06-29-2007, 18:21 | #91 (permalink) |
No Life Poster Join Date: Apr 2006 Location: WestSide Age: 38
Member: 254137 Status: Offline Sonork: 1592525 Thanks Meter: 275 | Card serial:000269xx Loaded 51 flash descriptors Open COM port OK Abort all operations. Can't load id loader ! Elapsed:30 secs. SERVER SUPPORT ENABLED. Open COM port OK Abort all operations. phone pre-boot failed,possible RECOVERY needed. Elapsed:8 secs. Open COM port OK Abort all operations. phone pre-boot failed,possible RECOVERY needed. Elapsed:74 secs. Open COM port OK ChipID:8040,EMP protocol:0301 NEW SECURITY MODEL DETECTED PHONE IS RED RETAIL PRODUCT Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:354269016299xx CERT:RED FLASH CID:52 COLOR:RED MAPP CXC article: R4GB001 prgCXC1250719_GENERIC_ME MAPP CXC version: R4GB001 Language Package:EUROPE_2 CDA article: CDA102738/40 CDA version: R8A Default article: cxc1250728 Default version: R4GB001 Operator: 262-07 USERCODE:0000 RESTORATION FILE NOT PRESENT YOU MUST PERFORM FULL FLASHING FOR PATCH UNLOCK Elapsed:23 secs. ALTERNATIVE SECURITY BYPASS DISABLED ! CHECK EITHER "USE CARD" OR "USE SERVER" ! UNLOCK POSSIBLE OR NOT? |
06-29-2007, 18:21 | #92 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: lets See.
Member: 128918 Status: Offline Thanks Meter: 282 | Quote:
When u Have Chosen UFS Interface For DB2020 Phones. No Matter Sonn U will be Producing Dead Pieces to Other Countries. Always Use DCU-60 for DB2020 Man uspi3 Ur Phone is CID52 Don't touch it if u Wana Unlock it. Only Special Server Logs Can Do Next Step | |
06-30-2007, 00:16 | #96 (permalink) | ||
Cheater -Don't Deal with him- Join Date: Nov 2002 Location: Tunisia Age: 45
Member: 18022 Status: Offline Sonork: 1574868 Thanks Meter: 192 | Quote:
for the rest i think my freind aishur answered you !! 50euro is more cheaper then 1500$ idiot and neither you or laser know how to patch/unlock cid 52 so better close your ***** ! and about cheater everybody know who you are and who is your brother !! and instead of talking better work hard or learn from real brains (they are near you idiot you will see their next bomb exploding on your faceand your freind faces too ) Quote:
br | ||
06-30-2007, 16:50 | #97 (permalink) |
No Life Poster Join Date: Feb 2003 Location: pakistan Age: 50
Member: 20646 Status: Offline Thanks Meter: 100 | v630i dear after unlocking hi m8s v630i dead after unlocking now showing this v0.91380091/UNI Card serial:********* Loaded 51 flash descriptors Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35194101241833 CERT:RED FLASH CID:49 COLOR:RED set_gdfs_props failed, exiting Elapsed:3 secs. whats wrong with it ? regards mahmood shad |
06-30-2007, 17:20 | #99 (permalink) | |
Freak Poster Join Date: Jan 2005
Member: 108280 Status: Offline Thanks Meter: 1 | Quote:
Flash Main Firmware with "use server" ticked only and you phone will be fine. Then try unlock again Regards | |
06-30-2007, 19:04 | #100 (permalink) |
Banned Join Date: May 2003 Location: www.CentralMobile.net/vbb
Member: 28188 Status: Offline Thanks Meter: 579 | Hi Code: and on "identify" it will show Code: ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:00000000000000 CERT:RED FLASH CID:49 COLOR:RED set_gdfs_props failed, exiting Elapsed:8 secs. solution: first, get normal 4in1/ufs cable (with both ports soldered and good pinout) next, select interface com/ufs semc tab, select proper model. settings, check ONLY "use server", add to flash files ONLY main firmware image, situable for selected model press flash check if phone turning on. it should. Recommanded readings are here Best regards, Aishur |
06-30-2007, 20:57 | #101 (permalink) | |
Registered User Join Date: Nov 2003 Location: wolverhampton Age: 59
Member: 45229 Status: Offline Thanks Meter: 1 | k800 orange need rest file Quote:
can u upload the rest for R1GB001_CXC1250212_ORANGE_WI" killed it last night need help hear is log file v0.91380091/UNI Card serial:00028653 Loaded 51 flash descriptors SERVER SUPPORT ENABLED. SERVER CREDITS LEFT/USED: 15/15 CARD COUNTERS: FLASH 6, UNLOCK 5 Elapsed:13 secs. SERVER SUPPORT ENABLED. RECOVERY MODE STARTED DB2020 EROM UPGRADE STARTED OTP LOCKED:1 CID:51 PAF:1 IMEI:35570401007096 CERT:RED FLASH CID:51 COLOR:RED Flash ID check:897E Flash props sent ok EROM UPGRADE CAN'T FIND QUALIFIED PART Elapsed:6 secs. SERVER SUPPORT ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:51 Speed:460800 OTP LOCKED:1 CID:51 PAF:1 IMEI:35570401007096 CERT:RED FLASH CID:51 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok bypassing DB2020 security... done,restarting... ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:51 Speed:460800 Trying to launch embedded bootloader... Embedded flashloader: DB2020_PRELOADER_FOR_SETOOL2 Flash ID check:897E Flash props sent ok FOUND: R1GB001_CXC1250212_ORANGE_WI Restore from:R1GB001_CXC1250212_ORANGE_WI can't open file "C:\Program Files\FoneFunShop Setools\rest\R1GB001_CXC1250212_ORANGE_WI" full sig complete. USERCODE reset to "0000" Searching... Can't find lock check Unlock Done Elapsed:61 secs. | |
07-02-2007, 11:03 | #102 (permalink) |
Freak Poster Join Date: Feb 2005 Age: 45
Member: 113892 Status: Offline Thanks Meter: 57 | i don't find rest file for this k610i v0.91380081/UNI Card serial:XXXXXXXX Loaded 51 flash descriptors Opening box. There is 1 ftdi devices ufs #XXXX ready to work ChipID:9900,EMP protocol:0301 Speed:460800 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35170901655417 CERT:RED FLASH CID:49 COLOR:RED MAPP CXC article: R1CB001 prgCXC1250537_ORANGE_TH MAPP CXC version: R1CB001 Language Package:ORANGE_GEN CDA article: CDA102497/32 CDA version: R14A Default article: cxc1250376 Default version: R1CB001 Network LOCKED Operator: 208-01 Elapsed:8 secs. |
07-02-2007, 12:51 | #103 (permalink) |
Member: 128918 Status: Offline Thanks Meter: 282 | Flash ur Phone with MAIN+FS Settings -Complete Phone -Unlock Phone -Use Server -Enable Alternate Secuirty No Need Rest File Do it and Post ur Result BR,,, |
07-02-2007, 13:09 | #104 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Inside facebook Age: 47
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | Quote:
Better flash main as choose option unlock after flash. All procedure will take only 1. @USPI3 I can unlock all DB2020 including CID52 and PNX5230 in my office. Offtopic: UNLOCK ALL BB5 AVAILABLE IN CONAKRY TOO !!! | |
07-02-2007, 14:10 | #105 (permalink) | |
FLash+Unlock Just 1 Credit BR,,, | |
again thanks setool team t280 hang repair with setool | kadricom | SETool2 | 1 | 04-03-2010 02:21 |
setool upgrade ****3012 setool card | gsm_eprom | Sony Ericsson | 0 | 01-30-2006 23:18 |
ITALIAN SETOOL MANUAL ( manuale setool in italiano ) | Dengel | Off Topic Zone | 10 | 06-27-2005 06:52 |
@SETOOL TEAM Big problam make SETOOL LG3G CABLE PLS HELP?? | Gsmfather.com | LG | 10 | 03-23-2005 12:06 |
