06-25-2012, 11:02 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Noise City
Member: 889564 Status: Offline Thanks Meter: 336 | >>>S5230 Unlock/Dead problem<<< |
06-25-2012, 11:31 | #3 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: Algeria-Cne Age: 47
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | Quote:
now i think is better to give log of boot repair operation to get more help form us. | |
06-25-2012, 12:32 | #4 (permalink) |
Member: 889564 Status: Offline Thanks Meter: 336 | 1.Here is the log from Z3X,repair dead boot,set to S5230 normal: Code: Selected model: S5230 Selected com port: COM3 Selected speed port: 921600 Connect phone to special micro-uart cable Start repair boot zone type 2... Bad Ask ! Repair boot - false Elapsed time: 21 second, sw ver: 3.5.0038 Code: Selected model: S5230M Selected com port: COM3 Selected speed port: 921600 Connect phone to uart cable Start repair boot zone type 2... Wait for download mode and connect to usb cable for flashig boot with multiloader.... Repair - boot ok Elapsed time: 33 second, sw ver: 3.5.0038 4.My PC can see the set,Multiloader is detecting it,but: Code: Download Start Ch[0] Bcmboot 55.1KB OK[0.2s] Boot2 170.7KB OK[0.4s] Patch_dsp 16.5KB OK[0.2s] Sysparm_dep 6.2KB OK[0.2s] Sysparm_ind 78.3KB OK[0.2s] Wait reset !! Serial port detect error! Last edited by DundyTM; 06-25-2012 at 12:38. |
06-25-2012, 13:11 | #6 (permalink) |
Member: 889564 Status: Offline Thanks Meter: 336 | Hm...It seems that Z3X is doing the boot trick,but I can't flash it. By the way,little update on the mission.I managed to flash the set with Z3X,not multiloader,but it's still dead.I have no "download mode"also. Code: Selected model: S5230M Selected com port: COM8 Selected speed port: 921600 Search flash modem ... OK Search flash modem on:COM8 Send APPS... OK Send RC1... OK Send RC2... OK Send FFS... OK Elapsed time: 180 second, sw ver: 3.5.0038 |
06-26-2012, 09:01 | #8 (permalink) | ||
Member: 889564 Status: Offline Thanks Meter: 336 | Quote: Quote:
06-26-2012, 12:51 | #10 (permalink) |
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | one thing i am sure is: 1- z3x can repair this phone 100% 2- you are doing wrong thing. 3- contact with me at sonork ID: 1603443 and we will try to solve your problem and after this you can post here how it worked for you. good luck |
06-26-2012, 15:33 | #11 (permalink) | |
1.I've managed to bring back the "download mode" via JTAG,,but... 2.When I try to fullflash the set...you can see for yourself: Code: Download Start Ch[0] Bcmboot 55.1KB OK[0.2s] Boot2 170.7KB OK[0.4s] Patch_dsp 16.5KB OK[1.3s] Sysparm_dep 6.2KB OK[0.2s] Sysparm_ind 78.3KB OK[0.2s] Wait reset !! Serial port detect error! Last edited by DundyTM; 06-26-2012 at 15:40. | |
06-26-2012, 15:42 | #12 (permalink) |
No Life Poster Join Date: Aug 2011 Location: Afghanistan
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | Mate do you remember its original version ? If yest try to flash with its original version . Once I had same problem and finally I find out that the phone was S5233T not S5233 and problem solved by flashing with the T version . WBR |
06-26-2012, 16:12 | #13 (permalink) | |
Actually,no,I don't.But even If I kill one S5230M,flashing it like S5230 normal,I can revive it with JTAG or Z3X boot repair and flash files for M,right?!It's just an example.The problem is that Im trying with almost all flashes-normal,M,W,but...you can see the situation,mate.Step by step. | |
06-26-2012, 20:54 | #14 (permalink) | |
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | try to lower your modem port number in device manager this can happen when you have a big modem port number. and also use another usb port (direct usb port not hub......) try in another pc also if after Quote:
if you can get download mode then try what i told you in first good luck | |
06-26-2012, 21:10 | #15 (permalink) |
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | and another thing you can do is knowing what firmware was in phone after he go to dead state. for this look at z3x location for me here is the directory C:\Program Files\Z3X\Samsung\All\LOG PS: folder LOG not logs there are two folder so vecareful in the mentioned folder you have text file and also picture screenshot you can see easly what firmware was in your phone in first time |
The Following User Says Thank You to adelkaha25 For This Useful Post: |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
