07-27-2017, 13:37 | #1 (permalink) |
No Life Poster Join Date: Sep 2010
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | Samsung sm-g930a unlock problem Unlocking with original MSL code: 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. Operation: Read Codes via Server Selected model: SM-G930A Selected port: COM10 Z3X BOX Serial Port Software version: 29.0 Checking Login and Password... wrong login/password! Checking Login and Password... OK Ballance: 50 crd. Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-G930A Android version: 7.0 Product code: SM-G930AZDAATT Phone version: G930AUCS4BQC2 PDA version: G930AUCS4BQC2 CSC version: G930AATT4BQC2 CSC country code: USA CSC sales code: ATT HW version: REV0.6 Phone SN: R38H607CJML Chip name: MSM8996 Modem board: MSM8996 Security patch: 2017-03-01 RF cal date: 2016.06.07 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error () Done with Samsung Tool PRO v.29.0 |
07-27-2017, 14:54 | #4 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | UNLOCK INSTRUCTIONS: This phoe can be unlocked with unique original MSL code only! 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. Operation: Unlock Selected model: SM-G930A Selected port: COM22 USB Serial Port Software version: 28.2 Checking phone at COM22 Ok Reading phone info... Ok Model: SM-G930A Country code: ATT Factory SW: G930AUCS4BQC2 Unique number: CE09160920D3BA0D05 IMEI: 35232508213646 Reading SN... Ok Phone SN: R58H93MC3C Enter MSL: 0D264D0C2443084E5C2F0C2Axxxxxxxx Bypass MSL... Ok Unlocking... Ok Codes set to 00000000 Unlock done Done with Samsung Tool PRO v.28.2 |
07-27-2017, 20:33 | #5 (permalink) |
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | support z3x answer to my problem i see same problem http://forum.gsmhosting.com/vbb/f453...oblem-2247984/ |
