04-22-2017, 01:24 | #1 (permalink) |
Insane Poster Join Date: May 2016
Member: 2575895 Status: Offline Thanks Meter: 10 | SM-G935t Combination converts phone to SM-G935a [Solved] now it will only accept att g935a roms how can I convert it back to tmobile when I flash it with T mobile roms odin gives Fail!sha 256 Need help with this issue please |
04-22-2017, 02:04 | #2 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
Then use Z3X or other box to change the Bootloader Recognized identifier 2、Making a special data line, to achieve strong brush the other version of the firmware. (The other phone use this way..) 3、Modify other editions Samsung firmware identifier,To achieve the bypass bootloader to flash the other version. | |
04-22-2017, 02:19 | #3 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
let me know | |
The Following User Says Thank You to CHANDARAKK For This Useful Post: |
04-22-2017, 02:21 | #4 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Take care because you can have root because of an engineering kernel that allows root commands. But bootloader will not allow us to flash anything that isn't developed or approved by Samsung. https://www.androidfilehost.com/?fid=457095661767141717 |
04-22-2017, 02:35 | #5 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | ENG (AP) files for S7 and S7E This is the ENGINEER boot kernel boot.tar file you'll be flashing in the special modified Odin software from your PC https://www.androidfilehost.com/?fid=457095661767141717 SuperSU 2.79 root.bat file This is the command prompt script you'll execute from a CMD prompt from a windows PC that installs the needed files for root access like SuperSU https://www.androidfilehost.com/?fid=817550096634750763 After Eng-Boot (root is complete) After all process return to STOCK Android 7.0 Nougat You will need to have Odin installed (same modified Odin linked above should work fine) You can download stock Android 7.0 Nougat firmware |
06-12-2017, 20:40 | #6 (permalink) | |
Freak Poster Join Date: Aug 2013 Location: Dominican Republic Age: 36
Member: 1993261 Status: Offline Sonork: 100.1678139 Thanks Meter: 66 | Has combination G935T Quote:
01-03-2018, 15:36 | #9 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Dominican Republic
Member: 469532 Status: Offline Sonork: TG: CodebUnlocks Thanks Meter: 868 | Quote: and now phone change to g935a and i can't flash any stock rom, i try with lates QL2 for g935t and QK2 for g935a, phone only flash ok with mentioned combo file | |
01-17-2018, 01:31 | #13 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2016
Member: 2532914 Status: Offline Thanks Meter: 1,154 | Just a heads up combo files for like the s7, s8 and note 8 will flash on any qualcomm phone regardless of its carrier as long as its a qualcomm phone. Oh no i flashed my tmobile phone with a combo file and it converted it to at&t LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL I dont know what sha256 error is LOL LOL LOL LOL LOL LOL I CANT STOP LAUGHING. YOU DONT LEARN ANYTHING OF VALUE ON THIS FORUM ANY LONGER BUT IT IS GOOD FOR A LAUGH!!!! |
The Following User Says Thank You to markhaines1985 For This Useful Post: |
01-23-2018, 18:55 | #14 (permalink) | |
Insane Poster Join Date: Dec 2014
Member: 2314949 Status: Offline Thanks Meter: 18 | Quote:
so there on the web its a COMBINATION_FA60_G935AUCU5AQK1, COMBINATION_FA60_G935TUCU5AQK1 all of them are bit 5 with bootloader from G935A, can be exchanged for a G935P bit 5 but cant be downgraded to BIT4, so there we have a problem, until samsung release bit5 firmware for g935t, anyway, YES it works with G935PVPU5BQL1_G935PSPT5BQL1_XAS search on samfirmware, and Comsy Odin, ALSO, u need the pit file of the g935p if u are getting FILE SIZE ERRORS, google it, and works fine | |
01-23-2018, 19:04 | #15 (permalink) | |
Member: 2532914 Status: Offline Thanks Meter: 1,154 | Quote:
I have forgotten more than you know. Know get off my pant leg. BTW i am still lauging...the guy said it converted my tmobile phone to an at&t phone LOL LOL LOL LOL | |
