PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic |
02-15-2009, 17:03 | #16936 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Porto, Portugal
Member: 718168 Status: Offline Sonork: Treo650 507mhz, Nokia5800 Thanks Meter: 441 | http://forum.gsmhosting.com/vbb/show...ostcount=15845 and these config for the fav tab: http://forum.gsmhosting.com/vbb/show...ostcount=15842 |
02-15-2009, 17:16 | #16937 (permalink) | |
Member: 718168 Status: Offline Sonork: Treo650 507mhz, Nokia5800 Thanks Meter: 441 | Quote:
Very few apps clean them selfs up, I only know of blazer. The rest rely on the system. If the app is big you shouldn't lock it in memory. Its all a balance in having more dbcache and background apps locked in memory. Rule of thumb, resco locker on top tells you how many apps are locked and how much the locked apps are taking from dbcache. I have 6 small/background apps. I also overclock but don't put the whole system just the apps that you need or apps that you go through them fast like a launcher, calender, etc... If you overclock a app to long and you notice the back of the device getting hot, you should stop and rethink your stetegy. Overclocking is very nice but its not the solution for apps that need to be on for very long, like pockettunnes, coreplayer, tcpmp. If its to watch short videos then your ok, but for a long 1 hour video, don't do it. When the device heats up it will crash to try to protect it self from damage. | |
02-15-2009, 17:16 | #16938 (permalink) | |
Freak Poster Join Date: Jan 2009 Location: Texas
Member: 951433 Status: Offline Thanks Meter: 45 | Quote:
02-15-2009, 17:21 | #16939 (permalink) |
Member: 718168 Status: Offline Sonork: Treo650 507mhz, Nokia5800 Thanks Meter: 441 | For alarms i use butler. But there are great apps out there, if you want weather theres treoalarm. For a advance alarms, i guess it would be crazyalarms. Mobileclock has cool feature that it can play a random mp3 on every alarm, this way you can wake up everyday with a different tune. |
02-15-2009, 17:23 | #16940 (permalink) |
Freak Poster Join Date: Nov 2007 Location: Where the Lakers RULE!!!
Member: 631598 Status: Offline Thanks Meter: 267 | Take a look at BellTimer. It is on this forum. It has a countdown feature to set off an alarm at the end of the countdown. It allows for several alarams to be set at once. So you could set one for 3 min one for 5 min one for 15 min etc. Hope this helps. |
The Following User Says Thank You to surfsup1 For This Useful Post: |
02-15-2009, 17:28 | #16941 (permalink) | |
Member: 631598 Status: Offline Thanks Meter: 267 | Call Block Quote:
I have call block installed and set up to block (ignore) text messages from two specific contacts but it doesn't block them. Initially, I had the app on the SD card and thought that might be the problem so I moved it to RAM but iti still doesn't block those text messsages. Am I missing a setting or something. Any help? Anyone? | |
02-15-2009, 20:44 | #16942 (permalink) | |
No Life Poster Join Date: Feb 2007
Member: 453630 Status: Offline Thanks Meter: 1,661 | Quote:
I have it on the phone and if you look at individual and group tab you need to assign what you want to block IE you can set this in individual or groups 1. group 2. vip 3. action allow or block call/sms 4.schedule 5. block method block call 6. incomming sms == here is were you set ignore message or delete.. let meknow if this work for you. this is my setting i used and it works as it suppose to block all call / sms | |
The Following User Says Thank You to saj070 For This Useful Post: |
02-15-2009, 23:00 | #16944 (permalink) | |
Everything you need is here follow instruction in txt file... http://www.megaupload.com/?d=40STXYCW | |
The Following 5 Users Say Thank You to saj070 For This Useful Post: |
02-15-2009, 23:24 | #16946 (permalink) | |
Member: 951433 Status: Offline Thanks Meter: 45 | Quote: Thanks Saj!!!...I have had nothing but trouble with the earlier builds. They said "too old version"...then I installed the demo 1.9R1 & no KG I could find would help, so I un-installed it. Then I found v1.8R1 that was patched, but somehow there is still some file(s) on the Palm that says I am trying o install on older version...bla, bla, bla...insisting that I install a more recent version. Now I won't have to fight with it...because v.1.9R1 was the newest one I had on my Centro. Thanks again! | |
02-15-2009, 23:31 | #16948 (permalink) |
Junior Member Join Date: Apr 2008 Location: Toronto
Member: 742910 Status: Offline Thanks Meter: 22 | Hi everyone: Just curious here: I have gotten audio gateway up and running nicely, and would really like to use it to watch movies in bed by streaming the audio of coreplayer to my bedroom speakers via bluetooth, but I find Audio gateway is taking up too much of the memory and video is too choppy to enjoy on my TX. Am I wishfull-thinking in technicolor, or is there something I can do about this to make my wireless experience "a beautiful thing"? By the way, i have tried using warpspeed to overclock both apps, but i is still choppy...is this normal? |
02-15-2009, 23:39 | #16949 (permalink) |
Member: 951433 Status: Offline Thanks Meter: 45 | Hey Rogue...I have a question for you. When you generate serials for other people, are you using a Palm emulator on your PC or some other method? I am just curious. I bet it would be much easier to get a serial using a emulator, seeing the files are already on the PC...would save some time. I appreciate your feedback. Thanks! |
02-16-2009, 00:04 | #16950 (permalink) | ||
Freak Poster Join Date: Dec 2008 Location: Belize City, Belize Age: 42
Member: 926677 Status: Offline Thanks Meter: 146 | CrossNums 1.4 update Quote:
After contacting the develper, it told me that it appears that "the persistent data may be corrupt" (have no idear what that meant !). Anyways, they told me to install a fresh copy from the site, don't really know why, that's where I initially got it from afterall. I did, what they said and as usual, it reset my centro after installation. I unistalled it (using uninstall) and reinstall it and use "LinkStart" to move it the SD Card. It is more stable from there, it hasn't yet reset my centro after tapping on the welcome screen. I changed the game number, and it does it with no problem. But listen to this... If I let my phone to go asleep (while playing the game), when I wake it up, it resets my phone. It may survive the first "wake", but if I let it consequitably (one after the other) to go asleep twice, it will, for sure, reset my phone on the second time (so far it hasn't reset my preferences and settings thou) (knock wood on that...). So I emailed the developer again and told them to look at that... Secondly, and it doesn't happen with the other games I have on my card (running with LinkStart). After my phone resets, because LinkStart exports the app to RAM so that it can run, and after the reset, I end up with two copies of CrossNums - one on RAM (left by LinkStart) and the copy on the SD card. I have to open the one on the SD Card and close it, so that it removes the other copy from RAM and it only leaves the link to the SD Card. So told them to look at that as well... I got an advice from somewhere else to try it on my phone fresh from a hard reset to see if there is another app clashing with this one... But this a tedious task to hard reset and load all applicatioins after that... so I decided to do what I did. Hope to hear if anybody has had similar problems so I can tell the developer as well... Thank you for you ears (I mean eyes...) Ron | ||
Pocket PC Appz & Games | HuBMOBILE | HTC & PDA WM( With Touchscreen) | 8203 | 12-05-2019 14:12 |
Nokia Latest Appz & Games Section | HuBMOBILE | Nokia Multimedia | 17 | 11-21-2010 14:03 |
Palm OS Appz & Gamez | LBOZ_GSM | PalmOS /HP and others | 1014 | 05-05-2009 21:45 |
Nokia N73 Appz and games collection.Binpda+get unsigned appz signed with secman.100% | usman8416 | Nokia Multimedia | 0 | 06-24-2008 21:01 |
WM5 Pocket PC Appz & Games | eboy44 | HTC & PDA WM( With Touchscreen) | 2 | 08-08-2006 22:23 |
