02-26-2010, 16:24 | #1 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Americas Age: 44
Member: 43802 Status: Offline Thanks Meter: 36 | w380a, can it be converted to W380i is this a software change or does it also need hardware change ? |
02-26-2010, 17:28 | #3 (permalink) |
Member: 43802 Status: Offline Thanks Meter: 36 | has anyone personally done this and it works without problems . Someone is buying the phone to use in a 900 mhz only area. so it would be a costly venture, thus want to be sure. |
03-24-2013, 18:18 | #5 (permalink) |
Major Poster Join Date: May 2012 Location: Cuba
Member: 1759121 Status: Offline Sonork: 100.1625076 Thanks Meter: 9 | BIG GRAND SOLUTION PROMISE ARE PROMISE First in the World W380a and W350a converted to W380i and W350i 900 Mhz and 850Mhz and process must work in all PNX phones 1- Write Script Cuadband of W200 2- Write firmware APP and FS 3- Hardware Changes Please Give your Thank´s for more solution write me. Good Look |
03-25-2013, 22:52 | #6 (permalink) |
Member: 1759121 Status: Offline Sonork: 100.1625076 Thanks Meter: 9 | Here the picture [IMG]C:\Documents and Settings\Administrador\Mis documentos\Descargas\W380\W380i\W380a to W380i and W350a to W350i-2.JPG[/IMG] |
04-07-2013, 17:46 | #10 (permalink) |
Member: 1759121 Status: Offline Sonork: 100.1625076 Thanks Meter: 9 | Responding a menssage for clearing douds Well, you download a picture??? in the picture you can see how you can convert this phone to 900 or 850 and invert. you most use wire when you remove N5704 component. in case of Z6122 component if this component is damage you must remove and make a jumper. like a picture show, no need remove. and Z6120 componen must by remplased using a capacitor with range from 15p tested to 22p. here using a wire I not try if you maked and work fine you post your experience. |
cdma k1m can it be convert to k1 gsm phone? | mccm | Motorola Hardware Repair | 2 | 04-05-2008 00:15 |
HOW CAN IT BE POSIBLE TO OPEN 850 BAND TO K790i | denisirias | Cruiser Suite | 0 | 01-22-2008 19:34 |
Can C81 be converted to S75? | ddgsm | S-Gold Based Phones | 0 | 09-28-2006 22:51 |
can 5130 be converted to dual band? | s4sajii | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 12-02-2001 12:37 |
