GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
09-30-2007, 22:29 | #931 (permalink) |
Junior Member Join Date: Sep 2007
Member: 593710 Status: Offline Thanks Meter: 0 | now is on my Nokia N95 the no more error message "Resource files are missing." But activation failed for my germany map is already there . I used two diffenret germany maps (one from 17.06.2006 and other from 21.11.2005). Entering any 16 characters do not help. How can I activate the german map? Can me send some one a funktionen link for a german map which I can activate with a 16 sign? Thanks Ivan |
09-30-2007, 22:29 | #932 (permalink) |
Member: 599420 Status: Offline Thanks Meter: 0 | OK here goes. I have downloaded the Route 66 aplication (for use on my Nokia N80) and it's telling me that the certificate is expired. My IMEI number is 3583 6100 5620 905 I would be obilged if somenody could get the cert for me. |
09-30-2007, 22:30 | #933 (permalink) | |
No Life Poster Join Date: May 2007 Location: UK
Member: 503346 Status: Offline Thanks Meter: 2,582 | thats correct! Quote:
09-30-2007, 22:32 | #934 (permalink) | |
Member: 503346 Status: Offline Thanks Meter: 2,582 | download a cracked version Quote:
2nd, you need to copy the maps to your memory card in a folder called "system\apps\route66\maps" 3rd, install and reg with any 15 digit no by selecting reg via internet | |
09-30-2007, 22:51 | #935 (permalink) | |
Member: 599420 Status: Offline Thanks Meter: 0 | Quote:
Thanks in anticipation, Dean | |
09-30-2007, 23:24 | #936 (permalink) |
Member: 593710 Status: Offline Thanks Meter: 0 | Hi BuMobiles, I have installed a cracked version it is the "Route66_7.3.545.Patched.UnSigned.SIS". I signed it and after the installation I copied this signed file to "system\apps\ROUTE66" My map (DACH.prm from 17.06.2007) is located in directory "system\apps\ROUTE66\maps". I put my sd-card in my N95 and install Route66. After installation I get now again "resource files are missing". This is 1 step behind the activation. with an other package was activation not successful. The best way to solve this problem I think to tell me the right link of cracked Route66. Otherwise I assume I will also next year the same troubles. Thanks Ivan |
10-01-2007, 08:20 | #939 (permalink) |
Freak Poster Join Date: Jul 2004
Member: 72707 Status: Offline Thanks Meter: 6 | Hi BU, I have got a problem with the fujitsu siemens loox pocket pc you help me install tomtom on satursday. The first time I turn is on it found the GPS signal right away, however now it says "waiting for a valid signal" The GPS is internal, what should the settings be? How can we overcome this problem? is there a GPS Fix software? Thanks very much. Umster |
10-01-2007, 09:13 | #940 (permalink) |
Member: 598591 Status: Offline Thanks Meter: 0 | cert for autoroute66 please Hi could you plase make a cert for the unsigned copy of auto route for me pease the simbiansigned page wont accept my email address Nokia N95 IMEI CODE 356962016728678 Many thanks Benitez1 |
10-01-2007, 09:23 | #941 (permalink) | |
Member: 503346 Status: Offline Thanks Meter: 2,582 | What Version TomTom Quote:
10-01-2007, 14:43 | #942 (permalink) | |
Insane Poster Join Date: Sep 2007
Member: 598694 Status: Offline Thanks Meter: 4 | Quote:
.PRM are for route66 mobile version 7 I have the same prob with UK and France maps, Have the PRM not the actual maps for nokia 6110 route66 version 6 I beleive | |
10-01-2007, 15:04 | #944 (permalink) | |
Member: 598694 Status: Offline Thanks Meter: 4 | mmmmmmmmm Quote: it seems that everyone here in the know about this stuff are simply incapable of r-engineering Route 66 version 6 ( the one that comes with the Nokia 6110 Navigator ) Yet they are able to easily r-engineer and bypass version 7. I have read that version 6 is much better though a little slow picking up you location at first I have read that version 7 looks very ugly I have version 6 ( I beleive ) all I need it certified maps for UK Scotland Ireland and France. I dont see this as a hard ask.. I already have the program signed wizard4it | |
10-01-2007, 15:11 | #945 (permalink) |
Member: 598694 Status: Offline Thanks Meter: 4 | Help a friend in need BUMOBILE You seem to be the guy with the know how etc, can you help me with maps for the Nokia 6110 Navigator... Do I really have to go through all the stuff and install version 7 although I already have a signed and certified / registered copy on my phone ( version 6 is it not.. ) If you can, help a friend out, I am new at all this at it is far easier to download already cracked maps than it is to download a program and go through the cert instr and sign instruction etc all I need is the maps that will work with the original route66 software, I have highspeed internet connection so size is not that importants, I have also bought a 2gb card for the phone as the original 512mb will not be enough please help if you can. wizard4it thankyou in advance |
Need crack for route 66 mobile 7 for n95 and australia maps. | carulli | Nokia Multimedia | 3 | 04-04-2009 11:14 |
MDictionary v6.7 S60v3 SymbianOS9.x Signed ML and Dictionaries (Update:15.03.09) | aapkae | Nokia Multimedia | 0 | 03-16-2009 10:01 |
Route 66 Wms Latest Uk Maps ??? | markcoopz | GPS devices , Navigators & Maps | 0 | 03-18-2007 13:34 |
Denmark map for TT 5.2 or Route 66 mobile 7 | lordb24 | Nokia Multimedia | 0 | 01-15-2006 21:12 |
Route 66 Mobile 2005 and GPS BT Receiver | fido59 | Nokia Multimedia | 1 | 10-11-2005 07:34 |
