Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GPS devices , Navigators & Maps
GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc
Old 12-20-2008, 14:34   #106 (permalink)
Paul.Thomas's Avatar
Member: 5302
Thanks Meter: 6
ok my friend has arrived in Thailand and he has the map I need with him so that bits ok
(if not use GpsGate set to generic NMEA GPS receiver) I don't understand what this means or how toselect external none garmin gps, sorry I'm having a blond day lol
Old 12-20-2008, 14:59   #107 (permalink)
Member: 385577
Thanks Meter: 656
Sorry.... Forget about that part.....
Just download Garmin Mobile XT, the basemap and the support-files
Install them
Use key generator to generate a key for your device
Put the key into a file called SW.UNL and save it in the garmin folder on your device.
The software should now be unlocked and be able to find/use the GPS.
Upload your unlocked maps from Mapsource.
Thats it....
Regards
Mike
Old 12-20-2008, 15:06   #108 (permalink)
Member: 5302
Thanks Meter: 6
thanks Mike I have done all that but it just keeps looking for my GPS It works with my PPC using Mapking or Tom Tom but not Garmin Why?
Old 12-20-2008, 15:46   #109 (permalink)
Member: 385577
Thanks Meter: 656
Have you enabled your Bluetooth in the phone? Have you paired your GPS with the phone?
If your unit-number is correct, and you have generated the rigt unlock code, you might have to enable your GPS.
Go to Settings > System > Remote GPS > and "Enable or Disable"
Regards
Mike
Old 12-20-2008, 16:13   #110 (permalink)
Member: 5302
Thanks Meter: 6
yes i have enabled your Bluetooth in the phone
yes i have paired your GPS with the phone
Go to Settings > System > Remote GPS > and "Enable or Disable" I have done this also
I have uninstalled it all started again but now its not showing the Card ID.??
Old 12-20-2008, 16:34   #111 (permalink)
Member: 385577
Thanks Meter: 656
Is it showing unit ID? The card ID or unit ID is the same....
Are you installing on a SD-card or on the harddrive of the phone?
Mike
Old 12-20-2008, 16:50   #112 (permalink)
Member: 5302
Thanks Meter: 6
I have now installed version 5
its is now showing a unit id and a card id
this software after it can not find a garmin gps say it will search for a n other gps but still does not find one ??
I run the software on the pc which install to the sd card I then put the sd card in the I=Mate jam and it askes to install and I say yes
Paul
Old 12-20-2008, 17:03   #113 (permalink)
Member: 385577
Thanks Meter: 656
Paul
OK....
What version of the unlocker are you using?
Mike
Old 12-20-2008, 17:08   #114 (permalink)
Member: 5302
Thanks Meter: 6
V1.5 and it gives a different code each time you run it
plus when i start the software it says purchase, trail, enter prodict key, or connect to gps
Paul
Old 12-20-2008, 17:13   #115 (permalink)
Member: 5302
Thanks Meter: 6
mike you have msn? or icq? or skype?
Old 12-20-2008, 17:22   #116 (permalink)
Member: 385577
Thanks Meter: 656
No, I do not have skype etc......
Please check you saved the file as SW.UNL and not as SW.UNL.TXT....
I am not realy an expert in unlocking the software (I can not realy remember how I did it), and maby you should look somewhere else in this forum.....
Regards
Mike
Old 12-20-2008, 17:25   #117 (permalink)
Member: 5302
Thanks Meter: 6
ok thanks anyway I have the .unl only no problem and thanks for trying
Paul
Old 12-21-2008, 03:18   #118 (permalink)
Member: 926828
Hi Mike,i have a big problem whit ROAD 2008.After i download the 2 part,and i whan to extract them whit Winrar i receive this messages : D:\ROAD2008[1].part1.rar: CRC failed in ROAD2008.nrg The file is corrupted .Please help me
Old 12-21-2008, 06:04   #119 (permalink)
Member: 757575
Thanks Meter: 70
DrDre88,
Extract both files simultaneously in WinRAR. Hope this helps.
fugglefeet
Old 12-21-2008, 07:32   #120 (permalink)
Member: 385577
Thanks Meter: 656
Check the size of both files:
ROAD2008.part1.rar 238 MB (250.000.000 byte)
ROAD2008.part2.rar 185 MB (194.614.574 byte)
Do both your files have the same size?
If not - download again.
Or else do as fugglefeet wrote....
Rightclick on ROAD2008.part1.rar and select "Extract to ROAD2008"....
In this case both the files will be joined to ROAD2008.nrg
Regards
Mike
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f491/garmin-xt-maps-mapsource-version-632595/
Posted By For Type Date
What is GARMIN XT V5 MIDDLE EAST? This thread Refback 06-29-2013 08:06
malaysia map for garmin xt carrotboy88 GPS devices , Navigators & Maps 1 01-19-2012 08:18
Garmin XT Canada Map jati_grewal GPS devices , Navigators & Maps 2 07-18-2009 13:10
maps for garmin xt billyprepo GPS devices , Navigators & Maps 1 03-11-2009 10:33
Need help with N95-2 & Garmin XT 4.10.60 maps wizard4it GPS devices , Navigators & Maps 1 10-14-2008 17:45
Garmin XT Canada Maps 2009 s3lekta Nokia Multimedia 0 09-21-2008 19:45
Page generated in 0.22806 seconds with 10 queries
