Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
08-14-2008, 07:28 | #1 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 471557 Status: Offline Thanks Meter: 13 | Dual Sim After Format One Sim No Network Pls Tell Us.... I Have Lot Here Dual Sim After Format Only One Sim Function Proprely...... Infinity Team .. Any Solution In This Kind Of Problem....... Thanx In Advance And Support...... |
08-19-2008, 06:38 | #2 (permalink) | |
Junior Member Join Date: Dec 2006
Member: 414164 Status: Offline Thanks Meter: 0 | buddy Quote:
08-19-2008, 10:46 | #5 (permalink) | |
Freak Poster Join Date: Sep 2007
Member: 583680 Status: Offline Thanks Meter: 47 | Quote:
I solved this problem for chinese LT-X3 | |
08-19-2008, 13:29 | #6 (permalink) | |
Moderator Join Date: Feb 2006 Location: Bangladesh & Bahrain
Member: 233205 Status: Offline Thanks Meter: 5,014 | Quote:
many many dual sim phone have dual cpu. so if you format only first cpu. 2nd cpu need to format or Rebuild IMEI also. if you phone have 2 cpu sometimes it have 2 imei. so though your phone have 2 IMEI, must rebuild IMEI both and for format or rebuild imei for 2 cpu, you need tx rx for both cpu. at last if your phone have 1 cpu and after format or rebuild IMEI both sim is not work, you need to flash your phone with new file. | |
The Following User Says Thank You to tkowsar For This Useful Post: |
08-19-2008, 20:02 | #7 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | you can solve your problem with infinity new update of chinese miracle... just repair second cpu imei and your mobile will be start working again tested many times |
08-23-2008, 08:51 | #8 (permalink) |
Member: 471557 Status: Offline Thanks Meter: 13 | n99i guy i will try in second time cause i already try it in the first place ...but i will do that thanx for the reply....for now the unit will sim2 display signal globe but the 1st sim display only emegncy.......but when i put sim in the sim2 and balance inquire in the menu selection it display not supported... but thanz any way in your reply will post the result... Qsite..:ro lleyes: |
08-27-2008, 11:07 | #9 (permalink) |
Member: 471557 Status: Offline Thanks Meter: 13 | n99i infinity team i just wanna ask if the n99i only display emergency now in both sim 1 and 2 i already rewrite the back up b4 only sim1 display emergency but now both what should i do to have a signal in even one sim1 pls advice me .... thanx....... |
08-28-2008, 07:23 | #10 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 754208 Status: Offline Thanks Meter: 67 | Solution for one sim no network Hi, Brother, i also faced this problem then i found the solution. please try it and work 100%. I have MC Tool and i just Format mobile countinusly 5 times and set will ok. Thanx Try and reply |
n92.. dual sim.. after format, no display!! HELP!! | parengBok | SpiderMan | 2 | 04-11-2009 04:02 |
N72 Dual SIM After Formatting IMEIs r Bad.. | LoveLess | SpiderMan | 0 | 03-29-2008 11:08 |
GX25 and insert SIM after format diag | Stoyan | Sharp | 0 | 06-22-2006 22:09 |
