07-31-2008, 21:45 | #1 (permalink) |
Freak Poster Join Date: May 2004 Location: Algeria Age: 53
Member: 66566 Status: Offline Thanks Meter: 43 | The server is not available ? Does the server working now ? I have two account and same response v0.914037/UNI CARD SERIAL: ******xx Loaded 51 flash descriptors ChipID:C900,EMP protocol:0401 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 OTP LOCKED:1 CID:52 PAF:1 IMEI:352571020***xxCERT:RED Model:K660i MAPP CXC article: R1EA033 prg12029712_HUTCHISON_CE MAPP CXC version: R1EA033 Language Package:HUTCH-WORLD CDA article: 1208-1161 CDA version: R5A Default article: 1202-2362 Default version: R1EA033 PROVIDER: 000-00 Network LOCKED SECURITY UNITS BACKUP CREATED. Elapsed: 12 secs. SIGNED MODE (USING SERVER). ChipID:C900,EMP protocol:0401 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 OTP LOCKED:1 CID:52 PAF:1 IMEI:352571020***xx CERT:RED LDR:2008-04-07 10:55 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A058 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2008-04-07 10:55 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A058 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Asking for EROM signature... CAN'T CONNECT TO SERVER. signature calculation not done,err: 144 Elapsed: 33 secs. SIGNED MODE (USING SERVER). No server found. CARD COUNTERS: FLASH 168, UNLOCK 89 Elapsed: 22 secs. |
08-01-2008, 04:57 | #2 (permalink) | |||
No Life Poster Join Date: Mar 2005 Location: lets See.
Member: 128918 Status: Offline Thanks Meter: 282 | All servers working OK maybe u did not edit ur setool.ini if u have credit for server 196 edit ur INI 1st three lines like Quote:
hopefully u will get desired result good luck | |||
The Following User Says Thank You to Afzaal For This Useful Post: |
08-01-2008, 14:48 | #3 (permalink) | |
Member: 66566 Status: Offline Thanks Meter: 43 | Quote:
Can I delete this setool2.ini and put another clean one ? | |
08-01-2008, 15:01 | #4 (permalink) |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | yes u can chek the settings for that : as all servers are working SIGNATURE SERVERS (FULL PERMANENT Unlock for CID>=51) : ONLINE please note,that signature servers will not work in weekends and holidays CREDIT SERVERS (alternative bypass,csca unlock): srv01.dontexist.com ONLINE srv02.dontexist.com ONLINE srv03.dontexist.com ONLINE |
The Following User Says Thank You to .::BHATTI::. For This Useful Post: |
csca server is not available at the moment | emedli | Universalbox | 3 | 08-28-2008 20:47 |
Rh99 1200 file is not available at ub server | rana4star | Universalbox | 5 | 08-31-2007 15:44 |
