPHSA78118 Phone Bluetooth ID: A0 07 98 45 B3 7B Phone SW: S5230ACIF3_IG1 Phone HW: MP 0.610 Phone CalData ver: 20091013 Searching server... OK Calculating security.... OK Please wait decrypt code ... OK [FREZEE]:94617963 [NET LOCK]:19793941 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 Decrypted time: 37 sec Elapsed time: 50 second, sw ver: 3.5.0040 |
07-14-2017, 22:09 | #18707 (permalink) |
Freak Poster Join Date: Apr 2008 Location: A_1st™ Support Age: 38
Member: 758981 Status: Offline Sonork: 100.1592091 Thanks Meter: 232 | Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 6.0.1 Product code: SM-G925TZKATMB Phone version: G925TUVS5EQA2 PDA version: G925TUVS5EQA2 CSC version: G925TTMB5EQA2 CSC country code: USA CSC sales code: TMB HW version: REV0.2 Phone SN: R58G51ZPVBV Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-01-01 RF cal date: 20150525 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 88 D9 B5 F6 56 04 00 00 00 00 00 00 00 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.28.7 |
07-14-2017, 23:14 | #18708 (permalink) |
Freak Poster Join Date: Apr 2007 Location: EDMONTON, CA / PH
Member: 489518 Status: Offline Thanks Meter: 47 | GALAXY S8 G955W UNLOCKING DONE Operation: Read Codes via Server Selected model: SM-G955W Software version: 28.6 Checking Login and Password... OK Balance: 50 crd. Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G955W Android version: 7.0 Product code: SM-G955WZKAGLW Phone version: G955WVLS1AQF7 PDA version: G955WVLS1AQF7 CSC version: G955WOYA1AQF7 CSC country code: Canada CSC sales code: GLW HW version: REV1.0 Phone SN: R28J53W6XRA Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-06-01 RF cal date: 2017.05.31 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM46 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 83836979 NET lock: 83962570 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.6 |
07-16-2017, 08:03 | #18709 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Opération:Write CERT Modèle sélectionné:SM-G530AZ Port sélectionné:COM60 SAMSUNG Mobile USB Serial Port Version du logiciel:28.7.2 Vérification du dossier CERT... Ok KEY ID: 0816 En attendant le périphériqueADB... Ok Lecture d'information du telephone... Modèle: SAMSUNG-SM-G530AZ Android version: 4.4.4 Code du produit: SM2G530AZWMAIO Version du telephone: G530AZTUU4BOI1 PDA version: FA44_G530AZTUU4BOI1 CSC version: SCC code de pays: CSC code de vente: HW version: REV0.2 Téléphones SN: 00000000000 Prise modem: MSM8916 RF cal date: 2015.08.05 IMEI: 357549064589349 RédactionAT RIL... Ok InitialisationAT RIL... Ok Contourne MSL... Ok Vérification pour le téléphone et cert compatible... Ok Téléphones KEY ID: 0816 RédactionCERT... Ok Vérification de l'étatCERT... Ok Redémarrage téléphone... Ok Fait avecSamsung Tool PRO v.28.7.2 |
07-16-2017, 15:37 | #18710 (permalink) |
Freak Poster Join Date: Mar 2017 Location: south africa
Member: 2696842 Status: Offline Sonork: 100.1683002 Thanks Meter: 296 | plz tell me why help files not showing but old models showing new latest models helps files not showing plz tell me z3x team ?? |
07-16-2017, 17:58 | #18711 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | G935f frp done via uart Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM6 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G935F) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.28.8 |
The Following User Says Thank You to rai14 For This Useful Post: |
07-16-2017, 21:10 | #18712 (permalink) | |
Junior Member Join Date: May 2015
Member: 2401771 Status: Offline Thanks Meter: 0 | SM-G930W8 Successful Unlock! Quote:
07-17-2017, 03:05 | #18713 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Canada
Member: 119464 Status: Offline Thanks Meter: 288 | G930W8 Frp reset. Code: Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM6 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G930W8) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.28.8.1 |
07-17-2017, 09:17 | #18714 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | erite cert done n910cq BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-N910C Software version: 28.2 Checking CERT file... Ok KEY ID: 0065 Waiting ADB device... Ok Reading phone info... Model: SM-N910C Android version: 6.0.1 Product code: SM-N910CZKETUR Phone version: N910CXXU1DPI1 PDA version: N910CXXS2DQF4 CSC version: N910CQOJT2DPJ3 CSC country code: TURKEY CSC sales code: TUR HW version: MP 0.800 Phone SN: RF8GC0XX5CN Modem board: DB7450R Security patch: 2017-06-01 RF cal date: 2015.12.16 IMEI: Checking Super user right... true Reading NV data... Ok Analyzing NV data... Ok Writing NV Data... Ok Rebooting phone... Ok Waiting ADB device... Ok Reading phone info... Model: SM-N910C Android version: 6.0.1 Product code: SM-N910CZKETUR Phone version: N910CXXU1DPI1 PDA version: N910CXXS2DQF4 CSC version: N910CQOJT2DPJ3 CSC country code: TURKEY CSC sales code: TUR HW version: MP 0.800 Phone SN: RF8GC0XX5CN Modem board: DB7450R Security patch: 2017-06-01 RF cal date: 2015.12.16 IMEI: Writing AT RIL... Ok Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... Ok Bypass MSL... Ok Checking for compatible phone and cert... Ok Phone KEY ID: 0065 Writing CERT... Ok Checking CERT status... Ok Rebooting phone... Ok Write CERT done Done with Samsung Tool PRO v.28.2 |
07-17-2017, 09:28 | #18715 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | write cert done g900fq BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-G900F Selected port: COM330 SAMSUNG Mobile USB Serial Port Software version: 28.2 Checking CERT file... Ok KEY ID: 0478 Waiting ADB device... Ok Reading phone info... Model: SM-G900FQ Android version: 5.0 Product code: SM-G900FZWATUR Phone version: G900FXXU1BOE5 PDA version: G900FQJVU1BOJ1 CSC version: G900FQTUR1BOF1 CSC country code: TURKEY CSC sales code: TUR HW version: MP 0.800 Phone SN: R58F70MNS7B Modem board: MSM8974PRO RF cal date: 2014.03.26 IMEI: Incorrect model selected. This may damage your phone. Continue? Yes Writing AT RIL... Ok Initialization AT RIL... Ok Bypass MSL... Ok Checking for compatible phone and cert... Ok Phone KEY ID: 0478 Writing CERT... Ok Checking CERT status... Ok Rebooting phone... Ok Done with Samsung Tool PRO v.28.2 |
07-17-2017, 11:56 | #18716 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | Searching Samsung modem... detected COM207 Reading phone info... OK Model: SM-G925A AP version: G925AUCS5DPK2 CSC version: G925AATT5DPK2 CP version: G925AUCU5API1 Product code: SM-G925AZWAATT Phone SN: R38G60FPSHD Unique number: 05157DF54DE5DA39 Reading IMEI... OK IMEI: 3579420615xxxxxxx (SIGN: OK) Checking hash file... OK Reading data from phone... OK HWID: 88 4D B6 B4 D5 04 00 00 00 00 00 00 00 00 00 00 Modem board: SHANNON333 Please wait, calculating codes... OK (time - 00:00:04) Freeze code: 69606136 NET lock: 28075383 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.8 |
07-17-2017, 13:30 | #18717 (permalink) |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | g935a unlocked Operation: Read Codes via Server Selected model: SM-G935A Selected port: COM210 SAMSUNG Mobile USB Serial Port Software version: 28.8 Checking Login and Password... OK Ballance: 50 crd. Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SAMSUNG-SM-G935A Android version: 6.0.1 Product code: SM-G935AZKAATT Phone version: G935AUCS4APK1 PDA version: G935AUCS4APK1 CSC version: G935AATT4APK1 CSC country code: USA CSC sales code: ATT HW version: REV0.7 Phone SN: R38H5051V7V Chip name: MSM8996 Modem board: MSM8996 Security patch: 2016-11-01 RF cal date: 2016.05.05 IMEI: Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM83 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 75863046 NET lock: 47297257 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.8 |
07-18-2017, 09:51 | #18718 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Sri Lanka Age: 35
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Reset FRP Selected model: SM-J710F Software version: 28.8 Waiting ADB device... OK Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: SM-J710FZDUSLK Phone version: J710FXXU2AQA2 PDA version: J710FXXU2AQA3 CSC version: J710FODD2AQA1 CSC country code: Sri Lanka CSC sales code: SLK HW version: MP 0.400 Phone SN: RF8HB3ABV6Y Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-01-01 RF cal date: 20161125 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.8 |
07-18-2017, 09:52 | #18719 (permalink) |
07-18-2017, 11:22 | #18720 (permalink) |
Freak Poster Join Date: Oct 2015
Member: 2478777 Status: Offline Sonork: 1669951 Thanks Meter: 103 | SM-N920T T-Mobile Repair Operation: Repair Selected model: SM-N920T Software version: 28.8 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-N920T Android version: 6.0.1 Product code: SM-N920TZDATMB Phone version: N920TUVU4DQC2 PDA version: N920TUVU4DQC2 CSC version: N920TTMB4DQC2 CSC country code: USA CSC sales code: TMB HW version: REV0.2 Phone SN: RF8GA2J83SB Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-01-01 RF cal date: 20151028 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: C8 29 7A 74 D4 07 00 00 00 00 00 00 00 00 00 00 Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.28.8 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
