06-19-2015, 16:50 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Ghana Age: 39
Member: 153893 Status: Offline Thanks Meter: 266 | Samsung 6 edge G925T v5.1.1 root failed downgrade to v5.0.1 here is the logs Operation: Flash Selected model: SM-G925T Software version: 21.5 File analysis... OK Total file size: 0xDB8E1740 (3512 Mb) Searching USB Flash Interface... detected COM196 Setup connection... OK Reading PIT from phone... OK Sending boot.img... error timeout Done with Samsung Tool PRO v.21.5 On phone it said KEANEL REV. CHECK FAIL. DEVICE:2, BINARY:1 Phone hang now |
The Following User Says Thank You to godwin For This Useful Post: |
06-19-2015, 17:54 | #4 (permalink) | |
Freak Poster Join Date: Sep 2012 Location: Albuquerque NM
Member: 1808628 Status: Offline Thanks Meter: 26 | Quote:
I have 2 with the same problem. Both were repaired (IMEI and Unlocked) and now are stuck on SAMSUNG logo after updating to 5.1.1 Any solution to this problem? | |
06-19-2015, 18:30 | #5 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | You need to flash this original firmware and make phone alive again G925TUVU1AOCG_G925TTMB1AOCG_G925TUVU1AOCG_HOME.tar https://www.unlockbase.com/download/...e-firmware.zip Then root it with Tennis root when phone is alive then unlock it if you wish Also there is no downgrade or upgrade for this phone at all, doesn't exist at any place for the moment any other firmware except the one above posted which can be found also on Z3X support site |
The Following User Says Thank You to byteforce For This Useful Post: |
06-19-2015, 18:48 | #6 (permalink) | |
Member: 153893 Status: Offline Thanks Meter: 266 | Quote:
KEANEL REV. CHECK FAIL. DEVICE:2, BINARY:1 on the phone and cant boot hang on logo | |
06-19-2015, 19:15 | #7 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | You might of done something wrong ... make sure you write the Original Firmware for the device ... and should be working back again .. |
The Following User Says Thank You to jusmejose For This Useful Post: |
06-19-2015, 20:21 | #8 (permalink) | |
Freak Poster Join Date: Sep 2013 Location: PR
Member: 2032498 Status: Offline Thanks Meter: 39 | Quote:
06-19-2015, 20:31 | #9 (permalink) |
Member: 2032498 Status: Offline Thanks Meter: 39 | makes perfect sense if you say that after repair imei 5.1.1 install stayed locked in the logo if so tmobile did a good job security but a headache for us .... |
The Following User Says Thank You to APUAK47 For This Useful Post: |
06-19-2015, 20:39 | #10 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | So...has anyone tried twrp/cwm? Afaik, custom recoveries normally work in the event that direct kernel roots and cf roots dont work. (Please dont ask where to get a custom recovery or how to use it...these things are easily searchable and will result in a lmgtfy response from me). |
06-19-2015, 20:42 | #12 (permalink) | |
No Life Poster Join Date: Oct 2014 Location: Guatemala
Member: 2273678 Status: Offline Thanks Meter: 293 | Quote:
06-19-2015, 20:47 | #13 (permalink) |
Freak Poster Join Date: Jul 2010
Member: 1347382 Status: Offline Thanks Meter: 85 | IMEI repaired S6 edge..for testing purposes updated to 5.1.1 . Phone will not boot. I flashed stock original EFS and phone came back on just fine..also you cannot downgrade due to new boot loader. |
