09-02-2009, 09:38 | #16 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: \/\/ 0RLD \/\/ IDE
Member: 238374 Status: Offline Sonork: 100.1597005 Thanks Meter: 1,087 | Quote:
if set have 5 looks then ? chk Code: 0.915040/UNI CARD SERIAL: Loaded 51 flash descriptors CFG:00000000000000 ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:921600 Flash ID check:2019 Flash props sent ok OTP: LOCKED:1 CID:50 PAF:1 IMEI:35657301xxxxxx CERT:RED FLASH CID:50 COLOR:RED 07 AM 07 AM Model (from GDFS):W810i MAPP CXC article: R4EA031 prgCXC1250316_GENERIC_HN MAPP CXC version: R4EA031 Language Package: M_EAST_N_AFR CDA article: CDA102494/1 CDA version: R2A Default article: cxc1250324 Default version: R4ED001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 21 secs. what you think about that Default article: cxc1250324 Default version: R4ED001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED | |
09-02-2009, 13:35 | #17 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | If set have 5 locks closed, which i think it have, then only csca unlock is possible, unless, because of wrong settings selected you produced that 5 locks to close, in this case just go to backups folder, look for a folder with the imei of your phone, look for the first backup made (it was created when you first pressed identify button) and write .sec file like a script, phone will return to original condition and then you can proceed to unlock it with correct settings, luck |
how to unlock w810 cid 49 | shoaib82a | SETool2 | 2 | 09-03-2009 11:56 |
how to unlock w810 cid-50 | saf470 | Universalbox | 3 | 11-28-2007 08:24 |
How To Unlock W81o Cid 50 | UNIQUEM | Universalbox | 4 | 11-05-2007 11:55 |
problem to unlock W810 CID 50 | ..:: i-MAX ::.. | Cruiser Suite | 5 | 10-04-2007 15:33 |
how to unlock w810 cid 50 by cruiser 07 | desmond2727 | Cruiser Suite | 13 | 09-23-2007 22:04 |
