Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 07-18-2014, 18:25   #1 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
[Guide] HTC ONE Hboot 1.57 Root S-Off Change CID Downgrade Hboot & OS
HTC ONE M7_UL Sense 6 OS 4.4.2 Hboot 1.57 S-Off & CID Change & Downgrade Hboot + Main Version
Strp - 1 Bootloader Unlocking
First We Need To Unlock Bootloader Use Any Good Tool Or Htcdev(dot)com Website For Bootloader Unlocking if You Dont know how Use Search Function You Will Find Many Post About How To Unlock Bootloader Also On Google Too.
Step - 2 CWM Flashing & Root
After Unlock Bootloader We Need To Flash Custom Recovery For M7_UL TWRP Recovery Is Best So Put Phone in Fastboot Usb Mode & Open Command Windows In Adb Folder & Put TWRP Recovery in adb Folder Too Now Use Command
fastboot flash recovery TWRP-recovery.img
After Successfully Write TWRP Now Reboot Handset In Normal Mode And Copy
Super-Su.Zip Into Handset Internal Memory & Again Go Into Recovery Mode
And Select install Option From Recovery Home Menu And Select Super-Su.zip From Internal storage And Flash.
Now Reboot Handset To Normal Mode And Go Application Menu & Open Super Su App It Will Gives You 2 Options Flash Super su Normal Mode Or Via TWRP
Select TWRP (Important Otherwise Super SU Not Install) Now Wait handset Will Reboot Into TWRP And Installing Super SU After Installation Handset Will Reboot Into Normal Mode Now Check Super SU Installed & Fully Working You Are Done Handset Now Rooted & TWRP Installed
Step - 3 Flash Custom Rom & Kernel If You Need S-Off On 4.4.2 Hboot 1.57
For Flashing Custom Rom If You Need S-Off On 4.4.2 Hboot 1.57 You Need To
Copy cm-11-NIGHTLY-m7ul.zip + CM11-Kernel-For-S-Off.zip Into Ur Handset Internal Memory After Copy zips Go Into TWRP Recovery & Wipe Data , Cache , Delvik Cache After Format Now Select Install Option & Select cm-11-NIGHTLY-m7ul.zip First Now Click On Add More Zip Option & Select CM11-Kernel-For-S-Off.zip & Flash Wait Until Flashing Done When Flashed Successfully Dont Reboot Handset Go Back Recovery Home Menu & Select Reboot Option And Select Reboot To Bootloader Option You Will See Again Handset Again On Fastboot USB Mode Now Again Open Command Window In ADB Folder & Copy boot.img Into ADB Folder. Now Use This Command
fastboot flash boot boot.img
After Successfully flashed boot.img Use Command fastboot reboot
Handset Will Reboot Into Normal Mode You Are Done Custom Rom Installed + Custom Kernel For S-Off On 1.57
Step - 4 Firewater S-Off On 4.4.2 Hboot 1.57 M7_UL
After Flash Custom Rom & Custom Kernel Now you can S-Off Ur Handset With Firewater. Go Into Setting / About device / Software information / More Baseband Information / Tape 7 To 8 Time On Build Number\Version Developer Mode Enable On Ur Handset Now Go Back To Main Setting Menu & Select Developer Mode And On USB Debugging Go Back Main Setting Menu And Select Super SU Option Now Go Into Super Su Setting & Change Super Su Permission Only Apps To Apps & ADB Now Open Command Window In ADB Folder & Copy Firewater In ADB Folder And Use Commands Like This
adb reboot <–important!!!! Means Must Use This Command First
adb wait-for-device push firewater /data/local/tmp
adb shell
su
chmod 755 /data/local/tmp/firewater
Answer Yes With Capital Y And Wait Till It Says Your Device Is S-OFF
Dont Touch Ur Device During This Process You Will Get Msg ur Device is Now S-Off Congratulations You Are Done With S-Off Want To See ? Go Into Bootloader You Will See S-Off There
Step - 5 Changing CID To Any Or Super CID After S-Off
After S-Off Changing CID Is Very Simple & Easy Put Handset Into Fastboot USB Mode. Open Command Windows In ADB Folder And Use 1 Simple Command For Changing CID To Any Other You Want or Super CID
For Super CID
fastboot oem writecid 11111111
Or Any Other Just Replace 11111111 To Any Like HTC__001 ETC After Successfully Change CID Use This Command
fastboot reboot-bootloader
Handset Will Reboot Into Bootloader Again & Your Handset CID Now Changed
You Are Done This Step
Step - 6 Downgrade Hboot From 1.57 To Any Older After S-Off For Downgrade OS Version
After S-Off Downgrading Hboot Is Also Very Simple & Easy If You Want To Use Any Older Version. You Need Ur Required hboot Firmware zip And ADB Package. Put Handset Into fastboot USB Mode And Copy hboot Firmware Zip Into ADB Folder Now Open Command Window In Adb Folder And Use This Command fastboot oem rebootRUU Ur Handset Will Go Into RUU Mode
Now Use Command As Ur Choice Of Hboot Version Witch You Want
fastboot flash zip hboot-1.43.zip
If 1.44 Then
fastboot flash zip hboot-1.44.zip
If 1.54 Then
fastboot flash zip hboot-1.54.zip
If 1.55 Then
fastboot flash zip hboot-1.55.zip
If 1.56 Then
fastboot flash zip hboot-1.56.zip
After Successfully Flashed Zip Now Type Command
Handset Rebooted To Bootloader Again Now
Check ur Hboot Version Downgraded & You Are Done With Hboot
Now Use This Post If You Want Downgrade M7_UL Stock Roms
http://forum.gsmhosting.com/vbb/f485...loads-1677358/
All These Files Are In 1 Package Download With Resumable Link In This Zip
All Things Have Witch You Need Custom Rom , Custom Kernels , Firewater , TWRP , Super-Su , hboot zips Download Click Downlad Link Below
HTC One M7 4.4.2 S-off.zip
Br,
..::Rizwan::..
The Following 8 Users Say Thank You to ..::Rizwan::.. For This Useful Post:
Old 07-19-2014, 23:36   #2 (permalink)
Member: 2225573
Hi Rizwan,
Thanks very much for your tutorial. I'm stuck though, after all the steps, my adb shell exits with no messages while firewater is chugging the first bottle. The phone reboots, but still s-on. Any ideas??
Old 07-20-2014, 00:47   #3 (permalink)
Member: 2225573
Ok, I was able to finally get this to work. Some info in case it helps anyone:
HBOOT 1.57
T-Mobile One M7
cm-11-20140106-NIGHTLY-m7tmo
teaMseven_v57_CM11_CPUQUIET_BACK_MENU_HOME
Did as above, although firewater failed the first few times. I rebooted and kept trying, third time was successful. My phone is now s-off
Old 08-18-2014, 08:00   #4 (permalink)
Member: 2242058
Hi I am Enrico.
Is It possible to flash rom and kernel with hboot 1.57 on a device with hboot 1.56?
Old 08-25-2014, 18:23   #5 (permalink)
Member: 2072045
Hi guys. Will this work on one m7-ul , android 4.4.3, hboot 4.4.3 ? I have tried before but I always get the same message from firewater... It goes from bottle 1 to 12, and it always says this bottle is empty, trying bottle number (x) and so on, and in the end it tells me all bottles are empty and that I should restart my device and try again... I tried doing this on 2 different computers,and used 2 different usb cables... I have also tried all kinds of combinations of kernels and roms... I have root, unlocked bootloader and custom recovery.. I havent yet tried that combination from first post.. Please tell me why do I get from bottle 1-12 without getting s-off. Thanks in advance
Old 09-02-2014, 17:45   #6 (permalink)
Member: 1726004
Once you are there, nothing happens.
Old 09-20-2014, 08:59   #7 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Originally Posted by enrico.tugnolo View Post
Hi I am Enrico.
What you say?, here is all procedure for DOWNGRADE 1.57 becouse have new security and is more complicate make S-OFF with hboot 1.57 and you that have hboot 1.56 more easy for to make S-OFF and supercid want upgrade?, explain the razon of this please
br
allumts
Old 09-20-2014, 10:10   #8 (permalink)
raselopu's Avatar
Member: 485407
Sonork: 100.1580486
Thanks Meter: 183
br
allumts
@ ..::Rizwan::..,allumts
Is it all about hboot?
Let's talk about hboot 1/54.0000, M7_WLJ , S-ON
You can't unlock bootloader from htcdev
Can you please tell/guide how to s-off this crap (HTL22..One from AU JAPAN)?
Old 09-27-2014, 18:23   #9 (permalink)
allumts's Avatar
Member: 1564612
Say right.....CRAP Htc, only with Box you can try...if support CRAP model and Cid.
Old 09-27-2014, 18:33   #10 (permalink)
allumts's Avatar
Member: 1564612
FOR ALL:
Update the "Firewater that is in package above, is obsolete, use this:
firewater.rar
Only Thannks button
_______
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 11-05-2014, 06:28   #11 (permalink)
Crazy Poster
Member: 1726256
Sonork: 100.1640858
Thanks Meter: 8
this works for Sprint HTC One also , have to download sprint cmw rom .
unable to download screenshot . works for me
Thanks
Old 11-05-2014, 22:08   #12 (permalink)
allumts's Avatar
Member: 1564612
Thanks
Try and test...also Sprint is CDMA phone, but if nobody try and share cannot know the result,
allumts
Old 11-10-2014, 07:40   #13 (permalink)
Member: 2289949
firewater is not work on my HTC DESIRE X DUAL SIM T329w please help me how to get s-off on my phone please reply fast and sorry for bad english
Old 11-11-2014, 06:17   #14 (permalink)
technisoft's Avatar
Member: 1914596
Sonork: 100.1619364
Thanks Meter: 59
Wink HTC One SPRINT 4.4.2 HBOOT 1.57 Unlocked
Yes i tryed to downgrade and unlocked this htc sprint
You can contact me here to helpful
you will get successfully :
1-Unlocked Bootloader
2-S-OFF
3-Downgrade
4-Sim Lock removed
and if you want
5-Update to 4.4.2
Old 11-11-2014, 12:38   #15 (permalink)
allumts's Avatar
Member: 1564612
Start to posting in Rigth thread, this isn't procedure for DESIRE X DUAL.
Page generated in 0.36080 seconds with 8 queries
