Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 09-01-2008, 15:24   #1 (permalink)
m_choko's Avatar
Member: 88177
Sonork: 1594092
Thanks Meter: 71
Problem with K320i : 5 locks closed
i cant unlock my K320i beacause there is no provider locked in it and it dont accept any card.
log :
v0.914034/UNI
CARD SERIAL: 00072807
Loaded 51 flash descriptors
SIGNED MODE (USING SERVER).
ChipID:8040,EMP protocol:0301
NEW SECURITY MODEL DETECTED
PHONE IS RED RETAIL PRODUCT
FLASH CID detected:50
Speed:921600
Flash ID check:897E
Flash props sent ok
OTP LOCKED:1 CID:50 PAF:1 IMEI:35257002106836 CERT:RED
FLASH CID:50 COLOR:RED
Model:K320i
Brand:Generic
MAPP CXC article: R4GC012 prgCXC1250682_GENERIC_MA
MAPP CXC version: R4GC012
Language Package:M_EAST_N_AFR
CDA article: CDA12345678/123
CDA version: R2A
Default article: cxc1250690
Default version: R4GC012
PROVIDER: 000-00
SIMLOCKS NOT DETECTED
USERCODE:0000
RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
Elapsed: 10 secs.
where is the solution please.?????
Old 09-01-2008, 15:42   #2 (permalink)
edcentec's Avatar
Member: 232960
Thanks Meter: 416
v0.914038
- added SCRC testpoint repair for db2012 phones.
supported CIDs : 50,51,52,53.
(db201x testpoint idea made by dre_ambox team).
usage:
1. it is only and only for professionals.
users,advanced users, please "go away".
2. testpoint is +3.3 voltage, connected to specific pin.
we suggesting to use +3.3v battery
(battery ground MUST be connected with phone's GROUND)
3. go to emptyboard fill & repair.
4. select needed db2012 model.
5. press "TP STAGE #1". read instructions and execute them.
6. phone is BROWN now.
7. now flash CORRECT db201x erom with needed CID.
NOTE, THAT EROM CID SHOULD BE >= OTP CID,OTHERWISE YOU WILL GET DEAD PHONE.
10. phone now retail,repaired and unlocked. fullflash phone as usual.
testpoint pictures (courtesy of drea_mbox team) included.
as all db201x shares same mcu, w200 testpoint picture is good
for all db201x phones.
IF YOU WROTE EROM WITH INCORRECT CID - USE "TP STAGE #2"
PLEASE NOTE, THAT CURRENT IMPLEMENTATION REQUIRES
VALID GDFS STRUCTURE. SO, IT SITUABLE ONLY FOR 5-LOCKS
REPAIR AND FULL STANDALONE UNLOCK.
- added all possible db201x eroms, now users can make cid50/51/52/53
phones from emptyboard phones
(not forget: add to firmware area gdfs_in_ssw FIRST and EROM LATEST)
- minor bugfixes
Tp pics inside setool folder...
The Following User Says Thank You to edcentec For This Useful Post:
Old 09-01-2008, 15:47   #3 (permalink)
edcentec's Avatar
Member: 232960
Thanks Meter: 416
If u have problem with flash and finalize phone after tp procedure.....
1. go to emptyboard tab,select k320, com/ufs as interface
2. select cid51,press recovery
3. add to firmware files gdfs_in_ssw format, db2012_erom_red50
4. press flash
5. phone now red50, but otp is unlocked, that is just fine
6. go to semc tab, select and flash in phone needed main+fsimage+custpack
7. check if phone okay (radio,etc)
8. if phone is okay, you need write IMEI and LOCK OTP, for that make steps 1,2,3
but on step 4 - fill desired IMEI and check "WRITE OTP" checkbox.
hopefully, i explained enough.
Old 09-01-2008, 18:34   #4 (permalink)
Member: 475865
Thanks Meter: 15
You don't need all that,
- Look in backup folder, ex : ....\v0.914038\backup
there's a folder named 35257002106836 (the imei of your phone)
- Look for the file 35257002106836_D_M_2008_H_Mn_S.seczone
D = day
M = month
H = hour
Mn = minute
S =seconde
- Take the the old one (date & hour) it's the first backup of your phone
- open setool soft
- Browse and select the file :
(35257002106836_D_M_2008_H_Mn_S.seczone) in MISC files
- Then write SCRIPT
and your phone will be back to its original state, means: locked to the first operator........enjoy
The Following 7 Users Say Thank You to boundif For This Useful Post:
Old 09-02-2008, 13:55   #5 (permalink)
m_choko's Avatar
Member: 88177
Sonork: 1594092
Thanks Meter: 71
D = day
M = month
H = hour
Mn = minute
S =seconde
- open setool soft
- Then write SCRIPT
thank you freind, good job.
Old 09-04-2008, 23:00   #6 (permalink)
hackgsm's Avatar
Member: 64014
Sonork: 100.1603152
Thanks Meter: 255
http:///vbb/showthread.php?t=588896
K320i 5 LOCK CLOSE HOW TO UNLOCK? denard Cruiser Suite 27 03-29-2010 02:26
SE K320i 5 LOCKS CLOSED. AbdulKadir Universalbox 7 07-01-2009 09:08
K320i 5 LOCKS CLOSED denard Cruiser Suite 5 08-10-2008 03:19
W850 5 lock closed just Unlock with ub? bestncheap Universalbox 2 03-20-2007 22:22
Please help ! K750i with 5 locks closed and hang in "please wait" nova75c Cruiser Suite 9 09-16-2006 04:40
Page generated in 0.16798 seconds with 9 queries
