06-23-2010, 14:45 | #33 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: Neverland
Member: 1099972 Status: Offline Thanks Meter: 208 | Quote:
(as I've said di ko na kelangan i save sa saurik ung shsh kc pwede nmn i downgrade ung version tested na yan b4 in 2.xxx days pa di nga lang maddowngrade ang MF & since unlockble na ung 5.13 whats the use of it to save shsh dba) the logic is, right now we have the tools to unlock all BB FM fr 4.xxx to 5.13 the sole purpose of this thread is to guide others who's having 4.0 on 3gs and want to use it since redsnow & spirit does't support it for JB at the moment I repeat correct me if I'm wrong spirit & redsn0w0.95xxx doest support iphone 3gs 4.0 maybe in mac via pwnage i donno i'm not a mac user... | |
06-23-2010, 14:55 | #35 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Bim
Member: 203715 Status: Offline Thanks Meter: 227 | iReb is from the website ih8sn0w.com, on there is also the useful iForecast and sn0wbreeze. What the threadstarter has failed to explain is how he got past the error msg 'iphone the device is not eligible for the requested build' when trying to downgrade the 3Gs. Everything is basically correct in theory. |
06-23-2010, 14:56 | #36 (permalink) |
No Life Poster Join Date: Jul 2007 Location: earth
Member: 538815 Status: Offline Thanks Meter: 161 | @fullblast yes boss. But as far as I know pag 3gs ang iphone dipo basta naiddowngrade ang firmware basta ng Walang back up na shsh blobs at uploaded sa saurik server. Papost daw po ng sinasabi ko screenshot ng cydia mo, dun kasi makikita yun. Walang back up na shsh |
06-23-2010, 15:04 | #37 (permalink) |
Member: 538815 Status: Offline Thanks Meter: 161 | @fullblast yes boss. But as far as I know pag 3gs ang iphone dipo basta naiddowngrade ang firmware basta ng Walang back up na shsh blobs at uploaded sa saurik server. Papost daw po ng sinasabi ko screenshot ng cydia mo, dun kasi makikita yun. Walang back up na shsh. If your phone is 3G u can downgrade it as simply then you will get error 1015. But it's okay just run Irecovery to kick dfu mode. But in 3gs afaik not supported unless If u have shsh blob back up from saurik server. |
06-23-2010, 15:09 | #38 (permalink) |
Member: 538815 Status: Offline Thanks Meter: 161 | One best example of downgrading from 3GS from 3.1.3 to 3.1.2 Downgrade iPhone 3GS OS 3.1.3 to 3.1.2 With Cydia SHSH | jailbreak you can't easily downgrade firmware of 3GS without shsh. |
The Following User Says Thank You to frooze_angel For This Useful Post: |
06-23-2010, 15:10 | #39 (permalink) | |
http://forum.gsmhosting.com/vbb/f456...nlock-1030255/ so i look for another possible way just to make sure i can still use the 3gs so came here i just downgrade 3gs. using itunes 9.2 in my post ive told you that you'll encounter an error in the last part of restoring just ignore it & close cydia then open iH8sn0w - iREB V3.1.2 For Windows-English click fix recovery loop & it will fix it for you now it reboots in ver 3.1.3 so i proceed to jb then unlock | |
06-23-2010, 15:21 | #41 (permalink) |
Member: 538815 Status: Offline Thanks Meter: 161 | @fullblast sir in 3G Wala pong problem both downgrade and unlocking. my issue is in 3GS downgrading firmware without shsh back up. From 4.0 to 3.1.3 maybe merong previous back up hung 3gs na ginawa mo at Dimo Lang napansin Kaya you can downgraded it without error sa firmware 3.1.3. Yum ang paniniwala ko. But if 3GS doesn't perform uploading shsh blobs in saurik server when it was 3.1.3 then accidentally na update ng 4.0 wala po tlagng solusyon alam ko para maidowngrade. |
06-23-2010, 15:30 | #43 (permalink) | |
correct !! but i do mention that there will be an error in itunes in the later part just ignore it close itunes then open ireb click fixrecovery mode loop & wait till reboot | |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
