PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic |
01-28-2009, 01:01 | #16263 (permalink) |
Freak Poster Join Date: Jan 2009 Location: Texas
Member: 951433 Status: Offline Thanks Meter: 45 | After getting Resco Backup to load, I installed the KG from V2201 to get my serial, then deleted KG & reinstalled Resco Backup & NOW it is crashing my phone again....Safe****d says that CallBlock is causing the crash, but I don't have CallBlock enabled. This is becoming frustrating! |
01-28-2009, 01:09 | #16265 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: New York where the Giants roam Age: 34
Member: 457382 Status: Offline Sonork: 700p, Centro, Pre, Evo, I Thanks Meter: 4,365 | Quote:
The problem is safe****d...... I used to have installed on my device and I started to get alot of resets...... I uninstalled it and I had no more resets..... safe****d is no good If the resets persists after safe****d is uninstalled, then it already have done damage......you will have to hard reset and install everything over again......... That's what I did...... | |
01-28-2009, 01:16 | #16268 (permalink) |
Member: 951433 Status: Offline Thanks Meter: 45 | Thanks King...I did a Warm Reset & now Resco Backup works again. I guess I will uninstall Safe****d. Now that mention it, I believe most of my problems have been since installing it. Thanks for the good help! |
The Following User Says Thank You to mothemak For This Useful Post: |
01-28-2009, 01:21 | #16269 (permalink) | ||
The app uses your device code to register.....so I can't generate a code for you.......you will have to use the keygen on your palm so that it can use your device code to generate a key for you...... Use the keygen below.... Quote:
01-28-2009, 01:53 | #16272 (permalink) |
Junior Member Join Date: Jan 2009
Member: 957617 Status: Offline Thanks Meter: 0 | Hello, how is everyone? Just wondering if someone has the register code for Astraware Casino? (http://www.astraware.com/palm/featured/casino/?skucode=0089-000-0544) Your help will be greatly appreciated! My Hotsync Id is NeilT. Thank you very much and Go Steelers! |
01-28-2009, 02:00 | #16273 (permalink) |
Freak Poster Join Date: Aug 2008
Member: 840905 Status: Offline Thanks Meter: 131 | Whats Up Hey everyone. I'm currently in the process of building a pc and im stuck in a dilema. I am going to have to wip my HD clean of everything and that means all my stuff from hotsync manager and palm desktop. My concern is when i reinstall all my programs will i be able to install hotsync manager and still hotsync my phone with no problems or will my phone lose all data because of the clean install. Do i need to back anything up? If so what. thanks for the help people. |
01-28-2009, 02:06 | #16274 (permalink) | |
Member: 453630 Status: Offline Thanks Meter: 1,661 | Quote:
Astra ID: 732272 6NA8QGP3 WHHSUMA4 H394FF3H3 MBNULZ64 | |
01-28-2009, 02:18 | #16275 (permalink) |
Insane Poster Join Date: Sep 2008
Member: 868665 Status: Offline Thanks Meter: 43 | Hi. I have a problem with ZLink k**g** for some hotsync id that does not register - always wrong code, I think it happens because it is only 3 digits long (?!...). Is there ant p*t*h I can use instead? On other topic, I do not really understand the g u a r wierd thing... But the truth is I do not write it straight either... |
Pocket PC Appz & Games | HuBMOBILE | HTC & PDA WM( With Touchscreen) | 8203 | 12-05-2019 14:12 |
Nokia Latest Appz & Games Section | HuBMOBILE | Nokia Multimedia | 17 | 11-21-2010 14:03 |
Palm OS Appz & Gamez | LBOZ_GSM | PalmOS /HP and others | 1014 | 05-05-2009 21:45 |
Nokia N73 Appz and games collection.Binpda+get unsigned appz signed with secman.100% | usman8416 | Nokia Multimedia | 0 | 06-24-2008 21:01 |
WM5 Pocket PC Appz & Games | eboy44 | HTC & PDA WM( With Touchscreen) | 2 | 08-08-2006 22:23 |
