02-28-2014, 18:38 | #31 (permalink) |
No Life Poster Join Date: Oct 2009 Location: serbia Age: 44
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | Only connecting when is in *7284# selected Pda for USB,Modem for UART,in "Quallcomm USB settings" and select "DM+MODEM+ADB",choose SAMSUNG Mobile USB Serial Port in port settings,device is rooted,and here is error: Code: Selected model: I9305 Selected port: COM46 Qualcomm HS-USB Diagnostics 9004 Selected port speed: 115200 Searching ADB device... Operation aborted Done with Samsung Tool v.17.0 Selected model: I9305 Selected port: COM38 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-I9305 Android version: 4.3 Product code: GT-I9305RWDORL Phone version: I9305DXALI7 PDA version: I9305XXUEMKC CSC version: I9305MGFEML1 IMEI: 353977051044842 Phone S/N: 00000000000 Checking Super user right... true Backuping MMCBLK... OK Writing data to phone... OK Reseting EFS... OK Rebooting phone... OK Waiting phone... OK Bypass MSL... error Done with Samsung Tool v.17.0 And after last step my imei is / 00 and TEST MODE is ON!!!! Need to use nspro to restore imei and remove test mode,but my problem is NOT CONNECT TO NETWORK,if anybody have solution please share.Thank you. |
02-28-2014, 19:38 | #32 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Man looks like you come from the moon. Why you reset EFS + same time you try repair imei?!!! After efs reset - imei is 01. all right. No network - NVM damaged or erased For imei repair you need repair IMEI!!! NOT RESET EFS. For network fix you need good NVM. Or use this solution: Write this NVM, i747_i747m_t999_Network_3_4g_FIX - Download - 4shared - test test you need choise RJ45 port and use UART cable Last edited by blang; 02-28-2014 at 19:47. |
The Following 3 Users Say Thank You to blang For This Useful Post: |
03-01-2014, 20:38 | #34 (permalink) |
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | It did not work writing "i747_i747m_t999_Network_3_4g_FIX".Same,not register on network,if somebody have full and working NVM from i9305 on android 4.3,please share here.Thanks |
03-02-2014, 12:02 | #37 (permalink) |
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | Solved writing full nvm,after need to choose network manually. Thank you all. Full nvm: I9305-Full NVM - Download - 4shared |
The Following User Says Thank You to galijus For This Useful Post: |
03-03-2014, 21:00 | #41 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | try this solution http://forum.gsmhosting.com/vbb/10129161-post191.html |
The Following User Says Thank You to blang For This Useful Post: |
03-03-2014, 21:40 | #42 (permalink) | |
Insane Poster Join Date: Feb 2003
Member: 22077 Status: Offline Thanks Meter: 3 | Quote:
thanks for your help | |
03-03-2014, 21:48 | #43 (permalink) | |
Freak Poster Join Date: Oct 2013 Location: italy
Member: 2048673 Status: Offline Thanks Meter: 62 | Quote:
with code you will solve your problem | |
03-03-2014, 21:51 | #44 (permalink) |
Member: 22077 Status: Offline Thanks Meter: 3 | i select full nvm and write Net_FIX.nvm with UART cable Code: Selected model: I9305 Selected port: COM4 USB Serial Port Selected port speed: 115200 Reading phone info... Reading IMEI... OK IMEI: 3562970XXXXXXXX Build: M9615ACEHWMAZD179545 Writing NVM... OK Done with Samsung Tool v.17.1 Done with Samsung Tool v.17.1 I think the problem is KNOX after install 4.3 i downgrade in 4.1.2 with rXtreme but the bootloader never downgrade and i think the bug is in bootloader and new security |
03-04-2014, 15:03 | #45 (permalink) | |
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | Quote:
