PadFinder box Smart universal box for Chinese phones ( for all phones ) with automatic pinouts search functions. |
07-28-2008, 08:42 | #1 (permalink) |
Registered User Join Date: Feb 2006 Location: tagum,davao philippines
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | padfinder problem installing driver insert the usb cable with the box to my computer it says found new hardware FTDI FT8U2XX DEVICE THEN I CHOOSE THE FOLDER WHERE MY DRIVER WAS EXTRACTED AFTER INSTALLATION THERES NO COMFORT AVAILABLE FOR MY PADFINDER BOX IN DEVICE MANAGER i already followed your procedure in installing the driver can you guide me please what to do in your guide the computer will detect the padfinder comfort but why when i insert usb to my box it only finds the ft ft8u2xx device and it says your new hardware is installed successfully and ready to used but why the comport not yet installed |
07-30-2008, 01:12 | #2 (permalink) |
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | hello is there really a supporter in this box? where can we find the the real supporter here i cant solve this problem |
07-30-2008, 03:36 | #3 (permalink) |
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | when i install my setool box,ustprobox,furiosbox,it auto matically detect the usb serial port but the pad finder box, it only finds ft ft8u2xx device and it says your new hardware is installed successfully and ready to used but why the comport not yet installed |
07-30-2008, 07:17 | #4 (permalink) |
No Life Poster Join Date: Mar 2001 Age: 44
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | /vbb/showthread...highlight=FTDI check this bro |
07-30-2008, 11:40 | #5 (permalink) |
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | thanks man your a great supporter it really solve my problem I had this problem too. It is caused by incompatible padfider drivers v1.0 supplied at http://www.padfinder.net/index.php?i...wse=%2Fdrivers. With this drivers it installs the ftd2xx part instead of the normal bus/port needed for padfinder to work. To fix it you can do this: - uninstall the device from windows device manager - disconnect the box from the pc - download the attached FTDIBUS_INF.zip - goto your \PadFinder_Drivers_v.1.0\ directory and extract the file there, overwrite FTDIBUS.INF - connect the box to usb - choose 'install from a list or specific location' - choose 'don't search. i will choose the driver to install' - click 'have disk' - browse to location and press ok - select padfinder com port - next, do not overwrite files if not needed (if you overwrite other boxes like jaf/nspro might stop functioning) - install the usb serial port the same way - finished, you can use the box now. be sure the comport number is not set too high. @support: Please fix the drivers supplied at the padfinder.net website! In the attached file I replaced VID_1500&PID_0002 by VID_0403&PID_6001 so the bus/port can be installed. I don't know if the FTD2XX part is needed for padfinder, so I didn't touch that part. Attached Files File Type: zip FTDIBUS_INF.zip (1.2 KB, 10 views) |
07-30-2008, 11:57 | #6 (permalink) | |
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | Quote:
07-30-2008, 12:13 | #7 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Ukraine Age: 46
Member: 18606 Status: Offline Thanks Meter: 560 | Thanks for Info. Problem Fixed. Pls download new driver: http://padfinder.net/download/driver...vers_v.1.1.rar |
j400 probleme instaling drivers | yassinek85 | UST Pro II | 0 | 05-27-2009 22:01 |
problem instaling driver with N-box with hwk | sameenshah123 | HWK | 1 | 03-02-2009 11:52 |
padfinder problem installing driver | dancd | PadFinder box | 5 | 12-05-2008 17:45 |
Problem installing Drivers | Ponder | UniMoto | 1 | 06-21-2004 20:54 |
