PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic |
08-28-2008, 23:11 | #11716 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453630 Status: Offline Thanks Meter: 1,661 | toysoft sites....or if someone here has an account with toysoft they can download the updates and post on this thread for us...... But if you still want the patch let me know. perfect timing but how can we get he updates ??? thank kingtyce |
The Following User Says Thank You to saj070 For This Useful Post: |
08-28-2008, 23:31 | #11717 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: New York where the Giants roam Age: 34
Member: 457382 Status: Offline Sonork: 700p, Centro, Pre, Evo, I Thanks Meter: 4,365 | Quote:
If only you can update through the app itself......but since you can't, we will just have to wait for someone who has a toysoft account that can download the update for us or you can do it manually, by changing the scores, records and other stats within the app itself. | |
08-28-2008, 23:41 | #11718 (permalink) | ||
No Life Poster Join Date: May 2008 Location: C E B U C I T Y
Member: 774786 Status: Offline Thanks Meter: 1,455 | Quote:
if 'm not mistaken the only way to update this is if you have an account w/ toysoft as what KT said and it will be sent to you via email. i haven't known anyone here and in the other forums that boughtthis so goodluck to all of us. | ||
08-29-2008, 00:41 | #11719 (permalink) |
Freak Poster Join Date: Aug 2008
Member: 840905 Status: Offline Thanks Meter: 131 | No luck I still can't get audio gateway to work with my bt8040. I either here static or nothing at all. I have uninstalled audio gateway compltely and then reinstalled it. No luck. Is there any one out there that had this problem and managed to fix it. Please explain to me in detail on how you did it. Tell me the software versions you used and other info. Please help. |
08-29-2008, 00:55 | #11720 (permalink) | |
What Palm device do you have audio gateway installed on? | |
08-29-2008, 01:01 | #11722 (permalink) |
Member: 457382 Status: Offline Sonork: 700p, Centro, Pre, Evo, I Thanks Meter: 4,365 | Maybe that's your problem...... Try asking your question here.... http://www.softick-forum.com/viewtop...77b465e97f59e7 |
08-29-2008, 01:04 | #11723 (permalink) |
Member: 840905 Status: Offline Thanks Meter: 131 | Finally I got it to work just now. I uninstalled ptunes 4.07. I went back to ptunes 4.04. And installed Audio gateway. Put the serial in and opened ptunes (4.04) and it finally played. Is audio gateway not compatible with 4.07. Should i not upgrade ptunes anymore? That's weird. Thanks for the help crew. I know i bug like crazy. but thanks again. |
The Following User Says Thank You to mejia_mj For This Useful Post: |
08-29-2008, 01:07 | #11724 (permalink) | |
Congrats! | |
08-29-2008, 01:39 | #11725 (permalink) |
Member: 840905 Status: Offline Thanks Meter: 131 | Something Came up When i closed ptunes and went back to audio gateway it said that the software is for evaluation purposes and it only had 9 more days. i thought i put in the serial number. why did it ask me to register again? All i wanted to do was to disconnect the bluetooth from a2dp. Can you guys help me again. Is there possibly a patch some where for version 1.22? Thanks |
08-29-2008, 02:26 | #11727 (permalink) | |
Maybe they recoded the new versions of audio gateway......maybe the keygen does not generate the same code as official release. =TWX6-KS So the code it generates may not get through all the verification schemes within the app. So my suggestions is to uninstall version 1.22 because it may have registration issues......... Try this out. Here is version 1.20 | |
08-29-2008, 02:30 | #11728 (permalink) |
Member: 840905 Status: Offline Thanks Meter: 131 | strange When i reopened audio gateway it asked me for the serial . i put it in like usual and then it registered and then i played the music through ptunes and it was static again. i had to reinstall audio gateway to have it work again. Is there a right way and a wrong way in closing audio gateway? Im confussed on what happened. |
08-29-2008, 14:24 | #11729 (permalink) | |
Junior Member Join Date: Aug 2008
Member: 834024 Status: Offline Thanks Meter: 12 | Quote:
changes --------- - fixed errors in the schedule - updated direcTV listing - updated pre-season week 1 and 2 scores. rosters will be sent out after the pre-season. -- Toysoft, Inc. I tried to upload files but upload failed. shoot me an email address and I'll send them | |
The Following User Says Thank You to feces For This Useful Post: |
08-29-2008, 14:40 | #11730 (permalink) |
Member: 849023 Status: Offline Thanks Meter: 0 | Hello. Would just like to inquire if there is a patch or key for: 1. Astraware Westward 2. ML tank 3. Azeroth Wars My Hotsync ID is Bishop and the Astra ID is 732096 Thanks in advance |
Pocket PC Appz & Games | HuBMOBILE | HTC & PDA WM( With Touchscreen) | 8203 | 12-05-2019 14:12 |
Nokia Latest Appz & Games Section | HuBMOBILE | Nokia Multimedia | 17 | 11-21-2010 14:03 |
Palm OS Appz & Gamez | LBOZ_GSM | PalmOS /HP and others | 1014 | 05-05-2009 21:45 |
Nokia N73 Appz and games collection.Binpda+get unsigned appz signed with secman.100% | usman8416 | Nokia Multimedia | 0 | 06-24-2008 21:01 |
WM5 Pocket PC Appz & Games | eboy44 | HTC & PDA WM( With Touchscreen) | 2 | 08-08-2006 22:23 |
