06-28-2007, 09:30 | #76 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 45
Member: 139388 Status: Offline Thanks Meter: 98 | W810i flashing problem HERE THE LOG Loaded 51 flash descriptors ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:3************* CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS 'TESTPOINT OK' ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Trying to launch embedded bootloader... Embedded flashloader: COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 Flash ID check:897E Flash props sent ok FOUND: R4DB005_CXC1250316_GENERIC_HN Restore from:R4DB005_CXC1250316_GENERIC_HN writing E:\FLASHER AND FLASHES\setool3\w810i flash files\R4EA031_1250316_GENERIC_HN.ssw\R4EA031_12503 16_GENERIC_HN.ssw.cry CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:344 Will flash 344 blocks... SSW loading returns:0 writing E:\FLASHER AND FLASHES\setool3\w810i flash files\R4ED001_S_ASIA_LEVAN_fs.ssw\R4ED001_S_ASIA_L EVAN_fs.ssw.cry CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:165 Will flash 165 blocks... Send superblock command NAK Elapsed:455 secs. one of the member says (Send superblock command NAK ).Is a hardware problem (i.e)nand ICproblem ...rehot or replace it I downloaded the schematics in the support site.But in the schematics diagram.The ic number only noted like N1100,N3200,D2200,N2600,etc... In these which number IC is nand IC?? Anyone can tell me which one is nand IC? |
06-28-2007, 13:19 | #78 (permalink) |
Freak Poster Join Date: Mar 2005 Location: india Age: 55
Member: 125424 Status: Offline Thanks Meter: 21 | k610i dead after unlocking cid49 please help.. Opening box. There is 1 ftdi devices v0.91380091/UNI Card serial:000109xx Loaded 51 flash descriptors ufs #274xx ready to work ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:353813010xxxxx CERT:RED FLASH CID:49 COLOR:RED phone CID not supported in that mode Elapsed:9 secs. ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:353813010xxxxx CERT:RED FLASH CID:49 COLOR:RED MAPP CXC article: R1CD001 prgCXC1250539_HUTCHISON_TH MAPP CXC version: R1CD001 Language Package:HUTCH_1 CDA article: CDA102497/46 CDA version: R14A Default article: cxc1250376 Default version: R1CD001 Network LOCKED Operator: MULTIPLE RESTORATION FILE NOT PRESENT "R1CD001_CXC1250539_HUTCHISON_TH" YOU MUST PERFORM FULL FLASHING FOR PATCH UNLOCK Elapsed:6 secs. NOW SET DEAD if not on costmer will kill me Last edited by amarjeet; 06-28-2007 at 15:00. |
06-28-2007, 16:03 | #81 (permalink) | |
No Life Poster Join Date: Jan 2002 Location: MARS
Member: 8304 Status: Offline Thanks Meter: 362 | Quote:
06-28-2007, 18:02 | #82 (permalink) |
No Life Poster Join Date: Oct 2005 Location: P A K I S T A N Age: 16
Member: 190344 Status: Offline Thanks Meter: 280 | why don"t you join http://www.************.com/forum/index.php. the best forum for sony ericsson |
06-28-2007, 18:04 | #83 (permalink) | |
Member: 190344 Status: Offline Thanks Meter: 280 | Quote:
06-28-2007, 19:03 | #84 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: WestSide Age: 38
Member: 254137 Status: Offline Sonork: 1592525 Thanks Meter: 275 | Quote:
Flash MAIN+FS Europe 2 and dont forget what to do in setting section UNLOCK after FLASH, | |
06-29-2007, 12:15 | #85 (permalink) |
No Life Poster Join Date: Feb 2003 Location: pakistan Age: 50
Member: 20646 Status: Offline Thanks Meter: 100 | w810i hi m8s i have a w810i . when we put it on the charger , it only blink once the there is a red light at the top. here is the log file v0.91380091/UNI Card serial:********** Loaded 51 flash descriptors Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35906300876031 CERT:RED FLASH CID:49 COLOR:RED MAPP CXC article: R4CE012 prgCXC1250316_GENERIC_HN MAPP CXC version: R4CE012 Language Package:T_MOB_INT_A CDA article: CDA102494/8 CDA version: R9A Default article: cxc1250324 Default version: R4CE012 Operator: 000-00 USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed:4 secs. ================================================== ======== unlocking................... v0.91380091/UNI Card serial:********** Loaded 51 flash descriptors Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35906300876031 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Trying to launch embedded bootloader... Embedded flashloader: COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 Flash ID check:2019 Flash props sent ok FOUND: R4CK003_CXC1250316_GENERIC_HN Restore from:R4CK003_CXC1250316_GENERIC_HN Setting up GDFS... IMEI MISMATCH !!!! POSSIBLE STOLEN PHONE !!!!! ORIGINAL IMEI:35906300876031 CURRENT IMEI:00000000000000 Clearing total time... sorry. maybe try again? Elapsed:547 secs. any idea? its sw problem or hw? any soulation ........... regards mahmood shad |
06-29-2007, 13:51 | #87 (permalink) | |
Banned Join Date: May 2003 Location: www.CentralMobile.net/vbb
Member: 28188 Status: Offline Thanks Meter: 579 | Quote:
have you nothing to do today except insulting my friend. I have seen more than 3 posts where you offense Infogsm. Infogsm is right in his statement. Davicnci is an enduser solution (50 euro) instead of Setool needs +50 logs for US $30 each one.(+ US $1500) Is not Infogsm right. Make the wars in the Cheaters Section. This section place seems to be your residence. (single use search button with Manole ) Best regards, Aishur | |
06-29-2007, 16:27 | #88 (permalink) | |
Member: 125424 Status: Offline Thanks Meter: 21 | Quote:
Opening box. There is 2 ftdi devices v0.91380091/UNI Card serial:000109xx Loaded 51 flash descriptors ufs #274xxready to work ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:353813010xxxxx CERT:RED FLASH CID:49 COLOR:RED phone CID not supported in that mode Elapsed:7 secs. how to fLASH | |
06-29-2007, 16:43 | #90 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: manchester, united kingdom Age: 39
Member: 288521 Status: Offline Thanks Meter: 685 | Quote:
setting (complete phone+unlock after flash+allow to change imei) thats all.. | |
again thanks setool team t280 hang repair with setool | kadricom | SETool2 | 1 | 04-03-2010 02:21 |
setool upgrade ****3012 setool card | gsm_eprom | Sony Ericsson | 0 | 01-30-2006 23:18 |
ITALIAN SETOOL MANUAL ( manuale setool in italiano ) | Dengel | Off Topic Zone | 10 | 06-27-2005 06:52 |
@SETOOL TEAM Big problam make SETOOL LG3G CABLE PLS HELP?? | Gsmfather.com | LG | 10 | 03-23-2005 12:06 |
