GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
08-18-2007, 16:37 | #391 (permalink) |
Junior Member Join Date: Oct 2006
Member: 367990 Status: Offline Thanks Meter: 0 | Many Thanks Wayne |
08-19-2007, 10:13 | #396 (permalink) | |
No Life Poster Join Date: May 2007 Location: UK
Member: 503346 Status: Offline Thanks Meter: 2,582 | New Keygen Needed! Quote:
You need to find a new keygen for palm/pocket os give me a day and i'll post mine that i use on here for you! | |
08-19-2007, 10:14 | #397 (permalink) | |
Member: 503346 Status: Offline Thanks Meter: 2,582 | Route 66 Version 7.3.545 Quote:
But Route 66 Mobile 7.3.545 doesn't support custom POI's There is a version being made that will support them, when i get more news on it i will post and let you know BuMobiles | |
08-19-2007, 12:51 | #398 (permalink) |
Major Poster Join Date: Oct 2006
Member: 362898 Status: Offline Thanks Meter: 0 | ok i have it all up and running now on a nokia n95 first impresions not as good as tomtom but will do for now i used this guide to install it if it helps any1 else connect N95 to PC select "PC Suite" mode in Nokia Application Loader install signed Route66 .sis file onto your N95 select install to "memory card" NOT "phone memory" !!! after install is complete, exit application, DO NOT RUN IT YET !!! disconnect and reconnect N95 to PC again select "Mass Storage" mode this time *** UNHIDE hidden folder first ! in Windows My Computer ->Tools -> Folder Options -> View -> Show Hidden files and folders copy map (example: E-CDN.prm) into System\Apps\Route66\maps folder on phone memory card If there is no maps folder, create a new folder called maps TO ADD MAP TO ROUTE66: in memory card you will see a folder called System open it and you will see a folder called Apps open it and you will see a folder called Route66 open it and you will see a folder called maps, and there is where you put the map. example E-CDN.prm After a new map is added select from the menu "Activate via internet". Register with any 16 digit alpha-numeric character code. If you get resource files are missing message at start-up, it is because you installed an incompatible map. If you are having difficulty when you reach the "activate via internet" step and the applcation closes, then do this : see attached zipped file (ActivationKey.zip) unzip the attached zip file connect your n95 to your pc select "mass storage" unhide hidden system files navigate to System\Apps\Route66 folder drop the file that you unzipped earlier ActivationKey.dat into the Route66 folder restart your phone and relaunch the Route66 application and this if your using vista to find the files This tutorial shows the user how to view hidden files and folders on their system. Seeing your hidden files and system files in Vista is not much different than in XP. Here are the step-by-step directions. Remember that system files are hidden for a reason. Don't go messin' around with stuff. 1. Click the round blue Start thing in the left corner 2. Click Control Panel 3. Click Folder Options 4. Click the View tab 5. Click Show hidden files and folders 6. If you want to see system files as well, unclick Hide protected operating system files (Recommended) 7. Click OK hope it helps it helped me |
08-19-2007, 12:57 | #400 (permalink) |
Member: 362898 Status: Offline Thanks Meter: 0 | http://rapidshare.com/files/49793772...part1.rarCode: http://rapidshare.com/files/49791970...tain.part2.rar these maps for the uk work with the 7 digit postcode search on route 66 |
Need crack for route 66 mobile 7 for n95 and australia maps. | carulli | Nokia Multimedia | 3 | 04-04-2009 11:14 |
MDictionary v6.7 S60v3 SymbianOS9.x Signed ML and Dictionaries (Update:15.03.09) | aapkae | Nokia Multimedia | 0 | 03-16-2009 10:01 |
Route 66 Wms Latest Uk Maps ??? | markcoopz | GPS devices , Navigators & Maps | 0 | 03-18-2007 13:34 |
Denmark map for TT 5.2 or Route 66 mobile 7 | lordb24 | Nokia Multimedia | 0 | 01-15-2006 21:12 |
Route 66 Mobile 2005 and GPS BT Receiver | fido59 | Nokia Multimedia | 1 | 10-11-2005 07:34 |
