Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 02-10-2010, 20:31   #1 (permalink)
Member: 22284
Thanks Meter: 81
Ramjan help
I tried to update 8220 and ended up with Error 507,i didnot back up and my son coul not even remember software version , i got the firmware but still cant load and ended up into fatal error as decribed by the pictures
Old 02-10-2010, 22:32   #2 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,429
Arrow
This problem comes from USB cable i faced
my advice change usb cable and try again it will be Done!
And follow this Procedure
Old 02-11-2010, 05:09   #3 (permalink)
Member: 22284
Thanks Meter: 81
i followed the procedure but came with the same error on display (Reload software :507)
Old 02-11-2010, 05:26   #4 (permalink)
Member: 757799
Thanks Meter: 782
first be sure you have full battery
if error again
update again use desktop manager
Old 02-11-2010, 09:39   #5 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,429
Arrow
Basically your phone was wiped before you got it and now uninstall the OS reboot pc then install other OS & make flash
Old 02-11-2010, 14:13   #6 (permalink)
Member: 1143132
Sonork: siraj93
Hello sir did u have any tool to unlock iphone 3.1.3 version please post me sir
Old 02-11-2010, 14:38   #7 (permalink)
Member: 1143132
Sonork: siraj93
Old 02-11-2010, 22:37   #8 (permalink)
Member: 22284
Thanks Meter: 81
Delower10 that's right i got the fone while it was already wiped out, now you say i have to remove and install other os, which tool to use to install other os cause i have these two firmmwares.
Old 02-11-2010, 23:53   #9 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,429
Arrow
To uninstall OS go (Start > control panel > add or remove ) u will see here which OS u have installed
To install OS just double click at (which u want to install ) & procedure inside
Old 02-12-2010, 03:13   #10 (permalink)
Member: 22284
Thanks Meter: 81
which is the right firmware to load to this fone at this point with this error Reload software 507
Old 02-12-2010, 11:52   #11 (permalink)
Member: 22284
Thanks Meter: 81
Actually the owner has told me that the BB 8220 is from T-mobile U.S.A
Old 02-12-2010, 12:10   #12 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,429
Arrow
Download the firmware and make update
don't forget to delete vendor
Old 02-12-2010, 21:26   #13 (permalink)
Member: 22284
Thanks Meter: 81
may you do me a favour by uploading this firmware at rapid share for easy download cause my speed is too slow
Old 02-13-2010, 02:59   #14 (permalink)
Member: 1234068
Thanks Meter: 3
help me...my bb 8320, it works fine basically, it's just that the speaker is so low, people can not hear me clearly..i've no idea how to fix it. a lot of times people i called just keep saying 'hallo' coz they cannot hear me speaking..any idea?
Old 02-13-2010, 05:22   #15 (permalink)
Member: 22284
Thanks Meter: 81
May someone give me a link not the official website but something like Rapidshare website where i may download this blackberry 8220 pearl firmware8220M_PBr4.6.0_rel520_PL4.1.0.100_A4.6.0 .305_AVEA.exe)
mr ramjan helps needed here malek45 BlackBerry (RIM) 2 02-25-2009 10:29
@@ RAMJAN , plz help with 8830 verizon sooo strange! shama_00 BlackBerry (RIM) 14 01-07-2009 13:34
Help you Ramjan FIRMWAR BB 8120 MOVISTAR SPAIN ???? omar_peligro BlackBerry (RIM) 2 12-19-2008 11:45
Mr.RAMJAN help godwin BlackBerry (RIM) 1 12-09-2008 12:59
Page generated in 0.24314 seconds with 10 queries
