HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
02-24-2015, 06:35 | #1 (permalink) |
No Life Poster Join Date: Dec 2012 Location: vadodara
Member: 1849215 Status: Offline Thanks Meter: 136 | HTC M7_UL,CID : TELST001 Stuck On Logo E- unable to mount cache any guide how to update pation sir |
The Following User Says Thank You to sunil1670 For This Useful Post: |
02-24-2015, 07:19 | #2 (permalink) |
Member: 1849215 Status: Offline Thanks Meter: 136 | C:\>fastboot getvar all INFOversion: 0.5 INFOversion-bootloader: 1.55.0000 INFOversion-baseband: 4A.21.3263.04 INFOversion-cpld: None INFOversion-microp: None INFOversion-main: 3.62.841.1 INFOversion-misc: PVT SHIP S-ON INFOserialno: HT35LW914327 INFOimei: 355859051614121 INFOmeid: 00000000000000 INFOproduct: m7_ul INFOplatform: HBOOT-8064 INFOmodelid: PN0714000 INFOcidnum: TELST001 INFObattery-status: good INFObattery-voltage: 3992mV INFOpartition-layout: Generic INFOsecurity: on INFObuild-mode: SHIP INFOboot-mode: FASTBOOT INFOcommitno-bootloader: dirty-bb768ae1 INFOhbootpreupdate: 11 INFOgencheckpt: 0 all: Done! finished. total time: 0.063s this my info |
02-24-2015, 07:24 | #3 (permalink) | |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
fastboot erase cache use latest custom recovery try diff recovery twrp or philz recovery Relock yur bootloader nd check if unable to relock yur bootloader may b hardware. if relocked successfully again flash any latest custom recovery wipe data system delvik cache flash the rom via recovery . | |
02-24-2015, 07:31 | #4 (permalink) |
Member: 1849215 Status: Offline Thanks Meter: 136 | C:\>fastboot erase cache erasing 'cache'... OKAY [ 0.063s] finished. total time: 0.063s now further trying sir C:\> |
02-24-2015, 07:57 | #5 (permalink) | |
Member: 1849215 Status: Offline Thanks Meter: 136 | bootloader relock done it seems its not a hardware issue sir again going to unlock and flash recovery and post results 1 question for flash by recovery we need superusers installed because i am not rooted sir? Quote:
02-24-2015, 08:01 | #6 (permalink) |
No Life Poster Join Date: Oct 2010 Location: India Age: 31
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | For flash recovery no need supersu or root,what you need unlocked bootloader. About error mounting cache ignore it for now and try to restore nandroid,when partition dead or erased you will always get error mounting. |
The Following 3 Users Say Thank You to Rahul_Bhutani For This Useful Post: |
02-24-2015, 08:24 | #9 (permalink) |
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | Card or pendrive you using is fat32 formatted ? Another way is mount usb storage and connect phone to usb and copy rom in internal drive. |
The Following User Says Thank You to Rahul_Bhutani For This Useful Post: |
02-24-2015, 08:37 | #11 (permalink) |
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | Extract rom and flash boot.img from fastboot and post result |
02-24-2015, 08:53 | #12 (permalink) |
Member: 1849215 Status: Offline Thanks Meter: 136 | i had installed again viper rom.zip by format user data option enable now condition is handset starts till htc one (beatsaudio) logo and after 1min restarts again . |
02-24-2015, 09:02 | #13 (permalink) |
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | You flashed boot.img or not,its important to boot the phone. |
02-24-2015, 09:06 | #14 (permalink) |
Member: 1849215 Status: Offline Thanks Meter: 136 | Thanks for your attention Rahul sir, but after flashing again my phone comes at lock screen when i slide up for setting languages and all it hangs at second boot htc logo and restarts sir i had flashed boot.img also sir |
02-24-2015, 09:34 | #15 (permalink) |
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | In order to run viper 7.X.X version you need latest hboot and you are still on old Download latest hboot from link below and flash to your phone. "fastboot oem rebootRUU" Wait phone to reboot in black display. "fastboot flash zip firmware_6.11.841.7.zip" Wait to finish reboot and check your phone. PS: All command are without quote mark. PS: In case after flash zip still same,flash again boot.img from viper zip. firmware_6.11.841.7 |
