11-07-2010, 08:48 | #2041 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | M310 unlock ok Selected com port: COM10 Selected speed port: 921600 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: M310XXHL2 IMEI: 35713202095164 MSL DEACTIVATED - TRUE NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 22 second, sw ver: 3.4.0071 |
The Following User Says Thank You to naveedbutt For This Useful Post: |
11-07-2010, 09:15 | #2043 (permalink) |
Freak Poster Join Date: Apr 2010 Location: Asia
Member: 1286135 Status: Offline Thanks Meter: 221 | Samsung E1360B unlock done Selected model: E1360B Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35191303XXXXXX Phone SW: E1360BBVID1 Phone BT ADDR: 60D0-A9-BBCF43 Phone SN: RQMS934463 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 18 second, sw ver: 3.4.0069 ------------------------------------------------------------------------------- |
The Following User Says Thank You to sinned For This Useful Post: |
11-07-2010, 14:25 | #2044 (permalink) |
No Life Poster Join Date: Oct 2005 Location: BISKRA Age: 55
Member: 192230 Status: Offline Thanks Meter: 106 | hi ......................... Model: SGH-F480V CountryCode: MOB Factory SW: F480AUGE5 UniqueNumber: 60110000211656 MemoryPhone: KBN00700AM(F480) Phone S/N: R2YQ809258 Build: M6281A-KLRZ-4.0.9535 Reading SysInfo... OK Calculating... OK Calculating codes... OK (time - 00:00:46) Freeze code: 36039715 NET lock: #7465625*638*71391494# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# SIM lock: #7465625*746*12369874# For check lock status: *#7465625# Done with Samsung 3G tool ver 8.5 br louai |
The Following User Says Thank You to LOUAI2005 For This Useful Post: |
11-07-2010, 17:27 | #2045 (permalink) |
Freak Poster Join Date: Dec 2009 Location: beside gsm world
Member: 1178779 Status: Offline Thanks Meter: 18 | c3053 unlock done.... ------------------------------------------------------------------------------- Selected model: C3053 Selected com port: COM24 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: C3053DXIF1 IMEI: 35381603395114 MSL DEACTIVATED - TRUE NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 17 second, sw ver: 3.4.0062 ------------------------------------------------------------------------------- |
The Following User Says Thank You to jigs69 For This Useful Post: |
11-07-2010, 18:45 | #2046 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Birmingham U.K
Member: 251421 Status: Offline Sonork: 100.1609329 Thanks Meter: 439 | Selected model: B3310 Selected com port: COM75 Selected speed port: USB Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: B3310XXII1 IMEI: 359144038xxxxxxxxxx MSL DEACTIVATED - TRUE Set default customer - fail NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 28 second, sw ver: 3.4.0066 ------------------------------------------------------------------------------- |
The Following User Says Thank You to malikzahidawan For This Useful Post: |
11-07-2010, 18:46 | #2047 (permalink) |
Member: 251421 Status: Offline Sonork: 100.1609329 Thanks Meter: 439 | Selected model: E1170 Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 06 Sending loader2... OK Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 90 second, sw ver: 3.4.0066 |
11-07-2010, 18:57 | #2048 (permalink) |
Member: 251421 Status: Offline Sonork: 100.1609329 Thanks Meter: 439 | Selected model: E1360B Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35191303496691 Phone SW: E1360BBVID1 Phone BT ADDR: 60D0-A9-B99D39 Phone SN: RQKS978837 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 29 second, sw ver: 3.4.0066 |
11-07-2010, 19:38 | #2049 (permalink) |
Member: 251421 Status: Offline Sonork: 100.1609329 Thanks Meter: 439 | Count supported models - 208 Reading file... OK Model: S8000 Version: S8000XEIG2 Info: Patched for unlock Searching Samsung USB Flash interface... detected (COM20) Sending file 1 of 5... sended Sending file 2 of 5... sended Sending file 3 of 5... sended Sending file 4 of 5... sended Sending last file... sended Flashing done (time - 00:04:27) ----------------------------- Searching Samsung USB interface... detected (COM20) Model: S8000 SW: S8000XEIG2 IMEI: 35202803248041/5 Unlocking... OK |
11-08-2010, 11:37 | #2050 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | Model: GT-S8300V CountryCode: VOD Factory SW: S8300BUIC6 UniqueNumber: 74240000959935 MemoryPhone: K5R2G1GACC(S8300)S IMEI: 35998402067606/2 Phone S/N: R5VS348430 Build: M6281A-KLRZR-4.0.9640 Reading SysInfo... error (Cant read Security data) Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:00:44) Freeze code: 37939360 NET lock: #7465625*638*57391571# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# SIM lock: #7465625*746*12369874# For check lock status: *#7465625# Done with Samsung 3G tool ver 8.6 |
11-08-2010, 11:38 | #2051 (permalink) |
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | Selected model: J700I Selected com port: COM15 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35770003286476 Phone SW: J700IBUIE2 Phone BT ADDR: A007-98-323862 Phone SN: RP2SA52211 Deactivated MSL - TRUE [FREZEE]: 36604330 [NET Lock]: 37054300 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00000000 Read info - ok Elapsed time: 11 second, sw ver: 3.4.0066 |
11-08-2010, 12:06 | #2052 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Mumbai--Great INDIA
Member: 665441 Status: Offline Sonork: 100.1670531 Thanks Meter: 603 | Selected model: S3650 Selected com port: COM5 Selected speed port: 921600 Connect phone and press power on 10 second Start repair boot zone type 2... Unpress power button on phone ! Repair - boot ok Elapsed time: 24 second, sw ver: 3.4.0068 |
The Following User Says Thank You to hanif007 For This Useful Post: |
11-08-2010, 15:05 | #2053 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | Count supported models - 208 ----------------------------- Model: GT-I5801 CountryCode: ORA Factory SW: I5801BVJF4_ORAJF4 UniqueNumber: 76400000286888 MemoryPhone: KAC007021B(I5801) PDA/CSC version: I5801BVJF4/I5801ORAJF4 Phone version: I5801BVJF2 Phone HW: MP 1.000 IMEI: 35178404092375/1 Phone S/N: R3XZ773823 Build: Q6270B-KPRBL-1.5.55052ST Reading Security... OK Bypass MSL... OK Unlocking ... OK |
11-08-2010, 17:04 | #2054 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Tanzania Age: 62
Member: 22542 Status: Offline Sonork: 100.1660285 Thanks Meter: 102 | UNLOCKED E1105T USING OPTION FOR E1107T HERE ARE THE LOGS Selected model: E1107T Selected com port: COM16 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35258003271866 Phone SW: E1105TJVIC1 Phone BT ADDR: 0000-00-000000 Phone SN: RUCS553587 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 18 second, sw ver: 3.4.0068 ------------------------------------------------------------------------------- |
11-08-2010, 17:07 | #2055 (permalink) |
Member: 22542 Status: Offline Sonork: 100.1660285 Thanks Meter: 102 | UNLOCKED S3650 HERE ARE THE LOGS Selected model: S3650 Selected com port: COM16 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM10 Phone IMEI: 35856803730450 /2 Phone S/N: R6XZ117135 Detecting UART port..... OK Repower phone - please wait Reconnect cable on phone for init modem Search modem ... OK Search modem on:COM10 Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 49 second, sw ver: 3.4.0068 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
