01-30-2011, 13:03 | #811 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: tuttotelefonia
Member: 125945 Status: Offline Thanks Meter: 495 | Quote:
if you have LG Qualcomm phone in Yellow screen, "UNAVAILABLE MEDIA FILE" or "LOGO START UP" or OTHER PROBLEM, to make this procedure: A) MAIN TABULATE> Put the Phone in EMERGENCY MODE (Type 2+5+Power on Key from phone Power OFF) can you use only the USB cable in the Packege connect to pc port direct or Hub port, B)Under the IMEI FIELD where now you see NVM, moove this and select what do u want to do, C) Click in the REPAIR button D) all Done, phone restored BR Max (ripgsm) | |
The Following 5 Users Say Thank You to .:Ripgsm:. For This Useful Post: |
01-30-2011, 18:50 | #812 (permalink) |
No Life Poster Join Date: Jun 2009 Location: Abcyz.
Member: 1055074 Status: Offline Thanks Meter: 7,096 | 2 lg gs101 ok. Connect phone and press Power ON! Connect ok! Send preloader ok! Send main loader Ok! Change BaudRate done! FlashId: 260600EC, flash size: 4Mb IMEI: 352231-04-263333-4 NCK Code: 8804 5660 9899 2601 Phone disconnected Selected model: GS101 Selected port: COM77 Selected speed: 115200 Connect phone and press Power ON! Connect ok! Send preloader ok! Send main loader Ok! Change BaudRate done! FlashId: 260600EC, flash size: 4Mb IMEI: 352231-04-983265-7 NCK Code: 3673 3325 4508 3303 Phone disconnected |
01-31-2011, 08:21 | #813 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | Mode: Normal Model: U310 Build version: Oct 12 200614:55:37MAY 09 200617:00:00U310 SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT IMEI: 35281801283962-6 BlueTooth Address: 00:19:A1:68:FD:3A Flash Name: toshiba_ty90009800cogg Flash Info: 0900/0020/0200 Elapsed: 0 secs. --> (v.2.1.0) Reading file as U310... Ok Patch Flash File: U310-TRINITYR-V10a-OCT-12-2006-H3G-LATIN_OFF_SEC Lang(ver 1.0): -Russian -Ukrainian Mode: Normal Model: U310 Build version: Oct 12 200614:55:37MAY 09 200617:00:00U310 SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT IMEI: 35281801283962-6 BlueTooth Address: 00:19:A1:68:FD:3A Flash Name: toshiba_ty90009800cogg Flash Info: 0900/0020/0200 Elapsed: 0 secs. --> (v.2.1.0) NV read... NV save:..\backup\U310_352818012839626_29012011_12144 9.cnv Elapsed: 9 secs. --> (v.2.1.0) Start Flash... Modem Write Start... Flash Verify Done. EFS Erase Done. Modem Write Done. Phone Reboot. Phone Detected! Write NV... EFS Write Start... Start Write Media... Start Write Module... EFS Write Done. Flash Done. Elapsed: 477 secs. --> (v.2.1.0) Mode: Normal Model: U310 Build version: Jan 23 200717:32:09MAY 09 200617:00:00U310 SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT IMEI: 35281801283962-6 BlueTooth Address: 00:19:A1:68:FD:3A Flash Name: toshiba_ty90009800cogg Flash Info: 0900/0020/0200 Elapsed: 0 secs. --> (v.2.1.0) Mode: Normal Model: U310 Build version: Jan 23 200717:32:09MAY 09 200617:00:00U310 SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT IMEI: 35281801283962-6 BlueTooth Address: 00:19:A1:68:FD:3A Flash Name: toshiba_ty90009800cogg Flash Info: 0900/0020/0200 Elapsed: 0 secs. --> (v.2.1.0) Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port:COM29 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... Unlock done! Phone reboot! Elapsed: 90 secs. --> (v.2.1.0) |
01-31-2011, 13:15 | #814 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Pandora
Member: 385139 Status: Offline Thanks Meter: 12 | gs290 unlock ok....here log Welcome to Sgold3 Module!! 31/01/2011 12:40:50 > Count supported models - 85 31/01/2011 12:41:01 > ***Disconnected*** 31/01/2011 12:41:01 > TIP: Please reconnect phone battery / power source. 31/01/2011 12:41:07 > Loading module , please wait... 31/01/2011 12:41:14 > PMB8877 Module 1.31 started. SW: Ver 2.2.9.0 31/01/2011 12:41:14 > Connecting to GS290 in UART Mode (COM3 ,921600) 31/01/2011 12:41:14 > Please reconnect battery, press and hold power button... 31/01/2011 12:41:24 > Phone found! (MCU:PMB8877) prebooting... 31/01/2011 12:41:24 > Release power button. Booting... 31/01/2011 12:41:34 > Reading info... 31/01/2011 12:41:36 > BOOT Stage Finished , sending authority... 31/01/2011 12:41:36 > Sending SEC pack... 31/01/2011 12:41:37 > Reading EEPROM... 31/01/2011 12:41:39 > Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\GS290_autobackup_31012 011_124139.eep 31/01/2011 12:41:39 > Analising EEPROM... 31/01/2011 12:41:39 > Phone IMEI:3592890346***** 31/01/2011 12:41:39 > Unlock codes: 31/01/2011 12:41:39 > NCK[0]: 2811382981593203 (LOCKED) 31/01/2011 12:41:39 > TIP: For additional codes , select Read Codes option and click Unlock button 31/01/2011 12:41:39 > Finished in 3 seconds 31/01/2011 12:41:48 > Unlocking... 31/01/2011 12:41:48 > Sending SEC pack... 31/01/2011 12:41:48 > Reading ... 31/01/2011 12:41:50 > Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\GS290_autobackup_31012 011_124150.eep 31/01/2011 12:41:50 > Analising EEPROM... 31/01/2011 12:41:50 > Phone IMEI:3592890346***** 31/01/2011 12:41:50 > SimLock Data Cleared! 31/01/2011 12:41:50 > Writing ... 31/01/2011 12:41:50 > Sending SEC pack... 31/01/2011 12:41:54 > Unlock done! 31/01/2011 12:41:54 > Finished in 6 seconds 31/01/2011 12:49:06 > Program succesfully closed at 31/01/2011 12:49:06 |
01-31-2011, 22:38 | #815 (permalink) |
Temporary banned !! Join Date: Aug 2007 Location: Austria (Linz)
Member: 568521 Status: Offline Thanks Meter: 240 | LG L1100 Unlock Done v1.1.6beta andrew_tm 2010(c) supported models: 203 Selected model: L1100 Selected port: COM6 Selected speed: 115200 Please press and hold power button! Phone detected! Start send loader... Loader startup Ok Change baudrate Ok Flash Id: 017E02 IMEI: 353584-00-268790-9 Read call. data... Patch call. data Write call. data... Direct unlock succesfully! Elapsed: 2 secs. --> (v.1.1.6beta) |
The Following User Says Thank You to sharef For This Useful Post: |
02-01-2011, 13:16 | #818 (permalink) |
Member: 1055074 Status: Offline Thanks Meter: 7,096 | Lg a133 done.thanks z3x Reading info... Flash ID: 0x8981 BOOT Stage Finished , sending authority... Reading ... Backup Saved AS:C:\Archivos de programa\Z3X\LG\LGI_SG3\BACKUP\A133_autobackup_010 22011_123134.eep Analising EEPROM... Phone IMEI:353545045170377 Unlock codes: NCK[0]: 0000000000000000 NCK[1]: 0000000000000000 NCK[2]: 0000000000000000 NCK[3]: 1194791435721032 NCK[4]: 1194791435721032 NCK[5]: 1194791435721032 NCK[6]: 1194791435721032 NCK[7]: 1194791435721032 NCK[8]: 1194791435721032 TIP: For additional codes , select Read Codes option and click Unlock button Finished in 17 seconds |
02-02-2011, 09:08 | #821 (permalink) |
Member: 1055074 Status: Offline Thanks Meter: 7,096 | lg gs290 read codes ok.thx z3x team Loading module , please wait... PMB8877 Module 1.31 started. SW: Ver 2.2.9.0 Please connect phone , it must be powered off Phone found! (MCU:SG3_USB) prebooting... Flash ID: 00FF00 *Note in USB mode flash id can be incorrectly read* BOOT Stage Finished , sending authority... Sending SEC pack... Reading EEPROM... Backup Saved AS:C:\Archivos de programa\Z3X\LG\LGI_SG3\BACKUP\GS290_autobackup_02 022011_090446.eep Analising EEPROM... Phone IMEI:354106044033055 Unlock codes: NCK[0]: 2296745631895633 (LOCKED) TIP: For additional codes , select Read Codes option and click Unlock button Finished in 1 seconds ***Disconnected*** TIP: Please reconnect phone battery / power source. |
The Following User Says Thank You to dani2080 For This Useful Post: |
02-02-2011, 09:14 | #822 (permalink) |
No Life Poster Join Date: Sep 2002 Location: south Afrika Age: 38
Member: 15156 Status: Offline Thanks Meter: 73 | kp500 imei repair failed Reading phone information ( must be powered ON! Phone platform:INFINEON Phone IMEI:358748037025121 Phone Secondary IMEI:358748037025121 Phone S/N:35874803702512100 Phone SW VER.:KP500AT-00-V10b-AFR-XXX-DEC-07-2008+3 Phone HW VER.:V1.0 Phone LCD Revision:LCD 1.0 Phone Camera Revision:CAM 1.0 Bluetooth Adress:0026e2e2be2f Net Lock Conf:"0","FFF,FFF,FFFFFFFF,FFFFFFFF,FF" SIM Lock Conf:"0","FFF,FFF,FFFFFFFF,FFFFFFFF,FF" Battery Voltage:3.7V Done! Repairing IMEI... , phone must be powered on! Operaing VIA: COM67 , Z3X BOX Serial Port (COM67) Config : /M Current IMEI:358748037025121 Writing new Main IMEI:58748107025121 Result is:MPL ERROR IMEI Repair failed , please make Direct Unlock or enter NCK and try to repeat procedure again. Reading phone... Phone platform:INFINEON Phone IMEI:358748037025121 Phone Secondary IMEI:358748037025121 Phone S/N:35874803702512100 Phone SW VER.:KP500AT-00-V10b-AFR-XXX-DEC-07-2008+3 Phone HW VER.:V1.0 Bluetooth Adress:0026e2e2be2f Operation Done! |
The Following User Says Thank You to osmanabu For This Useful Post: |
02-02-2011, 10:51 | #824 (permalink) |
No Life Poster Join Date: May 2006 Location: punjab
Member: 271008 Status: Offline Thanks Meter: 280 | lg GT365 Welcome to LG Infineon SGOLD3 TOOL v2x by NoName® Models count: 80 Current OS : Windows XP Welcome to Sgold3 Module!! Count supported models - 80 ***Disconnected*** TIP: Please reconnect phone battery / power source. Loading module , please wait... PMB8888 Module 1.1 started. SW: Ver 2.2.8.0 Connecting to GT365 in UART Mode (COM10 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8888) prebooting... Release power button. Booting... Reading info... Flash ID: 0000 BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\GT365_autobackup_02022 011_151050.eep Analising EEPROM... Phone IMEI:012294004610015 Unlock codes: NCK[0]: 47511158 (LOCKED) TIP: For additional codes , select Read Codes option and click Unlock button Finished in 7 seconds Reading codes... Sending SEC pack... Reading ... Analising EEPROM... Phone IMEI:012294004610015 For operation finishing,do next : 1. power phone ON with original SIM 2. type 2945#*71001# to enter unlock menu 3. Enter one of this code(s): NCK[0]: 47511158 (LOCKED) Finished in 7 seconds |
The Following User Says Thank You to neeraj1st For This Useful Post: |
02-03-2011, 08:14 | #825 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Selected model: GS101 Selected port: COM2 Selected speed: 921600 Connect phone and press Power ON! Connect ok! Send preloader ok! Send main loader Ok! Change BaudRate done! FlashId: 260600EC, flash size: 4Mb IMEI: 352231-04-637086-7 NCK Code: 4995 8728 8770 7973 Start unlock... Unlock code: 4995 8728 8770 7973 For enter unlock code: 1. Type: 2945#*101# 2. Goto Menu->Setting->Secutiry->Sim Locked->Sim Unlock Code 3. Desactivate and enter code:4995 8728 8770 7973 Elapsed: 3 secs. --> (v.1.1.6beta)v.2.1.0 supported models: 154 andrew_tm 2010(c) ; |
The Following User Says Thank You to worldlinkmobil For This Useful Post: |
Post here successfully job with Z3X-BOX Samsung (2010-2018) | mk | Z3X-Team Products | 21273 | 11-19-2018 09:21 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
