04-14-2016, 13:34 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | SM-G531F Reset FRP/React/EE Erasing EE lock... error >>Help Me I Do This This Mobile Flash With 2 different Firmware But Not Removing FRP Lock. some users Was Doing fixing this by flashing Please Give Me Tested Firmware. Log Bellow UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. If phone ask codes after unlocking, use: PUK - 12345678 PIN - 00000000 To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G531F Software version: 25.1 Searching Samsung USB Flash Interface... detected COM24 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error Done with Samsung Tool PRO v.25.1 I Was Try Z3X Many Software Like AS: 1.SamsungToolPRO_25.1 2.SamsungToolPRO_25.0 3.SamsungToolPRO_24.9 4.SamsungToolPRO_23.9 But Problem Same kindly Please Help Me Thanks & Regards By : Gopal Parmar |
04-15-2016, 06:19 | #3 (permalink) |
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | First= G531FXXU1AOH1_Rooted_Firmware_v5.1.1_New.zip Second=G531FDDU1APB2_ODD1APC1.zip Both Via Flash Success But Problem Not Solve |
04-18-2016, 06:19 | #5 (permalink) |
Freak Poster Join Date: Jul 2015 Location: Bangladesh
Member: 2424275 Status: Offline Sonork: 100.1625469 Thanks Meter: 68 | http://forum.gsmhosting.com/vbb/f777...azone-1990399/ try this sulation...... or try miracle box.... |
05-10-2016, 07:51 | #8 (permalink) | |
Freak Poster Join Date: Nov 2008
Member: 893550 Status: Offline Thanks Meter: 139 | Quote:
please help me how to remove frp on this device thanks | |
05-10-2016, 08:05 | #9 (permalink) |
Freak Poster Join Date: Mar 2014
Member: 2139591 Status: Offline Thanks Meter: 78 | Bro, try this way out. Hope ur problem solves. I know it is for J700F, but it may also work for All latest phones. http://forum.gsmhosting.com/vbb/11786625-post1.html 2nd method http://forum.gsmhosting.com/vbb/11788409-post15.html |
06-11-2016, 15:10 | #11 (permalink) | |
Product Supporter Join Date: Oct 2010 Location: DHAKA Mobile
Member: 1417131 Status: Offline Sonork: Uninstalled Thanks Meter: 1,090 | Quote:
http://forum.gsmhosting.com/vbb/f453...count-2092541/ | |
The Following User Says Thank You to farukpdm For This Useful Post: |
06-11-2016, 22:32 | #12 (permalink) |
Insane Poster Join Date: Jan 2015
Member: 2321119 Status: Offline Thanks Meter: 119 | flash this file in BL then reset with box Dev-Host - FRP_G531F_BY_ALOSYRIA_HALABTACh.tar.md5 - The Ultimate Free File Hosting / File Sharing Service only thanks button T |
The Following User Says Thank You to tarek.mobile For This Useful Post: |
06-17-2016, 12:21 | #13 (permalink) | |
Freak Poster Join Date: Oct 2010 Location: Transylvania
Member: 1423806 Status: Offline Sonork: 100.1685119 Thanks Meter: 44 | Quote:
Any other solution? | |
