Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Game Consoles & Mp3/4 , HD players
Game Consoles & Mp3/4 , HD players Repairing and servicing Mp4, Mp3 devices, HD players.. you may also find here any threads related to Game Consoles devices like Wii, PlayStation, Xbox, Nintendo .. etc
Old 01-01-2009, 20:40   #1 (permalink)
Member: 21937
Thanks Meter: 279
psp freezing at psp loading screen ??
hi
i got a psp slim in here , got it freezing while loading any game .
i reflashed it with latest 5.00m33 , still while loading iso game psp freezing on the psp white loading screen , every time .
it also freez while exiting from recovery/settings menu of the m33.
any ideas what and how to fix ?
thx
psp was working before and from what i asked my friend , it didnt fall or got any damge.
thx
Old 01-01-2009, 23:02   #2 (permalink)
RNC_EBM's Avatar
Member: 101860
Sonork: 100.1582168 100.77603
Thanks Meter: 6,036
Originally Posted by TRABEL View Post
hi
thx
thx
http://forum.gsmhosting.com/vbb/show...96&postcount=2
br
RNC_EBM
The Following User Says Thank You to RNC_EBM For This Useful Post:
Old 01-02-2009, 09:29   #3 (permalink)
Member: 21937
Thanks Meter: 279
Originally Posted by RNC_EBM View Post
already checked this before , cpu speed is and was at default.
i also played with speeds a little bit , same results , psp also freezing while exiting recovery menu ( all the time)
btw , i just notice , psp drive is not working , i will open it now , maybe something lose there .
Old 01-02-2009, 11:45   #4 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
if you have PLUGINS RUNNING, TRY to disable all.
br
RNC_EBM
Old 01-02-2009, 11:48   #5 (permalink)
Member: 21937
Thanks Meter: 279
br
RNC_EBM
no bro , psp is brand after new f/w .
nothing runing and all is defualts
Old 01-02-2009, 12:15   #6 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
are u using ORIGINAL Mem Stick or Fake ?
FAKE Memory Stick CAN CAUSE & NOT ONLY THAT.....
br
RNC_EBM
Old 01-02-2009, 12:21   #7 (permalink)
Member: 21937
Thanks Meter: 279
br
RNC_EBM
well , this 8gig card looks original , thought i have tested with different card and same problem , also , tested with only umd , and no memory card , psp freez when loading umd on white screen , if i take umd out psp still froze , if i put umd from psp screen its not spining and not see any umd
Old 01-02-2009, 12:29   #8 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
try not to use umd ( remove UMD at tray ) then use memory stick to play games.
i think your umd drive has problem.
br
RNC_EBM
Old 01-02-2009, 12:42   #9 (permalink)
Member: 21937
Thanks Meter: 279
br
RNC_EBM
same bro
even no umd , iso get psp to freez at psp loading screen.
after this only remove battery restart it.
even changed memory sticks.
Old 01-02-2009, 12:59   #10 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
same bro
does your setting/UMD AutoStart is OFF ?
if yes - DISAble it & REStart.
if NOT - Maybe your PSP has PROBLEM (HARDWARE)
br
RNC_EBM
Old 01-02-2009, 14:09   #11 (permalink)
Member: 21937
Thanks Meter: 279
br
RNC_EBM
umd option is no umd , tested few of the umd options, same problem.
maybe hardware problem ... but what to look for.
Old 01-08-2009, 11:34   #12 (permalink)
Member: 939217
Thanks Meter: 18
try formatting your flash1 folder. enter recovery menu, scroll down to advance and press enter. then scroll down to "format flash1 folder" and press enter (don't panic, this will not brick your psp). the psp will then reset itself and you will need to re-enter the time, date etc.
to check to see if you have a fake mem card, (with the mem card in the psp) highlight the "memory card" icon in the "game" icon on the psp's xmb (main screen) and press triangle. then select "information". a small list will appear with your mem cards details. look down to where it says "Magicgate". if it reads "supported" next to it, then you have an original mem card. but if it reads "unknown", then you have a fake.
did you format your mem card after you install v5.00m33? if not, copy all your game saves and anything you wish to keep and format the mem card using the psp's format utility (found in the "System Settings" icon). replace the game/s and try again.
have you enabled the "use no umd" option? you can do this by pressing "select" in the xmb, and the vsh menu will appear. scroll down to "umd iso mode" and press left or right on your d pad until it reads either "m33 driver" or "sony NP9660". then exit the vsh menu and try again.
also im not sure if your aware, but there is a new version of v5.00m33 available. if all of the above doesn't work, then you could try and update to v5.00m33-4. that might fix your problem.
Old 01-08-2009, 22:08   #13 (permalink)
Member: 21937
Thanks Meter: 279
thx for a nice answer
but
psp brought to me by a friend with this problem , psp was at 3.71m33 , same state , freezing when runing a game , from memory stick or from original UMD.
first thing i did was upgrading to 5m33.... and format the memory stick ..
thought problem is the same. psp also freezing when exiting recovery mode.
also tested with other memory stick.
also tested with no memory stick at all and original umd.
i think i have formated flash1 but not sure , i will test this again.
i did uses idstorge recovery same problem.
Old 01-08-2009, 22:14   #14 (permalink)
Member: 939217
Thanks Meter: 18
if it still doesn't work, you could always try and use a pandora's battery again to reinstall the custom firmware. there is a new version of DC available. and it will install v5.00m33-4. and you can reset your idstorage keys in on dcv8.
Old 01-08-2009, 22:18   #15 (permalink)
Member: 21937
Thanks Meter: 279
all i did was from a pandora battery
latest v5.00m33-4 and resey idstorage from dcv8
The Following User Says Thank You to TRABEL For This Useful Post:
samsung x210 freezes at the start screen GSMELECTRO Samsung Hardware Repair 7 04-17-2011 16:07
p800 freezes at the startup screen chuoi Sony Ericsson 5 06-27-2009 15:08
K800 Freeze At Sony Ericsson Screen Please Help TAZMAN Sony Ericsson 1 08-17-2007 20:45
SHARP GX25 freez at Vodafone screen ,but gsmfriend Sharp 5 11-06-2006 06:17
V800.....freeze at startup with Vodafone logo on the screen...need help... plruzza Sony Ericsson 3 02-07-2006 13:14
Page generated in 0.28012 seconds with 9 queries
