GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
11-28-2007, 22:34 | #2266 (permalink) | |
Junior Member Join Date: Nov 2007
Member: 638237 Status: Offline Thanks Meter: 0 | Quote:
Ye im selecting all the application capabilities. Attached is a screen shot of what i think is wrong. If you look you'll see that it says OS v9 only, is that right or? Many thanks Liffey Last edited by Liffeymanok; 03-15-2008 at 14:12. | |
11-28-2007, 23:17 | #2268 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Over Here
Member: 613875 Status: Offline Thanks Meter: 61 | Quote:
What ever key you use to make the csr file with DevCert tool should be the same key when signing apps/ Example I use sultan key to make csr file, I sign all the apps with sultan key also. | |
11-28-2007, 23:21 | #2269 (permalink) |
Member: 636693 Status: Offline Thanks Meter: 0 | Hi Could someone please create a cetificate for my N95. Any help would really be apperciated, and which is the best signing tool, i have downloaded a few not sure which one to use. IMEI: 358998010006735 Thank you in advance. |
11-28-2007, 23:44 | #2271 (permalink) |
Junior Member Join Date: Jun 2007
Member: 526478 Status: Offline Thanks Meter: 0 | hi boys after not having luck getting anyone to help me signing route66 i decided to do it myself. i've downloaded the file ***.cer from symbiansigned.com after using devrequest now can anyone tell me what do i have to do with that fie. Thanks very much |
11-29-2007, 00:20 | #2277 (permalink) | |
http://forum.gsmhosting.com/vbb/showthread.php?t=466498 | |
11-29-2007, 00:44 | #2279 (permalink) | |
No Life Poster Join Date: May 2007 Location: UK
Member: 503346 Status: Offline Thanks Meter: 2,582 | Quote:
your Route 66.sis is named wrong, 1st edit the auto_sign Sis.bat 2nd, change the route 66.unsigned.sis to the name of your app that you have downloaded. this should sort the problem out (i/o error is when i file can't read / write to and from the software, i.e Input/Output Error) another way to sort the problem out is download my B.u Mobiles Sign Your Apps v2.0 this little program will sort out all the renaming and signing parts that you are stuck on this program was made for people finding the signing process hard....! like i always say, it's easy as 1-2-3 B.u Mobiles | |
Need crack for route 66 mobile 7 for n95 and australia maps. | carulli | Nokia Multimedia | 3 | 04-04-2009 11:14 |
MDictionary v6.7 S60v3 SymbianOS9.x Signed ML and Dictionaries (Update:15.03.09) | aapkae | Nokia Multimedia | 0 | 03-16-2009 10:01 |
Route 66 Wms Latest Uk Maps ??? | markcoopz | GPS devices , Navigators & Maps | 0 | 03-18-2007 13:34 |
Denmark map for TT 5.2 or Route 66 mobile 7 | lordb24 | Nokia Multimedia | 0 | 01-15-2006 21:12 |
Route 66 Mobile 2005 and GPS BT Receiver | fido59 | Nokia Multimedia | 1 | 10-11-2005 07:34 |
