Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Ve Box > VE-PRO BOX
Old 09-04-2008, 03:15   #1 (permalink)
rk_grover77's Avatar
Member: 142191
Sonork: 100.1589775
Thanks Meter: 297
Is there anyway to use vepro with rj45 cable n how.
hello
is there any way to use vepro with rj45 cable as we use in infinity...because sometime vepro cant find correct pinouts (mostly sigmatel cases)..then we can attact direct rx tx gnd which was on board..plzz anyone tell the solution..
Old 09-06-2008, 02:28   #2 (permalink)
Member: 142191
Sonork: 100.1589775
Thanks Meter: 297
where is supporter to help us plzzzzz...?
Old 09-06-2008, 03:12   #3 (permalink)
Member: 811759
Thanks Meter: 14
above all, find tx and rx on the board, then use any two lines of rj45 to connect with them. .....
Old 09-06-2008, 05:38   #4 (permalink)
biochemistali's Avatar
Member: 190344
Thanks Meter: 280
Bonnie_xuan you are totally wrong.seem u have never worked with china mobiles....
right answer is
cut any jaf rj45 cable.use as under
Red coloured cables is rx ie pin no 2 from left for my cable
green tx pin no 3 from left side
black gnd pin no 9 from left
(while locating number of pins, hold it in the same way , direction u are inserting the cable in the box. understand)
br
hamid
Old 09-10-2008, 11:32   #5 (permalink)
sahil00150's Avatar
Member: 624567
Thanks Meter: 256
no solution till now.....................................
Old 09-10-2008, 11:43   #6 (permalink)
Crazy Poster
Member: 639200
Thanks Meter: 10
use infinity/furious/uni r45 open cable
rx7
tx8
this is for ve-pro rj45 port...
gud luck
br
Old 09-11-2008, 13:32   #7 (permalink)
Member: 142191
Sonork: 100.1589775
Thanks Meter: 297
no support in this section from ve...plz reply supporter...if there is no rx tx define on charging jeck how we format the set...????
Old 09-11-2008, 14:01   #8 (permalink)
joni_rajpura's Avatar
Member: 508072
Thanks Meter: 1,621
i think there is no way to connect vepro with infinity
Old 09-11-2008, 15:22   #9 (permalink)
Member: 142191
Sonork: 100.1589775
Thanks Meter: 297
i hvnt ask how to connect vepro with infinity. plz read carefully...
Old 09-12-2008, 15:02   #10 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Exclamation
use this pinouts of rj45 connector.
100%worked.
http://www.freeimagehosting.net/uploads/5c65eb5249.jpg
Old 09-13-2008, 16:32   #11 (permalink)
Member: 142191
Sonork: 100.1589775
Thanks Meter: 297
this is for infinity box....not for vepro..as infinity hv 8 pin adoptor and vepro hv 10pin adoptor..
Old 09-14-2008, 20:39   #12 (permalink)
yawarniazi's Avatar
Member: 194128
Thanks Meter: 303
Originally Posted by rk_grover77 View Post
hello
No confusions, no difficulties>>>>
Just get a "RJ45 Female" connector and connect any 8 wires of "RJ48 Cable" which is shipped with your vepro box. Now your RJ48 connector is converted to RJ45. Tested by me, I am using Infinity Box cables through this RJ45 converter.
BEST OF LUCK.
yawarniazi
Old 09-17-2008, 20:34   #13 (permalink)
..::Ahsan::..'s Avatar
Member: 604795
Thanks Meter: 822
PM the product supporter...
Old 09-18-2008, 04:45   #14 (permalink)
Member: 142191
Sonork: 100.1589775
Thanks Meter: 297
plz give me ur yahoo id yawarniazi.
Old 09-18-2008, 04:54   #15 (permalink)
Member: 142191
Sonork: 100.1589775
Thanks Meter: 297
plz supporter give RJ45 pinouts definition for vepro box as spiderman box has discribed for there box..
http://forum.gsmhosting.com/vbb/showthread.php?t=483651
Is there anyway to unlock the C139 trackfone with no testpoints etimoult Infinity-Box 0 06-05-2008 18:11
is there anyway to fix a60 buzz problem with martech? ddhorn Martech CLIP / Box / Key 3 12-08-2006 15:51
Is there anyway to have more txt messages in the inbox stukachu Sharp 0 11-27-2003 12:47
is there anyway to edit call duration time on8210? excespeace Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-27-2002 22:05
Is there anyway to reset the user lock on GD93? NUGSM Panasonic 1 10-03-2001 13:34
Page generated in 0.17726 seconds with 9 queries
