PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic |
12-19-2006, 19:51 | #3424 (permalink) | |
Freak Poster Join Date: Oct 2006
Member: 364604 Status: Offline Thanks Meter: 8 | Quote:
I see it is 9b3 back on the home page instead of the 9b4 I saw on there a few minutes ago. Not sure what that is all about but i'm sure it will keep getting better as more feedback comes through. | |
12-19-2006, 19:51 | #3425 (permalink) | |
Freak Poster Join Date: Nov 2006
Member: 390425 Status: Offline Thanks Meter: 4 | Buzz 1.0 Quote:
- I installed all 3 files. - I then opened up buzz and wrote down the Serial # - Then I installed the keygen - I used MultiUserHack to change the hotsync name for the KEYGEN to the serial # the orignal file gives you (the one you wrote down) - Run the keygen and it should give you the correct Reg Code and it registered fine! thanks a lot folks | |
12-19-2006, 20:50 | #3427 (permalink) | |
How do you convert the ROMS over so the Palm device excepts it? I know with like NesEm there is a ROM tool that converts them over, but I don't know how to do that with firestorm. Any suggestions from anyone that has used firestorm> | |
12-19-2006, 20:55 | #3429 (permalink) | ||
Crazy Poster Join Date: Nov 2006 Location: TREO 700P
Member: 400913 Status: Offline Thanks Meter: 7 | Quote:
Here are the formal instructions...the only thing I see in addition is the recommendation to add a zero to the number it gives you if necessary: Quote:
12-19-2006, 21:13 | #3430 (permalink) | |
Junior Member Join Date: Dec 2006
Member: 404562 Status: Offline Thanks Meter: 1 | Quote:
12-19-2006, 21:16 | #3431 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 363899 Status: Offline Thanks Meter: 38 | Use a card reader or card read program to put the roms directly into the firestorm file that is now on the card ,also I believe you can trick your hotsync into believeing that roms are .prc if you change the .rom or whatever to .prc then you can hotsync them and if they dont go into the proper file you could use zlauncher or something else to move them into the firestorm folder hope this makes sense anyway good luck it's alot easier than it sounds |
12-19-2006, 21:21 | #3433 (permalink) | |||
Freak Poster Join Date: Oct 2006 Location: www.th3palmz.com/th3palmz
Member: 361063 Status: Offline Thanks Meter: 2 | Quote:
Thank you so, so much for the feedback!! Have you figured out what the differences between pyramid and pyramania are? I thought it was weird that they were included in the code as options... but were hidden. They may not be finished or may be buggy or something, but I figured a new buggy option is better than a hidden buggy one. | |||
12-19-2006, 21:23 | #3434 (permalink) |
Member: 371901 Status: Offline Thanks Meter: 6 | |
12-19-2006, 21:23 | #3435 (permalink) | |
Tried the .prc and .pdb thing and when I changed them and then did a sync, they disappeared from the palm installer but didn't find them on the device. I'll try the other way. One thing I noticed was like 1942 on the Gameboy one is like 1mb and it is WAY smaller for the NesEm emulator I use. Not sure why this is. Guess i'll have to see how big the rest of the files are. No bid deal with an SD card, but 1mb versus 128kb Just seems odd. | |
Pocket PC Appz & Games | HuBMOBILE | HTC & PDA WM( With Touchscreen) | 8203 | 12-05-2019 14:12 |
Nokia Latest Appz & Games Section | HuBMOBILE | Nokia Multimedia | 17 | 11-21-2010 14:03 |
Palm OS Appz & Gamez | LBOZ_GSM | PalmOS /HP and others | 1014 | 05-05-2009 21:45 |
Nokia N73 Appz and games collection.Binpda+get unsigned appz signed with secman.100% | usman8416 | Nokia Multimedia | 0 | 06-24-2008 21:01 |
WM5 Pocket PC Appz & Games | eboy44 | HTC & PDA WM( With Touchscreen) | 2 | 08-08-2006 22:23 |
