02-15-2018, 08:34 | #17 (permalink) |
Junior Member Join Date: Aug 2015 Location: Nowshera Pakistan
Member: 2445304 Status: Offline Sonork: 100.1673122 Thanks Meter: 5 | SM-G935U_G935T-G935V-G935R4-G935P- Convert and Fix Rom Done combine convert Rom for multiple models 100% tested by JJ contact Number ) 03324242664 skype - [email protected] Last edited by jhoni janan; 02-15-2018 at 08:39. |
The Following User Says Thank You to jhoni janan For This Useful Post: |
02-15-2018, 11:24 | #19 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: Asia Mobiles Repairing (Swabi)
Member: 435412 Status: Offline Sonork: 100.1608142 Thanks Meter: 289 | Quote:
https://androidfilehost.com/?fid=745425885120745969 | |
02-16-2018, 20:54 | #20 (permalink) | |
Freak Poster Join Date: Dec 2015
Member: 2495033 Status: Offline Thanks Meter: 21 | hi Quote:
02-17-2018, 11:52 | #22 (permalink) |
Member: 2495033 Status: Offline Thanks Meter: 21 | Lolxxx odin patch only fix sha256 error... but on g935t case there is not the only sha256 error there is also some other errors too.. odin patch cannot write firmware on converted g935a... |
02-17-2018, 18:44 | #23 (permalink) |
Banned Join Date: Jan 2014 Location: Havana, Cuba Age: 40
Member: 2107306 Status: Offline Thanks Meter: 612 | I've just had a g935T with NON FATAL MIPI FAIL and flashed combination FA60_G935A_G935T rev4, entered service mode *#33725327#, make backup EFS and then EFS CLEAR & RESTORE. Restart handset and you'll get MIPI TEST SUCCESS and the normal non mipi device fail. Reflashed phone to stock using "princecomsy" odin (yes ODIN PATCHED 3.12.3) to g935T stock, phone booted network locked, just connected it to internet and make device unlock. Phone is working just fine full network 2g/3g signal. If you like I can send you a video of how its done, my whatsapp +53 52667726. I can do this just for fun endless times, flash combo, service menu, efs clear, network locked, device unlock, ta daaa. |
The Following User Says Thank You to Prsctt For This Useful Post: |
06-07-2018, 18:58 | #24 (permalink) | |
Member: 2495033 Status: Offline Thanks Meter: 21 | cheater Quote:
05-14-2019, 08:26 | #26 (permalink) |
Registered User Join Date: Jun 2005 Location: jamnagar gujarat india
Member: 149938 Status: Offline Thanks Meter: 47 | i have G935T 8.0 G935TUVS9CSC1 flashed combination file COMBINATION_FA60_G935AUCU9ASA1 now my phone model is g935a and when i full flash g935tuvs9csc1 , it gives error. how to get out of factory . Do i need G935Aucu9asa1 ? where can i find ? please guide. |
05-14-2019, 08:42 | #27 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Malappuram. INDIA
Member: 412813 Status: Offline Sonork: 100.1594692 Thanks Meter: 353 | Quote:
now which model you need to flash in this phone? if u need to flash G935T, just flash g935T file and tell me what error coming when using this file | |
05-14-2019, 11:18 | #28 (permalink) | |
Member: 149938 Status: Offline Thanks Meter: 47 | Quote:
Total file size: 0x1203EEDC4 (4611 Mb) Searching USB Flash interface... COM6 detected Setup connection... OK Getting device info... OK Reading PIT from phone... OK Sending emmc_appsboot.mbn.lz4... OK Sending lksecapp.mbn.lz4... OK Sending xbl.elf.lz4... OK Sending tz.mbn.lz4... OK Sending hyp.mbn.lz4... OK Sending devcfg.mbn.lz4... OK Sending pmic.elf.lz4... OK Sending rpm.mbn.lz4... OK Sending cmnlib.mbn.lz4... OK Sending keymaster.mbn.lz4... OK Sending apdp.mbn.lz4... OK Sending msadp.mbn.lz4... OK Sending cmnlib64.mbn.lz4... OK Sending sec.dat.lz4... OK Sending NON-HLOS.bin.lz4... OK Sending boot.img.lz4... OK Sending recovery.img.lz4... OK Sending system.img.ext4.lz4... error timeout in screen it shows volume size is too big Odin inval id ext4 image. | |
05-17-2019, 19:31 | #29 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1548115 Status: Offline Thanks Meter: 0 | You have to download the AT&T firmware, if available, flash only BL, AP, and CSC. After it boots and you're in the main screen, enable Developer Options (Settings>About Phone>Tap Build number 4 times) and enable OEM unlock. From there, just restart phone in Download mode and flash the original T-Mobile firmware. This has worked for me every single time with the S7 & S7Edge from T-Mobile. |
05-19-2019, 00:40 | #30 (permalink) | |
Freak Poster Join Date: May 2015 Location: Los Angeles Age: 29
Member: 2400231 Status: Offline Thanks Meter: 124 | Quote:
