01-28-2011, 09:11 | #796 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | andrew_tm 2010(c) supported models: 198 Selected model: KP170 Selected port: COM2 Selected speed: 921600 Please press and hold power button! Phone detected! Loader startup Ok.. Reading phone info... Flash ID: 01223C Flash type: S29PL129N Flash size: 32Mb Read eeprom... Code #0: 45781837 Code #1: 04997904 Code #2: 60406971 Code #3: 59377591 Code #4: 15686560 For enter unlock code: 1. With sim type: 2945#*71001# or 2945#*70001# 2. Goto Menu->Setting->Secutiry->Sim Locked->Sim Unlock Code 3. Desactivate and enter code Elapsed: 7 secs. |
The Following User Says Thank You to worldlinkmobil For This Useful Post: |
01-28-2011, 09:12 | #797 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Welcome to LG Infineon SGOLD3 TOOL v2x by NoName® Models count: 80 Current OS : Windows XP Welcome to Sgold3 Module!! Count supported models - 80 ***Disconnected*** TIP: Please reconnect phone battery / power source. Loading module , please wait... PMB8877 Module 1.21 started. SW: Ver 2.2.8.0 Connecting to GS290 in UART Mode (COM2 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8877) prebooting... Release power button. Booting... Reading info... BOOT Stage Finished , sending authority... Sending SEC pack... Reading EEPROM... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\GS290_autobackup_27122 010_141502.eep Analising EEPROM... Phone IMEI:353543046534444 Unlock codes: NCK[0]: 7824785359800862 (LOCKED) TIP: For additional codes , select Read Codes option and click Unlock button Finished in 3 seconds |
01-28-2011, 09:12 | #798 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Selected model: GB102 Selected port: COM2 Selected speed: 921600 Connect phone and press Power ON! Connect error! Selected model: GB102 Selected port: COM2 Selected speed: 921600 Connect phone and press Power ON! Connect ok! Send preloader ok! Send main loader ok! Change BaudRate done! FlashId: 22F6007F, flash size: 4Mb IMEI: 353477-04-052347-7 NCK Code: 55737757 SIM Lock enabled: Yes SIM Code Protection enabled: Yes IMEI Protection enabled: Yes Start unlock... Unlock code: 55737757 For enter unlock code: 1. Without sim type: *#9999# 2. Type: 2945#*20001# 3. Goto Menu->Setting->Secutiry->Sim Locked->Sim Unlock Code 4. Desactivate and enter code:55737757 |
01-28-2011, 12:18 | #799 (permalink) |
No Life Poster Join Date: Jun 2009 Location: Abcyz.
Member: 1055074 Status: Offline Thanks Meter: 7,096 | lg gs290 done TIP: Please reconnect phone battery / power source. Loading module , please wait... PMB8877 Module 1.31 started. SW: Ver 2.2.9.0 Connecting to GS290 in UART Mode (COM77 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8877) prebooting... Release power button. Booting... Reading info... BOOT Stage Finished , sending authority... Sending SEC pack... Reading EEPROM... Backup Saved AS:C:\Archivos de programa\Z3X\LG\LGI_SG3\BACKUP\GS290_autobackup_28 012011_121051.eep Analising EEPROM... Phone IMEI:353543045617075 Unlock codes: NCK[0]: 5562357255022487 (LOCKED) TIP: For additional codes , select Read Codes option and click Unlock button Finished in 3 seconds ***Disconnected*** TIP: Please reconnect phone battery / power source. |
01-29-2011, 09:10 | #805 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Mode: Normal Model: U310 Build version: Oct 12 200614:55:37MAY 09 200617:00:00U310 SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT IMEI: 35281801283962-6 BlueTooth Address: 00:19:A1:68:FD:3A Flash Name: toshiba_ty90009800cogg Flash Info: 0900/0020/0200 Elapsed: 0 secs. --> (v.2.1.0) Reading file as U310... Ok Patch Flash File: U310-TRINITYR-V10a-OCT-12-2006-H3G-LATIN_OFF_SEC Lang(ver 1.0): -Russian -Ukrainian Mode: Normal Model: U310 Build version: Oct 12 200614:55:37MAY 09 200617:00:00U310 SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT IMEI: 35281801283962-6 BlueTooth Address: 00:19:A1:68:FD:3A Flash Name: toshiba_ty90009800cogg Flash Info: 0900/0020/0200 Elapsed: 0 secs. --> (v.2.1.0) NV read... NV save:..\backup\U310_352818012839626_29012011_12144 9.cnv Elapsed: 9 secs. --> (v.2.1.0) Start Flash... Modem Write Start... Flash Verify Done. EFS Erase Done. Modem Write Done. Phone Reboot. Phone Detected! Write NV... EFS Write Start... Start Write Media... Start Write Module... EFS Write Done. Flash Done. Elapsed: 477 secs. --> (v.2.1.0) Mode: Normal Model: U310 Build version: Jan 23 200717:32:09MAY 09 200617:00:00U310 SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT IMEI: 35281801283962-6 BlueTooth Address: 00:19:A1:68:FD:3A Flash Name: toshiba_ty90009800cogg Flash Info: 0900/0020/0200 Elapsed: 0 secs. --> (v.2.1.0) Mode: Normal Model: U310 Build version: Jan 23 200717:32:09MAY 09 200617:00:00U310 SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT IMEI: 35281801283962-6 BlueTooth Address: 00:19:A1:68:FD:3A Flash Name: toshiba_ty90009800cogg Flash Info: 0900/0020/0200 Elapsed: 0 secs. --> (v.2.1.0) Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port:COM29 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... Unlock done! Phone reboot! Elapsed: 90 secs. --> (v.2.1.0) |
01-29-2011, 12:29 | #806 (permalink) |
No Life Poster Join Date: May 2006 Location: punjab
Member: 271008 Status: Offline Thanks Meter: 280 | ks360 unlock Loading module , please wait... PMB8888 Module 1.1 started. SW: Ver 2.2.8.0 Connecting to KS360 in UART Mode (COM10 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8888) prebooting... Release power button. Booting... Reading info... Flash ID: 0000 BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\KS360_autobackup_29012 011_164703.eep Analising EEPROM... Phone IMEI:354995031759213 Unlock codes: NCK[0]: 56218245 (LOCKED) TIP: For additional codes , select Read Codes option and click Unlock button Finished in 7 seconds ***Disconnected*** TIP: Please reconnect phone battery / power source. Loading module , please wait... PMB8888 Module 1.1 started. SW: Ver 2.2.8.0 Connecting to KS360 in UART Mode (COM10 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8888) prebooting... Release power button. Booting... Reading info... Flash ID: 0000 BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\KS360_autobackup_29012 011_165036.eep Analising EEPROM... Phone IMEI:354995031759213 Unlock codes: NCK[0]: 56218245 (LOCKED) TIP: For additional codes , select Read Codes option and click Unlock button Finished in 7 seconds Reading codes... Sending SEC pack... Reading ... Analising EEPROM... Phone IMEI:354995031759213 For operation finishing,do next : 1. power phone ON with original SIM 2. type 2945#*71001# to enter unlock menu 3. Enter one of this code(s): NCK[0]: 56218245 (LOCKED) Security block not found Finished in 7 seconds |
01-29-2011, 12:39 | #807 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Mauritius Port Louis
Member: 762522 Status: Offline Thanks Meter: 156 | ku990 unlock done v.2.1.1a supported models: 161 andrew_tm 2010(c) Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 3 secs. --> (v.2.1.1a) Mode: Normal Model: KU990 Build version: Jul 07 200809:33:48APR 30 200817:00:00KU990 SW Version: KU990-MSM6280-V10g-APR-30-2008-XX IMEI: 35363802880988-3 BlueTooth Address: 00:1F:6B:F8:73:F8 Flash Name: toshiba_tya000bc00bogg Flash Info: 06C3/0040/0800 Elapsed: 0 secs. --> (v.2.1.1a) Send loader... Loader startup Ok! Init NAND Ok! Security backup saved to: C:\Program Files\Z3X\LG\LGQ\Backup\KU990_353638028809883_2901 2011_032736.sec Erase sec. zone... Write data to phone... Phone rebooted! Elapsed: 15 secs. --> (v.2.1.1a) |
01-30-2011, 08:53 | #809 (permalink) |
No Life Poster Join Date: Jul 2007 Location: In my body
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | Lg U990 Unlock Done.. Mode: Normal Model: U990 Build version: Aug 22 200810:37:09AUG 22 200817:00:00U990 SW Version: U990-MSM6280-V10d-AUG-22-2008-XX IMEI: 3599440000000-0 BlueTooth Address: 00:22:A9:290:2B Phone Code: default Flash Name: toshiba_tya000bc00bogg Flash Info: 06C3/0040/0800 Elapsed: 0 secs. --> (v.2.1.3) Send loader... Loader startup Ok! Init NAND Ok! Security backup saved to: C:\Program Files\Z3X\LG\LGQ\Backup\U990_359944022920520_30012 011_123432.sec Erase sec. zone... Write data to Phone.Qualcomm.. Phone rebooted! Elapsed: 28 secs. --> (v.2.1.3) |
The Following User Says Thank You to thushdt For This Useful Post: |
01-30-2011, 08:55 | #810 (permalink) | |
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | Lg U900 Unlock Done.. Quote:
Post here successfully job with Z3X-BOX Samsung (2010-2018) | mk | Z3X-Team Products | 21273 | 11-19-2018 09:21 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
