10-30-2010, 15:02 | #1981 (permalink) |
No Life Poster Join Date: Oct 2005 Location: dreams
Member: 188445 Status: Offline Thanks Meter: 86 | Model: SGH-T469W CountryCode: GLW Factory SW: UQIK5 UniqueNumber: 55440000316873 MemoryPhone: K5R2G1GACC(T469)S IMEI: 35862403017747/6 Phone S/N: RPCZ176630 Build: M6246A-KPVZL-1.2.0035 Reading SysInfo... OK Calculating... error Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:00:44) Freeze code: 75253525 NET lock: #7465625*638*30962794# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# |
10-30-2010, 15:04 | #1982 (permalink) |
Member: 188445 Status: Offline Thanks Meter: 86 | another T469W unlock successful Model: SGH-T469W CountryCode: GLW Factory SW: UQIK5 UniqueNumber: 55320001159399 MemoryPhone: K5R2G1GACC(T469)S IMEI: 35862403026657/6 Phone S/N: RQOZ149616 Build: M6246A-KPVZL-1.2.0035 Reading SysInfo... OK Calculating... error Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:00:11) Freeze code: 05170708 NET lock: #7465625*638*20626820# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# |
10-30-2010, 15:04 | #1983 (permalink) |
Member: 188445 Status: Offline Thanks Meter: 86 | l760v unlock successful unlock Model: SGH-L760V CountryCode: ATL Factory SW: L760BUGH1 UniqueNumber: 74300000124030 MemoryPhone: K5D1G13DCM IMEI: 35660301471146/0 Phone S/N: R8UQ269568 Build: M6260A-KYRZ-2.1.300605T Reading SysInfo... OK Calculating... OK Searching Samsung USB interface... detected (COM79) Model: SGH-L760V SW: L760BUGH1 IMEI: 35660301471146/0 Bypass MSL... OK Unlocking... OK (time - 00:00:09) Done with Samsung 3G tool ver 8.4 |
10-30-2010, 15:06 | #1984 (permalink) |
Member: 188445 Status: Offline Thanks Meter: 86 | s3370 successful unlock Model: GT-S3370 CountryCode: YOG Factory SW: S3370REJE2_YOGJE3 UniqueNumber: 80980001027548 MemoryPhone: K522H1HACC(S3370)S IMEI: 35267304503170/3 Phone S/N: RVRZ817835 Build: Q6270B-KPVZL-1.5.55011ST Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:00:57) Freeze code: 86306314 NET lock: #7465625*638*19585202# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*00000000# |
10-30-2010, 15:09 | #1985 (permalink) |
Member: 188445 Status: Offline Thanks Meter: 86 | s8300 successful unlock Model: GT-S8300 CountryCode: ORA Factory SW: S8300BVIE1 UniqueNumber: 74080001330522 MemoryPhone: K5R2G1GACC(S8300)S IMEI: 35275103012322/0 Phone S/N: R8XS717988 Build: M6281A-KLRZR-4.0.9640 Reading SysInfo... error (Cant read Security data) Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:00:27) Freeze code: 48240374 NET lock: #7465625*638*16971580# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# SIM lock: #7465625*746*12369874# |
10-30-2010, 15:19 | #1986 (permalink) |
Member: 188445 Status: Offline Thanks Meter: 86 | s8000 flash+unlock Model: S8000 Version: S8000XEIG2 Info: Patched for unlock Searching Samsung USB Flash interface... detected (COM98) Sending file 1 of 5... sended Sending file 2 of 5... sended Sending file 3 of 5... sended Sending file 4 of 5... sended Sending last file... sended Flashing done (time - 00:04:10) Model: S8000 SW: S8000XEIG2 IMEI: 35202803584079/7 Unlocking... OK |
10-30-2010, 16:57 | #1987 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Selected model: E250D Selected com port: COM12 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use manual parameters Phone in TAT MODE Phone IMEI: 35xxxxxxxxxxxxx Phone SW: E250DJPHA2 Phone BT ADDR: 001F-CD-2CBA29 Phone SN: R3XQ532061 Deactivated MSL - TRUE Write imei - ok Repair - ok Elapsed time: 15 second, sw ver: 3.4.0068 ------------------------------------------------------------------------------- |
10-30-2010, 22:58 | #1988 (permalink) |
Junior Member Join Date: Jul 2009 Location: cuba
Member: 1080668 Status: Offline Thanks Meter: 4 | a687 tested 100% select a797 model press 1 and 0 key and conect usb cable -------------------------------------------------------------------- Count supported models - 214 Press 1 + message key and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.6 Press 1 + message key and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.6 Press 1 + message key and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&358ab8a0&0&2# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:00:39) Freeze code: 53925904 NET lock: #7465625*638*86425725# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 8.6 |
10-31-2010, 03:36 | #1989 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | e2110i restart solved Selected model: E2120 Selected com port: COM11 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Erase - ok Elapsed time: 108 second, sw ver: 3.4.0069 ------------------------------------------------------------------------------- Selected model: E2120 Selected com port: COM11 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Start NOR flash NOR flash - ok Download - ok Elapsed time: 1072 second, sw ver: 3.4.0069 |
10-31-2010, 04:05 | #1990 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | s3310 flesh done Selected model: S3310 Selected com port: COM11 Selected speed port: 921600 Please, connect phone and press shortly power button Detect broadcom2... OK Switching to boot mode... OK Erase NAND - start Erase NAND - ok Send IMG NAND ... Send IMG - ok Send IMG NAND ... Send IMG - ok Send IMG NAND ... Send IMG - ok Send TFS ... Send TFS - ok Download - ok Elapsed time: 985 second, sw ver: 3.4.0069 |
10-31-2010, 09:04 | #1991 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | s3310 flesh done -------------------------------------------------------------------------------- Selected model: S3310 Selected com port: COM11 Selected speed port: 921600 Please, connect phone and press shortly power button Detect broadcom2... OK Switching to boot mode... OK Erase NAND - start Erase NAND - ok Send IMG NAND ... Send IMG - ok Send IMG NAND ... Send IMG - ok Send IMG NAND ... Send IMG - ok Send TFS ... Send TFS - ok Download - ok Elapsed time: 985 second, sw ver: 3.4.0069 thank mr joni /////////////////////// |
10-31-2010, 11:58 | #1994 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | Sam c5130s flash successfully Selected model: C5130S Selected com port: COM11 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader... OK Start erase all part... OK Sending part-1... OK Sending part-2... OK Sending part-3... OK Sending part-4... OK Sending part-5... OK Sending part-6... OK Sending part-7... OK Sending part-10... OK Start erase boot nand... Sending boot... OK Download - ok Elapsed time: 1556 second, sw ver: 3.4.0068 ------------------------------------------------------------------------------- |
10-31-2010, 19:05 | #1995 (permalink) |
Freak Poster Join Date: Dec 2009 Location: beside gsm world
Member: 1178779 Status: Offline Thanks Meter: 18 | s5233a unlock done..... ------------------------------------------------------------------------------- Selected model: S5233 Selected com port: COM24 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM26 Phone IMEI: 35427203075534 /9 Phone S/N: R1YS704034 Detecting UART port..... OK Repower phone - please wait Reconnect cable on phone for init modem Search modem ... OK Search modem on:COM11 Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 82 second, sw ver: 3.4.0062 ------------------------------------------------------------------------------- |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
