BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
08-20-2010, 04:31 | #1 (permalink) |
No Life Poster Join Date: Mar 2006
Member: 246691 Status: Offline Thanks Meter: 54 | blackberry bold 9700 app error 523 |
01-05-2011, 04:51 | #10 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Mobile Phone Repairing
Member: 108747 Status: Offline Sonork: 100.108643 Thanks Meter: 655 | my problem is solved by this way:- Re: App Error 523 - Bold 9700 1) Make sure you have Blackberry Desktop Manager installed. BlackBerry - BlackBerry Desktop Software 2) On your PC, go to Start > Run and copy and paste the following line exactly (meaning with the quotation marks): "c:\program files\common files\research in motion\apploader\loader.exe" /nojvm 3) The Application Loader Wizard will appear -- click "Next." 4) In the "Connection:" drop-down menu, you should see "USB-PIN: UNKNOWN". Click the "Next" button. 5) You should then see a list of applications ready to be installed for your Blackberry. Hit Next and Finish and you are well on your way to getting your Blackberry back to life. Just don't disconnect anything and let the lengthy process finish completely. NOTE: If you do not see a list of applications mentioned in step 5 and instead see the message "The Blackberry Desktop Software does not have Blackberry Device Software for the device that you have connected to the computer. Contact your wireless service provider or system administrator," then you must download Blackberry's Operating System for your carrier and device. BlackBerry Operating System Downloads - BlackBerryFAQ Just select the appropriate carrier and network type, select your Blackberry model from the list and download the latest version. Install this download and follow the above steps again and you should be on the right path. |
03-07-2011, 13:17 | #11 (permalink) |
No Life Poster Join Date: May 2007 Location: INDIA
Member: 511749 Status: Offline Thanks Meter: 335 | Very good solution bahri sir Re: App Error 523 - Bold 9700 1) Make sure you have Blackberry Desktop Manager installed. BlackBerry - BlackBerry Desktop Software 2) On your PC, go to Start > Run and copy and paste the following line exactly (meaning with the quotation marks): "c:\program files\common files\research in motion\apploader\loader.exe" /nojvm 3) The Application Loader Wizard will appear -- click "Next." 4) In the "Connection:" drop-down menu, you should see "USB-PIN: UNKNOWN". Click the "Next" button. 5) You should then see a list of applications ready to be installed for your Blackberry. Hit Next and Finish and you are well on your way to getting your Blackberry back to life. Just don't disconnect anything and let the lengthy process finish completely. NOTE: If you do not see a list of applications mentioned in step 5 and instead see the message "The Blackberry Desktop Software does not have Blackberry Device Software for the device that you have connected to the computer. Contact your wireless service provider or system administrator," then you must download Blackberry's Operating System for your carrier and device. BlackBerry Operating System Downloads - BlackBerryFAQ Just select the appropriate carrier and network type, select your Blackberry model from the list and download the latest version. Install this download and follow the above steps again and you should be on the right path.[/QUOTE] |
03-30-2013, 13:49 | #13 (permalink) |
No Life Poster Join Date: Mar 2013 Location: pakistan Age: 34
Member: 1899191 Status: Offline Sonork: 100.1625109 Thanks Meter: 136 | do agin window of ur fone there is no other solution with out window if u have firmware of this verion thas gud and if u have not tell me i will sent u link. |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
Avoid 3 times error code in Nokia 6185 | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-08-2000 20:24 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
