10-19-2009, 20:06 | #1 (permalink) |
Insane Poster Join Date: Sep 2007
Member: 579111 Status: Offline Thanks Meter: 9 | Samsung s3650 (genio) - help in unlocking and flashing I just purchased a z3x box and am having trouble unlocking these phones. I get the following message; Selected model: S3650 Selected com port: COM38 Selected speed port: 921600 Connect phone(RJ 45 cable) and power on - press 2-3 second Detecting UART port..... OK Repower phone - please wait If see on phone "Upload data to PC" - reconnect phone manually Disconnect RJ45 cable and connect data cable(APCBS10BBE or compatible) to phone Search modem ... Timeout Elapsed time: 89 second, sw ver: 3.3.0020 Do I connect this seperate from the box, ie. in a different usb slot? I dont have this cable, ill have to buy one tomorrow. Also I want to flash these phones, they are currently vodafone. I want to debrand (uk), which file shall I pick? I used to have nspro and know to pick files marked with XA for uk. Also which files do I pick for flashing? The only files in support is; S3650XEII3_BALTIC.zip S3650XEII3_RU.zip S3650XEII3_UA.zip Last edited by Soulja88; 10-19-2009 at 20:14. |
10-19-2009, 20:16 | #2 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Info about language pach here: http://forum.gsmhosting.com/vbb/showthread.php?t=674825 second you need this i think: http://forum.gsmhosting.com/vbb/showthread.php?t=609899 Unlocking: Power on phone, connect usb cable and setup usb driver. 1st method: you can use 2in1 cable (need choise option use 2in1 cable) 2nd. method you need RJ45 cable and aftert usb cables from phone box. |
10-20-2009, 07:35 | #3 (permalink) | |
Member: 579111 Status: Offline Thanks Meter: 9 | Quote:
Last version on support: 2G tools v3.3.0020 Selected model: S3650 Selected com port: COM38 Selected speed port: 921600 Phone must be ON Search modem ... Timeout - modem not found Elapsed time: 60 second, sw ver: 3.3.0020 Sorry for the newbie questions but how do I setup usb driver. By connecting the phone with rj45 cable or direct usb? ps - I did not get a e210 seperate usb with z3x. Can I use the e210+ as a seperate rj45 as well? Last edited by Soulja88; 10-20-2009 at 07:45. | |
10-20-2009, 07:45 | #4 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
Power on phone, connect usb cable and setup usb driver. | |
10-21-2009, 21:13 | #5 (permalink) | |
Also I dont understand how to set up usb driver, I have already installed usb from the z3x folder in program files. | |
10-21-2009, 21:14 | #6 (permalink) | |
Also I dont understand how to set up usb driver, I have already installed driver from the z3x folder in program files. | |
10-25-2009, 16:27 | #9 (permalink) |
Member: 579111 Status: Offline Thanks Meter: 9 | Hi Thanks for everyones help. There was no cable including in the box for some odd reason. I put the usb part of the e210+ cable direct into the computer, it recognised the phone but it could not find driver for modem. I downloaded the driver from a google search and installed and it unlocked succesfully. It worked and the phone is now unlocked. I have provided a link below for the modem driver for anyone who is in the same position. I have now a question about flashing the phone. I have made a request in the thread linked above but no reply. Therefore I need to unlock with one of the files in the support area. The ones below; S3650XEII3_BALTIC.zip S3650XEII3_RU.zip S3650XEII3_UA.zip What is the difference between baltic, ru and UA? Is it just country codes? If so which ones include english language? Also which files would I upload out of; APPS RSRC1 RSRC2 FFS I want to upload for debranding the vodafone firmware on the phone. |
The Following User Says Thank You to Soulja88 For This Useful Post: |
11-07-2009, 10:55 | #14 (permalink) |
Freak Poster Join Date: Jun 2006 Location: uk
Member: 291456 Status: Offline Thanks Meter: 15 | add flash files then connect rj45 + usb cable to the phone. make sure usb cable is connected to pc usb and not box usb phone must be turned on then click flash. make sure you have phone modem drivers installes in device manager |
The Following User Says Thank You to gji25 For This Useful Post: |
11-07-2009, 10:56 | #15 (permalink) |
Member: 291456 Status: Offline Thanks Meter: 15 | add flash files then connect rj45 + usb cable to the phone. make sure usb cable is connected to pc usb and not box usb phone must be turned on then click flash. make sure you have phone modem drivers installed in device manager |
how can i connect samsung s3650 with pc for unlock it [SOLVED] | abdel-27 | PolarBox 3 | 12 | 05-20-2013 15:55 |
help in ku990 bt problem after unlock and flash | tsarkh | VygisToolbox | 4 | 02-11-2009 14:10 |
motorola w375 unlock and flash NEW IN SMART CLIP HELP | maniek27 | Smart-Clip | 37 | 10-21-2008 12:56 |
i want a very clear guide in unlocking and flashing new sonyericsson arm | f164 | Sony Ericsson | 1 | 06-10-2007 14:03 |
Zulea, Please help for unlock and flash Nov 703sh and 903sh | superwing1248 | SonyEricsson (USB-Smart) | 2 | 01-07-2006 23:50 |
