12-06-2008, 03:10 | #17 (permalink) |
Crazy Poster Join Date: Nov 2008
Member: 901121 Status: Offline Thanks Meter: 3 | RJ45 Connector is used to spy phone's point out without connect to 24pins connector. If you found TX and RX point, just solder to the 2 points with any color of cable's color because of VePro will auto spy it. If you didn't found any mark of TX or TX on the board, solder all the cable to the phone's board available soldering point. |
The Following User Says Thank You to VE-BOX100 For This Useful Post: |
12-12-2008, 19:43 | #23 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 624567 Status: Offline Thanks Meter: 256 | 100%%%%%%% solution........................... Flashed many sets................. get any rj45 cable and cut it from otherside...... now 2: rx 3: tx 8: gnd its a complete universal rj45 cable use it its grat working meeeeee........ |
The Following User Says Thank You to sahil00150 For This Useful Post: |
Is there anyway to unlock the C139 trackfone with no testpoints | etimoult | Infinity-Box | 0 | 06-05-2008 18:11 |
is there anyway to fix a60 buzz problem with martech? | ddhorn | Martech CLIP / Box / Key | 3 | 12-08-2006 15:51 |
Is there anyway to have more txt messages in the inbox | stukachu | Sharp | 0 | 11-27-2003 12:47 |
is there anyway to edit call duration time on8210? | excespeace | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-27-2002 22:05 |
Is there anyway to reset the user lock on GD93? | NUGSM | Panasonic | 1 | 10-03-2001 13:34 |
