GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
![]() | #558 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2005
Member: 147270 Status: Offline Thanks Meter: 16 | ![]() Quote:
http://www.megaupload.com/?d=26MH2A4S | |
![]() | #559 (permalink) | |
Crazy Poster ![]() ![]() ![]() Join Date: Sep 2007
Member: 578458 Status: Offline Thanks Meter: 6 | Quote:
I installed it on my phone memory. I've put the maps on my memory card, but don't forget to put the language (sound) also on the memory card;Route66 will not check the phone memory for it when the map is installed on the memory card and Route66 is installed on the phone memory. Newest version here: http://rapidshare.com/files/48535900...d.UnSigned.zip | |
![]() | #560 (permalink) | |
Download and Install: https://www.symbiansigned.com/DevCer..._2006_v2.0.exe Execute and follow the instructions. Hint: ACS Pub ID should be 'no'. | |
![]() | #561 (permalink) |
Member: 578458 Status: Offline Thanks Meter: 6 | I heard that these versions work without signing. Could someone check it and report back? http://thepiratebay.org/tor/3706913/...s.Included-TKM |
![]() | #564 (permalink) | |
Junior Member Join Date: Sep 2007
Member: 578820 Status: Offline Thanks Meter: 1 | Quote:
just wanna know,what is this sign sis_gui_V1.1 for? is it just for n95 or other symbian devices too? many thanks in advance.. | |
![]() | #565 (permalink) | |
Junior Member Join Date: Jan 2004
Member: 51428 Status: Offline Thanks Meter: 0 | Quote:
I'm using the older version cos this one works with sound. Thanks HardSlam for the tip on getting sound for v7.3.545. | |
![]() | #567 (permalink) |
Member: 578458 Status: Offline Thanks Meter: 6 | ![]() My guess is on the phone memory:so \system\apps\route66\<a map> << there the sound file should be located. In short: Route66 on phone memory && Maps on SD --> sound should also be on SD. Route66 on phone memory && Maps on phone memory --> OK. Route66 on SD && Maps on SD --> OK. |
![]() | #568 (permalink) |
Junior Member Join Date: Nov 2006
Member: 398344 Status: Offline Thanks Meter: 0 | Thanks Bumobiles for the reply, i tried to activate it and it says "too many active devises" still asking for activation code. Tried many times with 16 digit codes but does not work. Any suggestions? Thanks |
![]() | #570 (permalink) | |
Need crack for route 66 mobile 7 for n95 and australia maps. | carulli | Nokia Multimedia | 3 | 04-04-2009 11:14 |
MDictionary v6.7 S60v3 SymbianOS9.x Signed ML and Dictionaries (Update:15.03.09) | aapkae | Nokia Multimedia | 0 | 03-16-2009 10:01 |
Route 66 Wms Latest Uk Maps ??? | markcoopz | GPS devices , Navigators & Maps | 0 | 03-18-2007 13:34 |
Denmark map for TT 5.2 or Route 66 mobile 7 | lordb24 | Nokia Multimedia | 0 | 01-15-2006 21:12 |
Route 66 Mobile 2005 and GPS BT Receiver | fido59 | Nokia Multimedia | 1 | 10-11-2005 07:34 |
