PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic |
02-17-2009, 18:26 | #17011 (permalink) |
Insane Poster Join Date: Aug 2008
Member: 836053 Status: Offline Sonork: guerreiro Thanks Meter: 79 | Call rec is reseting |
02-17-2009, 18:33 | #17012 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Around
Member: 416272 Status: Offline Thanks Meter: 1,095 | Quote:
RS | |
The Following 3 Users Say Thank You to RogueSaber For This Useful Post: |
02-17-2009, 19:54 | #17016 (permalink) |
Junior Member Join Date: Jan 2009
Member: 945559 Status: Offline Thanks Meter: 3 | how to exit Mrs. Pacman does anyone know how to exit out of Mrs.Pacman on a Centro I think I've tried every button, I ended up having to take the battery off thanks in advance |
02-17-2009, 21:40 | #17017 (permalink) | ||
(Make sure all 5 files are installed) This is the full (purchased) app. Works on: Handspring Treo 600, Palm Centro, Treo 600, Treo 650, Treo 680, Treo 700p, Treo 755p, Quote:
RS | ||
The Following User Says Thank You to RogueSaber For This Useful Post: |
02-17-2009, 22:19 | #17018 (permalink) |
Major Poster Join Date: Feb 2009 Location: Baton Rouge
Member: 961466 Status: Offline Thanks Meter: 11 | I am trying to load Java on my palm and downloaded Java 5.7.2 but there are tons of files in the zip. Which one do I need to install? Any help would be appreciated....I remember long ago I downloaded just one file and installed it.....?? Thanks, Peter |
02-17-2009, 23:51 | #17022 (permalink) | |||
Freak Poster Join Date: Dec 2008 Location: Belize City, Belize Age: 42
Member: 926677 Status: Offline Thanks Meter: 146 | Quote:
Look for keygen, here the guys already took sometime to explain on how to use them... Hope this helps Ron | |||
The Following 5 Users Say Thank You to ron2k_1 For This Useful Post: |
02-17-2009, 23:54 | #17023 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: Porto, Portugal
Member: 718168 Status: Offline Sonork: Treo650 507mhz, Nokia5800 Thanks Meter: 441 | Quote:
Butler and powerhero need to be disabled first, lets do it another way. Uninstsall all 3 and test crossnum, if it still resets thsn its not theses apps. If it doesn´t reset than instal one by one and crissnum each time. | |
The Following User Says Thank You to r_castro For This Useful Post: |
02-17-2009, 23:56 | #17024 (permalink) |
Member: 926677 Status: Offline Thanks Meter: 146 | Instead of BellTime, I recommend Butler 5.15 thou, search you will find it here, and use the hobbyist keygen, which is here as well (Go to the attachment page https://forum.gsmhosting.com/vbb/f487/ ) Install both prc's and run hobbyist kg and select Butler and generate a key, then run Butler and register with the serial generated. Then unistall kg. Hope it helped Ron |
Pocket PC Appz & Games | HuBMOBILE | HTC & PDA WM( With Touchscreen) | 8203 | 12-05-2019 14:12 |
Nokia Latest Appz & Games Section | HuBMOBILE | Nokia Multimedia | 17 | 11-21-2010 14:03 |
Palm OS Appz & Gamez | LBOZ_GSM | PalmOS /HP and others | 1014 | 05-05-2009 21:45 |
Nokia N73 Appz and games collection.Binpda+get unsigned appz signed with secman.100% | usman8416 | Nokia Multimedia | 0 | 06-24-2008 21:01 |
WM5 Pocket PC Appz & Games | eboy44 | HTC & PDA WM( With Touchscreen) | 2 | 08-08-2006 22:23 |
