10-27-2010, 07:33 | #1936 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Mongolia
Member: 444532 Status: Offline Sonork: 100.1576960 Thanks Meter: 214 | Selected model: C3300K Selected com port: COM52 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 106 second, sw ver: 3.4.0068 |
The Following User Says Thank You to shuric For This Useful Post: |
10-27-2010, 09:10 | #1937 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Romania
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | E570 E570 succesfully read codes and direct unlock. Thank you Z3X Team. BR. Selected model: E570 Selected com port: COM29 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK SW: E570XFGD2 Langpack: Bulgaria, Croatia, Romania IMEI: 35299701xxxxxx S/N: R8WP470057 HW-> MP 1.200 Phone password: 00000000 Bluetooth ID: 001b98-95d2d4 Status OTP: OTP not present MSL DEACTIVATED - TRUE Locks is active [NETLOCK]: Use #0111*47745418# for deactivate this lock [SIMLOCK]: Use #0141*00000000# for deactivate this lock Read info - ok Elapsed time: 12 second, sw ver: 3.4.0068 ------------------------------------------------------------------------------- Selected model: E570 Selected com port: COM29 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: E570XFGD2 IMEI: 352997015xxxxxx MSL DEACTIVATED - TRUE NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 12 second, sw ver: 3.4.0068 |
The Following User Says Thank You to danrachita For This Useful Post: |
10-27-2010, 09:22 | #1938 (permalink) |
Insane Poster Join Date: Oct 2009
Member: 1137783 Status: Offline Thanks Meter: 45 | Galaxy i9000 unlock done with z3x! Searching Android modem... detected (COM19) Model: GT-I9000 SW: I9000NEJG1 IMEI: 35175104756218/9 CountryCode: ¿µ±¹ Factory SW: I9000NEJG3 UniqueNumber: 74160001868905 MemoryPhone: KB100D00WM(I9000) Reading Data from phone... OK MCK: 58075737 NET lock: 19285130 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung 3G tool ver 8.4 br |
The Following User Says Thank You to Arshad Ahmad For This Useful Post: |
10-27-2010, 16:00 | #1939 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Germany
Member: 753732 Status: Offline Thanks Meter: 252 | i9000 unlock ok Code: --------------------------- No answer from phone Done with Samsung 3G tool ver 8.4 Searching Samsung USB interface... detected (COM12) Model: GT-I9000 SW: I9000AUJF1 IMEI: 35175104255175/7 Done with Samsung 3G tool ver 8.4 Searching Android modem... detected (COM12) Model: GT-I9000 SW: I9000AUJF1 IMEI: 35175104255175/7 CountryCode: À¯·´ Factory SW: XXJF3_MOBJF6 UniqueNumber: 74200001752399 MemoryPhone: KB100D00WM(I9000) Reading Data from phone... OK MCK: 75151604 NET lock: 31386479 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung 3G tool ver 8.4 |
The Following User Says Thank You to powerplay83 For This Useful Post: |
10-27-2010, 16:40 | #1940 (permalink) |
Freak Poster Join Date: Dec 2009 Location: beside gsm world
Member: 1178779 Status: Offline Thanks Meter: 18 | c3510 read codes & unlock done......... Selected model: C3510 Selected com port: COM24 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Phone IMEI -> 35865103367687 Phone SW -> C3510CWAMID Langpack-> Not found langpack ! Phone HW -> Phone BT ADDR -> Phone WI-FI ADDR -> Read Info - ok Elapsed time: 81 second, sw ver: 3.4.0062 ------------------------------------------------------------------------------- Selected model: C3510 Selected com port: COM24 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 129 second, sw ver: 3.4.0062 ------------------------------------------------------------------------------- |
The Following User Says Thank You to jigs69 For This Useful Post: |
10-27-2010, 16:58 | #1941 (permalink) |
Freak Poster Join Date: Sep 2006 Location: medellin colombia
Member: 350892 Status: Offline Thanks Meter: 40 | T749 unlock ok 100%test Model: SGH-T749 CountryCode: TMB Factory SW: UVIF3 UniqueNumber: 60550000241211 MemoryPhone: K5R2G1GACC(T749)S IMEI: 35249403037352/5 Phone S/N: R6WS635713 Build: M6290A-KPVZL-1.2.0080T Reading SysInfo... error (Cant read Security data) Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:00:44) Freeze code: 79362717 NET lock: #7465625*638*68273617# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# |
The Following User Says Thank You to juanguirre For This Useful Post: |
10-27-2010, 19:03 | #1942 (permalink) |
No Life Poster Join Date: Feb 2010 Location: Ghana
Member: 1230787 Status: Offline Thanks Meter: 96 | s3100 successfully unlocked. Selected model: S3100 Selected com port: COM8 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Unlock - ok Elapsed time: 28 second, sw ver: 3.4.0068 ------------------------------------------------------------ |
The Following User Says Thank You to lloydgsm For This Useful Post: |
10-28-2010, 05:02 | #1943 (permalink) |
Banned Join Date: Feb 2008 Location: GSM Nowshera
Member: 713374 Status: Offline Sonork: 100.1597179 Thanks Meter: 223 | Selected model: S5230 Selected com port: COM15 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM10 Phone IMEI: 35856903371643 /4 Phone S/N: R1YZ125943 Detecting UART port..... OK Repower phone - please wait Phone must be ON Search modem ... OK Search modem on:COM10 Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 64 second, sw ver: 3.4.0068 |
The Following User Says Thank You to xim360 For This Useful Post: |
10-28-2010, 05:03 | #1944 (permalink) |
Member: 713374 Status: Offline Sonork: 100.1597179 Thanks Meter: 223 | Selected model: S5230 Selected com port: COM15 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM51 Phone IMEI: 35856903382275 /2 Phone S/N: R1YZ190505 Detecting UART port..... OK Repower phone - please wait Phone must be ON Search modem ... OK Search modem on:COM10 Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 49 second, sw ver: 3.4.0068 |
10-28-2010, 06:46 | #1945 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | Selected model: E2121B Selected com port: COM2 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Phone IMEI -> 35980103334348 Phone SW -> Langpack-> Not found langpack ! Phone HW -> Phone BT ADDR -> Phone WI-FI ADDR -> Read Info - ok Elapsed time: 30 second, sw ver: 3.4.0068 ------------------------------------------------------------------------------- Selected model: E2121B Selected com port: COM2 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 56 second, sw ver: 3.4.0068 |
The Following User Says Thank You to worldlinkmobil For This Useful Post: |
10-28-2010, 09:57 | #1946 (permalink) |
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | E1310b E1310B succesfully read codes and direct unlock. Thank you Z3X Team. BR. Selected model: E1310B Selected com port: COM29 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35423703xxxxxx Phone SW: E1310BAMIE1 Phone BT ADDR: A007-98-3EE77B Phone SN: RPCSA37609 Deactivated MSL - TRUE [FREZEE]: 92496920 [NET Lock]: 08494640 [Subset Lock]: 08494640 [SP Lock]: 08494640 [CP Lock]: 00000000 [Sim Lock]: 00000000 Read info - ok Elapsed time: 14 second, sw ver: 3.4.0068 ------------------------------------------------------------------------------- Selected model: E1310B Selected com port: COM29 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 354237034xxxxxx Phone SW: E1310BAMIE1 Phone BT ADDR: A007-98-3EE77B Phone SN: RPCSA37609 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 22 second, sw ver: 3.4.0068 |
10-28-2010, 10:26 | #1947 (permalink) |
No Life Poster Join Date: Dec 2005 Location: India
Member: 213808 Status: Offline Sonork: 100.1615441 Thanks Meter: 126 | elected model: C6625 Selected com port: COM5 Selected speed port: 921600 Power On phone Press on phone keyboard code *#0228# Press Back and press 2 key Select UART-CP and connect phone on cable Phone detected [SOFTWARE]:C6625JCIC3 [Unique number]:60030000512657 [IMEI]:359757020522928 [Serial number]:S100017028 Start Bruteforce Msl code detected: 521750 Unlock - ok Elapsed time: 8859 second, sw ver: 3.4.0068 |
The Following User Says Thank You to drbilal For This Useful Post: |
10-28-2010, 10:28 | #1948 (permalink) |
Member: 213808 Status: Offline Sonork: 100.1615441 Thanks Meter: 126 | Model: GT-S7330 CountryCode: ETL Factory SW: S7330CYHG1_HH2 UniqueNumber: 70590000373513 MemoryPhone: K5D1G13DCA(S7330) IMEI: 35452202158427/6 Phone S/N: R8WQB77764 Build: M6260A-KYRZ-2.5.1032_5S Reading SysInfo... OK Calculating... OK Calculating codes... OK (time - 00:00:38) Freeze code: 91419574 NET lock: #7465625*638*15364909# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 8.4 |
10-28-2010, 10:53 | #1949 (permalink) |
No Life Poster Join Date: Oct 2007 Age: 39
Member: 602830 Status: Offline Thanks Meter: 283 | Count supported models - 214 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 8.6 Searching Samsung USB interface... not found ----------------------------- Model: SGH-F406 CountryCode: RWC Factory SW: UXHJ3 UniqueNumber: 70350000901552 MemoryPhone: TY9000A800O(F406) IMEI: 35524802016843/7 Phone S/N: R1YSB30543 Build: M6280A-KLRZ-4.0.9535_3S Done with Samsung 3G tool ver 8.6 ----------------------------- Model: SGH-F406 CountryCode: RWC Factory SW: UXHJ3 UniqueNumber: 70350000901552 MemoryPhone: TY9000A800O(F406) IMEI: 35524802016843/7 Phone S/N: R1YSB30543 Build: M6280A-KLRZ-4.0.9535_3S Reading SysInfo... OK Calculating... OK Searching Samsung USB interface... not found Unlocking... OK (time - 00:00:02) Done with Samsung 3G tool ver 8.6 |
The Following User Says Thank You to gagan_o5 For This Useful Post: |
10-28-2010, 11:37 | #1950 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | [B]SAMASUNG SG E2120 READ CODE DONE!!![ Selected model: E2120 Selected com port: COM146 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Phone IMEI -> 35492703518782 Phone SW -> Langpack-> Not found langpack ! Phone HW -> Phone BT ADDR -> Phone WI-FI ADDR -> [NET LOCK]:88253500,88253500,88253500,88253500, [SIM LOCK]:00000000,00000000,00000000,00000000, [PHONE LOCK]:00000000,00000000,00000000,00000000, [SP LOCK]:00000000,00000000,00000000,00000000, Read Info - ok Elapsed time: 75 second, sw ver: 3.4.0068 ------------------------------------------------------------------------------- Selected model: E2120 Selected com port: COM146 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Phone IMEI -> 35166404354160 Phone SW -> Langpack-> Not found langpack ! Phone HW -> Phone BT ADDR -> Phone WI-FI ADDR -> [NET LOCK]:54050610,54050610,54050610,54050610, [SIM LOCK]:00000000,00000000,00000000,00000000, [PHONE LOCK]:00000000,00000000,00000000,00000000, [SP LOCK]:00000000,00000000,00000000,00000000, Read Info - ok Elapsed time: 63 second, sw ver: 3.4.0068 ------------------------------------------------------------------------------- |
The Following User Says Thank You to fokal2008 For This Useful Post: |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
